Logical AND/OR/ Sequencing question
Results 1 to 11 of 11
    Default Logical AND/OR/ Sequencing question
    Hello.
    Say here is a logical structure like this
    IF A=1 AND B<6 OR A=2 THEN
    The first part is clear, if a=1 and b is less than 6, then do something
    but what about OR?
    when I add that OR A=2 this means B still should be less than 6, or that part is ignored and only A=2 is checked?
    Default Re: Logical AND/OR/ Sequencing question
    AND, OR, XOR, ANDNOT, ORNOT, XORNOT all have the same precedence and so are evaluated from left to right. But, as the manual says:
    Left-to-right is, in our opinion, unacceptable as a method of specifying the order of
    evaluation. USE PARENTHESES to avoid ambiguity!
    IF (A=1 AND B<6) OR (A=2) THEN makes it much clearer.
    OT
    Have you got your HTC dot matrix ? on your other posting http://www.picbasic.co.uk/forum/show...445#post146445
    Nope, it is still on the way, will get it in week or so.
    So my question will be split into things like
    IF A=1 AND B<6
    OR B<6 AND A=2
    I want to make it such way, than if A=2, then it would not care about whenever B is less than 6 or not.
    Have you TRIED it? Sometimes simply trying a few things out on your own gives you the answer much faster than asking here.
       LED = 1
    Whenever A = 2 LED will turn on.
    If A = 1 then B must also be <6 for LED to turn on.
    Ugly and verbose but likely smaller:
    IF A = 2 THEN LED = 1
    IF (A = 1) AND (B < 6) THEN LED = 1
    OK
    Also, when using IF statements, it will probably take fewer lines of ASM code to execute if you put the clause most likely to give you a "yes", or the easiest to check first. IF (A = 2)... is the easiest to check so I'd put it first.
  1. Ports don't stay on when sequencing them.
    By cnc002 in forum FAQ - Frequently Asked Questions
    Last Post: - 5th August 2017, 16:08
  2. Logical vs Bitwise ==
    By Archangel in forum General
    Last Post: - 19th February 2010, 06:22
  3. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 10:14
  4. Logical Operators
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 1st May 2008, 20:55
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 07:35
