Logical AND/OR/ Sequencing question
Results 1 to 11 of 11
    Default Logical AND/OR/ Sequencing question
    Hello.
    Say here is a logical structure like this
    IF A=1 AND B<6 OR A=2 THEN
    The first part is clear, if a=1 and b is less than 6, then do something
    but what about OR?
    when I add that OR A=2 this means B still should be less than 6, or that part is ignored and only A=2 is checked?
    Default Re: Logical AND/OR/ Sequencing question
    AND, OR, XOR, ANDNOT, ORNOT, XORNOT all have the same precedence and so are evaluated from left to right. But, as the manual says:
    Left-to-right is, in our opinion, unacceptable as a method of specifying the order of
    evaluation. USE PARENTHESES to avoid ambiguity!
    IF (A=1 AND B<6) OR (A=2) THEN makes it much clearer.
    OT
    Have you got your HTC dot matrix ? on your other posting http://www.picbasic.co.uk/forum/show...445#post146445
    Nope, it is still on the way, will get it in week or so.
    So my question will be split into things like
    IF A=1 AND B<6
    OR B<6 AND A=2
    I want to make it such way, than if A=2, then it would not care about whenever B is less than 6 or not.
    Have you TRIED it? Sometimes simply trying a few things out on your own gives you the answer much faster than asking here.
       LED = 1
    Whenever A = 2 LED will turn on.
    If A = 1 then B must also be <6 for LED to turn on.
    Ugly and verbose but likely smaller:
    IF A = 2 THEN LED = 1
    IF (A = 1) AND (B < 6) THEN LED = 1
    OK
    Also, when using IF statements, it will probably take fewer lines of ASM code to execute if you put the clause most likely to give you a "yes", or the easiest to check first. IF (A = 2)... is the easiest to check so I'd put it first.
    Well as I've said previously, sometimes I have no access to machine where PBP is installed. I tried to get a student license for my laptop, but it never works.
    So sometimes, I write code on the road, in the notepad, which obviously, can't run PBP, so this is why I'm asking here.
    The gold and silver editions allows you to install and activate PBP on up to 3 machines, do you have that many and still need that extra laptop?
    Why not simply:
    IF (A=2) THEN
    IF (A=1) AND (B<6) THEN
    IF (B<6) AND (A=2) THEN
    It is not my computer where PBP is installed, it belongs to company, so have no idea where any other remaining copies are installed or whatsoever. Regarding my laptop, it is not actually a laptop, but a Surface Pro 5, a tablet which works as a nice laptop, is super lightweight and portable. I was thinking about getting the silver version, but as I've stated in feature requests, I'd like to have say some "core package" for some relatively low price, say $29.99 and ability to add extra MCU support on paid basis - I will never use 99% of currently supported MCUs, so paying for thing that you're not going to use....
  1. Ports don't stay on when sequencing them.
    By cnc002 in forum FAQ - Frequently Asked Questions
    Last Post: - 5th August 2017, 17:08
  2. Logical vs Bitwise ==
    By Archangel in forum General
    Last Post: - 19th February 2010, 07:22
  3. Understanding 3 phase sequencing
    By ardhuru in forum General
    Last Post: - 22nd June 2008, 11:14
  4. Logical Operators
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 1st May 2008, 21:55
  5. 3 phase sequencing
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 26th May 2007, 08:35
