Writing custom characters to LCD display
Results 1 to 40 of 60
    Iran
    Hi, i have written this program to make custom character on 2*16 LCD but LCD shows nothing.i use picbasic pro and PIC16F877A. what's the problem?
    define OSC 4
    ' Set LCD Data port
    DEFINE LCD_DREG PORTC
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTC
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 1
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTC
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 0
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    'Making lcd ready
    lcdout $fe,1
    m var byte
    n var byte
    m=25
    n=98
    lcdout $fe,$40,$08,$04,$02,$01,$01,$02,$04,$08
    lcdout $fe,$14
    lcdout $fe,$00,$00,$07,$07,$1F,$00,$00,$00
    lcdout $fe,$14
    lcdout $fe,$04,$04,$04,$04,$07,$00,$00,$00
    lcdout $fe,$14
    lcdout ":",#m,".",#n
    Quote Originally Posted by amindzo View Post
    If you study post #2 of this thread, you'll find your problem...
    Iran
    i have studied that post but i still have problem. post 2 just specify the 8 location but LCD is 2*16.what about other locations?
    The 8 locations are memory locations in the LCD.
    Take a look at post #32
    Copy that code.
    If you had studied post #2 (and the rest of the posts), you'd notice that you can only program the first 8 locations in the LCD's ram.
    You may be setting up the first few custom characters in the LCD ram, but you surely aren't trying to display them...
    These answers are so easy.
    Why do they always turn into personal attacks.
    If they don't get it. Explain it again.
    Maybe your version will make more sense.
    No personal attack intended. I thought post #32 explained it...
    There are 8 memory locations on most LCDs, starting at $40 and ending at $78. Each custom character will be at one of these locations.
    character 0 = $40
    character 1= $48
    character 2 = $50
    character 3= $58
    character 4 = $60
    character 5= $68
    character 6 = $70
    character 7= $78
    In your code
    writes your character to "0" position. or character 0
    To display that character on the first line, first space
    LCDOUT $FE,1,0
    second space
    LCDOUT $FE,$81,0
    If you have a character in the second memory location
    lcdout $fe,$48,$08,$04,$02,$01,$01,$02,$04,$08
    LCDOUT $FE,1,1
    second space
    LCDOUT $FE,$81,1
    Sorry Dave, wasn't refering to you.
    But your new explanation might help someone.
    Oct 2009
    MEXICO
    Unhappy Trying to make an example !!!
    HI DEAR ELECTRONIC HOBBYST:
    I'M FROM MEXICO AND I REALLY WANT TO LEARN ABOUT THIS TOPIC HOW TO CREATE MY OWN CHARACTER, BUT I DON'T REALLY KNOW HWAT HAPPENED I HAVE TROUBLES ON THE SIMULATION WITH PROTEUS ALL OF YOUR EXAMPLES AND ONLY ONE WORKS THE EXAMPLE THAT IS POSTED ON THE NUMBER 8, BATT LEVEL BUT ALL OF THE OTHER ONES DOESN'T WORKS I HAVE TRIED IN MANY WAYS, I USE PIC BASIC PRO TRYING TO CHARGE MY OWN PROGRAM ON A PIC16F877A CHEK IT OUT !
    COULD SOMEBODY TELL ME WHAT'S GOING WRONG ??
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 140
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 4
    DEFINE ADC_SAMPLEUS 50
    ADCON1=%00001110
    TRISA=%111111
    TRISB=%00000000
    TRISC=%00000000
    TRISD=%00000000
    TRISE=%000
    PORTA=0
    PORTB=0
    PORTC=0
    PORTD=0
    PORTE=0
    LoopCount VAR BYTE
    Clear
    LCDOut $FE,$60,$00,$0a,$0a,$00,$00,$11,$0e,$00 ; #4 Smiley Face
    Pause 1000
    MAIN
    For LoopCount = 1 TO 80
    LCDOut 4
    Next LoopCount
    GoTo MAIN
    THANKS FOR YOUR ATTENTION AND IF SOMEBODY COULD TELL ME HOW TO PUT IN ON WORKING, THAT COULD BE GREATE !! SEE YOU SOON HAVE A NICE DAY
    Maybe try
    LCDOUT $FE,1,4
    Oct 2009
    MEXICO
    Talking Thanks man !!
    HEY DAVE, THANKS A LOT MAN I REALLY APRECIATE THAT HELP BY YOURSELF.
    YEAH, I KNOW I SHOULD WEAR SAFETY GLASSES WHEN I'M PROGRAMMING jajaja WILL NOT BE DE DEVIL IF I KILL MYSELF PROGRAMMING WITHOUT IT !! jaja WELL LET ME TRY ANOTHER EXAMPLES MAN
    THANKS A LOT AGAIN
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 21:06
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
