18F1220 - DEBUGIN not working
Results 1 to 3 of 3
    SWITZERLAND (french speaking)
    Default 18F1220 - DEBUGIN not working
    Hi All,
    As HSERIN and HSEROUT are working well on my 18F1220, I can't make DEBUGIN work (DEBUG is okay).
    I couldn't find any information searching in the forum and googeling around so if somebody has a clue where I'm missing something...
    @ __CONFIG  _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _INTIO1_OSC_1H ; OSC1 as RA7, OSC2 as RA6
    @ __CONFIG  _CONFIG2L, _BORV_27_2L & _BOR_OFF_2L & _PWRT_OFF_2L
    @ __CONFIG  _CONFIG2H, _WDT_OFF_2H & _WDTPS_32K_2H
    @ __CONFIG  _CONFIG3H, _MCLRE_OFF_3H
    @ __CONFIG  _CONFIG4L, _DEBUG_OFF_4L & _LVP_ON_4L & _STVR_ON_4L
    @ __CONFIG  _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    @ __CONFIG  _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG  _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    @ __CONFIG  _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG  _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    @ __CONFIG  _CONFIG7H, _EBTRB_OFF_7H
    OSCCON  = %01110000 'set INTRC to 8 MHZ
    OSCTUNE = %00000000 'OSCILLATOR TUNING REGISTER
    ADCON0  = %00000000 'A/D CONTROL REGISTER 0
    ADCON1  = %00000000 'A/D CONTROL REGISTER 1
    ADCON2  = %00000000 'A/D CONTROL REGISTER 2
    INTCON  = %00000000 'INT CTRL REG
    INTCON2 = %00000000 'INT CTRL REG 2
    INTCON3 = %00000000 'INT CTRL REG 3
    PORTA   = %00000000 'State High (1) or Low (0)
    TRISA   = %00000000 'Data Direction Control Register (Input/Output)
    PORTB   = %00000000 'State High (1) or Low (0)
    TRISB   = %00010000 'Data Direction Control Register (Input/Output)
    Define OSC 8            ' Oscillator speed in MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40
    DEFINE HSER_CLROERR 1   ' Clear overflow automatically
    DEFINE NO_CLRWDT 1      ' Don't waste cycles clearing WDT
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 1
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUGIN_BIT 4
    DEFINE DEBUGIN_MODE 0
    SData   VAR BYTE(5)
    TimeOut CON 100
    MAIN:
        ' Send some serial data with ID as header from Serial Comm Terminal
        DEBUGIN TimeOut,MAIN,[WAIT("ID"),str SData\5]
        ' Display received data
        DEBUG str SData\5 ,13
        GOTO MAIN
    Roger
    Default Re: 18F1220 - DEBUGIN not working
    The pin you're trying to use is configured for analog input.
    Hi Henrik,
    Obviously, the beam was far too big for my little eye!
    Thanks a lot
    Roger
  1. 18F1220 newbie
    By Hebemabo in forum mel PIC BASIC Pro
    Last Post: - 25th July 2014, 16:43
  2. 18F1220 A/D Converter
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 31st May 2011, 16:50
  3. 18F1220 fuse help
    By mr.sneezy in forum General
    Last Post: - 24th May 2010, 14:54
  4. DEBUGIN not working on 12F629
    By fredpret in forum Serial
    Last Post: - 22nd September 2007, 11:39
  5. Sleep command with 18F1220
    By suded in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 11:11
