understanding I2CWrite optional address parameter?
Results 1 to 9 of 9
    Jan 2007
    Default understanding I2CWrite optional address parameter?
    Hello,
    I was experimenting with driving a PCF8547P 8-bit IO chip today with a PIC12F683
    I tested it out by having it drive an LED bargraph
    I was scratching my head over the "optional" address parameter within the I2CWRITE command.
    I searched around and noticed someone applied the value of zero to that parameter, for the PCF8547P chip.
    But I didn't think it would work - because the I2C protocol within PCF8547P datasheet does not call for that parameter.
    So I figured the PCF8547P wouldn't respond.
    I was surprised to find however it did work!
    So I'm curious to know what is going on with that optional "Address" parameter.
    Does the I2CWrite function ignore it when it is zero?
    If the I2CWrite function actually does send a zero - how is it that does not mess up the PCF8547P's protocol?
    dw
    Jan 2007
    Default Re: understanding I2CWrite optional address parameter?
    Attached is also a screen shot of one of the I2C transactions.
    I was surprised to see two read transactions followed by one write transaction.
    Especially because there is no IC2READ occurring in the code.
    I'm simply writing one value to the IO chip.
    So I wonder if the chip is programmed to return the two READ transactions - or is PBP3 doing that as part of the IC2WRITE function?
    PCF8547p/t/a is an unusual situation having only one register to read or write from, the chip cares not how many reads or writes you squeeze into one transaction.
    the final result is the last byte written or read.
    all i2c read transactions start with a write transaction sequence to set the register to read from if necessary a PCF8547p/t/a ignores this action.
    to make any sense of what you allege without the code to demonstrate it is near impossible
    Aug 2011
    The "address" is just another one or two data bytes (depending on the data type used) sent before the actual "data".
    Typically it's used for eeproms where you need to send an address parameter, or a register number.
    The PCF8574 only has a single 8-bit register and doesn't require anything but the data. If you send multiple bytes to the device it'll
    set the output port multiple times. For example, if you sent $00, $55 it would set all the outputs low before setting the port to $55.
    So, setting the "address" to 0 will do the same thing.
    I can't explain the read. It's certainly not being sent by the PCF since it's a slave device.
    Jan 2007
    Thanks!
    Here is the code:
    mainloop:
    for B0 = 0 to 255
    I2CWRITE SDA, SCL, $40, 0, [B0]
    next B0
    for B0 = 255 to 0 step -1
    next B0
    goto mainloop
    My guess is - since the PCF chip isn't doing the READ transaction - it must be built into the IC2WRITE function.
    Just curious
    thats not a complete program ,its a pointlless snippet
    this is a program
    ;pic16f1825
    DEFINE I2C_SLOW 1
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    define OSC 32
    trisa=%11011111
    trisc=%11111110
    ANSELA = 0
    ANSELC = 0
    OSCCON = $70
    OPTION_REG.7=0
    wpuc= %00011000
    SDA         VAR PORTc.3       ; I2C Data pin
    SCL         VAR PORTc.4     ; I2C Clock Pin
    pcf_Addr CON $78
    led         VAR latc.0
    leds var byte
    b0 var byte
    for B0 = 0 to 255
    I2CWRITE SDA, SCL, pcf_Addr, 0, [B0]
    pause 5
    led=!led
    next B0
    pause 5
    led=!led
    next B0
    led=!led
    goto Main
    this is how it looks on a logic analyzerName:  Untitled.jpg
    and this is a trace , is shows no signs of what you claim
    Jan 2007
    Thanks Richard
    Interesting how my analyzer shows two READ transactions following each WRITE transaction - and your's apparently does not.
    there is no apparently. its what should and does happen.
    more interesting is that your analyser does not even come close to reflecting what your "snippet" should reproduce.
    either your analyser is defective/miss used or the "snippet" is not what is being measured.
    Jan 2007
    I think its best for me to drop this conversation.
  1. Help in Understanding the Math
    Last Post: - 24th March 2012, 15:49
  2. So many option but little understanding
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2010, 09:45
  3. I2C optional label question
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 13th July 2009, 17:17
  4. HSERIN WAIT parameter
    By tishri in forum mel PIC BASIC
    Last Post: - 9th December 2008, 10:23
  5. Understanding Interrupts
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 01:53
