Change variable increment/decrement into mid-loop?
Results 1 to 5 of 5
    Default Re: Change variable increment/decrement into mid-loop?
    And yes, CNT=1 should be added in the beginning, or absolutely unexpected behavior will be generated (just tested)
    Regarding negative numbers, as long as both variables are of the same size what you did will work:
    Cnt VAR BYTE
    Add VAR BYTE
    Cnt = 100
    Add = -1
    Cnt = Cnt + Add   ' Cnt now = 99
    But if Cnt was a WORD and Add a BYTE then Cnt woul equal 354.
  1. Replies: 27
    Last Post: - 9th April 2015, 05:51
  2. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2013, 00:05
  3. Altering a variable in a loop.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 18th September 2012, 07:24
  4. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 08:00
  5. Let a variable change from bin to dec.
    By Roy in forum mel PIC BASIC Pro
    Last Post: - 25th May 2004, 20:57
