DEFINE RESET_ORG and DEC modifier issue
Results 1 to 26 of 26
    Sep 2009
    Default Re: DEFINE RESET_ORG and DEC modifier issue
    Look at this
    http://www.picbasic.co.uk/forum/showthread.php?t=137
    Store raw data in FLASH. Terminate your string with 0.
    Use readcode to read data, send one byte at time, and that is it.
    So you can store 300 bytes in 300 bytes. Readcode take little space.
    EDIT:
    Another way is to store strings to EEPROM. So no code space is used.
    http://www.picbasic.co.uk/forum/showthread.php?t=573
    please explain how would you do. Of course debug strings are different and mixed
    a message database of null terminated strings
    @ ORG 4000h
    @ dw 0x08   ;message 0 offset
    @ dw 0x12   ;message 1 offset
    @ dw 0x22   ;message 2 offset
    @ dw 0x2e   ;message 3 offset
    @ DB        "a message",0
    @ DB	"another message",0
    @ DB	"and another",0
    @ DB	"last one",0
    to find a message[x] read from messages + 2*x this is the offset from messages label
    message[x] start address = messages + offset
    you can then copy message to a buffer and hserout it the usual way or create your own routine to
    stream the message directly from flash
    edited lst file
    004000        00839  ORG 4000h
    004000 0008           00847  dw 0x08
    004002 0012           00855  dw 0x12
    004004 0022           00863  dw 0x22
    004006 0032           00871  dw 0x2E
    004008 2061 656D 7373 00879  DB    "a message",0
        6761 0065
    004012 6E61 746F 6568 00887  DB     "another message",0
        2072 656D 7373
        6761 0065
    004022 6E61 2064 6E61 00895  DB     "and another",0
        746F 6568 0072
    00402E 616C 7473 6F20 00903  DB     "last one",0
        656E 0000
    Italy
    Clear, thanks both. I've used something like that in the past when I needed a bunch of kbytes more to fit a program in memory.
    But as I told debug strings are mostly mixed test+variables and become very difficult to manage this stuff, for example
    Hserout2["logging ",DEC ByteCount," chars at @",HEX4 BaseAddress,"-Type ",HEX2 DataType,"-Data ",str inbuff\ByteCount*2,"-",HEX2 DataCrc,"                        "]
    But some messages are all plain text, so I will consider to mix the two method
    cheers
  1. Arrayread and DEC modifier issue
    By Marcick in forum mel PIC BASIC Pro
    Last Post: - 26th January 2021, 08:35
  2. Indexing DEC modifier
    Last Post: - 13th December 2015, 23:12
  3. reset_org with 16f193X ?
    By kik1kou in forum mel PIC BASIC Pro
    Last Post: - 9th October 2011, 09:32
  4. LCDout $FE,2, dec Days - What is dec ?
    By merc07 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2009, 05:03
  5. 12F675: DEC modifier not accepted
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 03:39
