16F877a ASM Interrupt Confused
Results 1 to 8 of 8
    Apr 2005
    Question 16F877a ASM Interrupt Confused
    I've been trying to get a handle on how to write an assembly interrupt, but I feel like I am missing something simple.
    The example given in the Pic Basic Pro manual makes sense, but I'm not sure exactly what to do since the 877a has 4 banks of RAM. I realize I need to save the W and Status register and that I am supposed to reserve a system variable in each bank similar to the following:
    	wsave  var	byte $20 system
    	wsave1 var	byte $a0 system   ' If device has RAM in bank1
    	wsave2 var	byte $120 system	' If device has RAM in bank2
    	wsave3 var	byte $1a0 system	' If device has RAM in bank3
    The following is the example given in the PBP manual, but it appears it is an example for a chip with a single bank of RAM. How do I convert the following code so it will work on the 877a and save "wsave1" and "wsave2" etc when needed?
    	' Assembly language interrupt example
    	led	 var	PORTB.1
    	ssave var	byte bank0 system
    	psave var	byte bank0 system
    	Goto start	' Skip around interrupt handler
    	' Define interrupt handler
    	define INTHAND myint
    	' Assembly language interrupt handler
    	asm
    	; Save W, STATUS and PCLATH registers
    	myint	movwf	wsave
    		swapf	STATUS, W
    		clrf	STATUS
    		movwf	ssave
    		movf	PCLATH, W
    		movwf	psave
    	; Insert interrupt code here
    	; Save and restore FSR if used
    		bsf	_led	; Turn on LED (for example)
    	; Restore PCLATH, STATUS and W registers
    		movf	psave, W
    		movwf	PCLATH
    		swapf	ssave, W
    		movwf	STATUS
    		swapf	wsave, F
    		swapf	wsave, W
    		retfie
    	endasm
    	' PICBASIC PRO™ program starts here
    	start: Low led	' Turn LED off
    	' Enable interrupt on PORTB.0
    		INTCON = %10010000
    	loop:	Goto loop	' Wait here till interrupted
    Thanks in advance for any help
    Last edited by Darrel Taylor; - 19th September 2005 at 03:30. Reason: added [code][/code] tags
    Each PIC datasheet explain black on white how to save the context variable.
    PIC16F877a section 14.12
    For a 16F877A, and for many others, it's very simple.
    Just change the $20 to $70.
    There is a small amount of ram space that is common between all BANKS.   It ranges from $70 to $7F.   Any one of those locations can be used.
    That way you don't need the wsave1 - wsave3 stuff
    Apr 2005
    Here is the code example from the 877a data sheet:
    MOVWF W_TEMP ;Copy W to TEMP register
    SWAPF STATUS,W ;Swap status to be saved into W
    CLRF STATUS ;bank 0, regardless of current bank, Clears IRP,RP1,RP0
    MOVWF STATUS_TEMP ;Save status to bank zero STATUS_TEMP register
    MOVF PCLATH, W ;Only required if using pages 1, 2 and/or 3
    MOVWF PCLATH_TEMP ;Save PCLATH into W
    CLRF PCLATH ;Page zero, regardless of current page
    :(ISR) ;(Insert user code here)
    MOVF PCLATH_TEMP, W ;Restore PCLATH
    MOVWF PCLATH ;Move W into PCLATH
    SWAPF STATUS_TEMP,W ;Swap STATUS_TEMP register into W
    ;(sets bank to original state)
    MOVWF STATUS ;Move W into STATUS register
    SWAPF W_TEMP,F ;Swap W_TEMP
    SWAPF W_TEMP,W ;Swap W_TEMP into W
    I guess my question is if I define the following variables at the begining of my PBP code:
    	w_temp  var	byte $20 system
    	w_temp1 var	byte $a0 system   ' If device has RAM in bank1
    	w_temp2 var	byte $120 system	' If device has RAM in bank2
    	w_temp3 var	byte $1a0 system	' If device has RAM in bank3
    how do I tell if I am in bank 0,1,2,or 3 when the interrupt occurs, so I know what w_temp variable(0,1,2, or3) to save using the following assembly code?
    Thanks again
    Apr 2005
    Thanks Darrel, I will give that a shot. I am still interested how to make the wsave1,2,3 stuff work tho.
    Ok, easy to explain.
    When a particular bank is selected with the RP0 and RP1 bits in the STATUS register, any opcode trying to access that bank is limited to 128 bytes. So, $20, $A0, $120 and $1A0 all point to a location that is 32 bytes into their respective BANK. &nbsp; The Variable declarations wsave1-3 are set that way to reserve the same locations in each bank.
    That way you don't need to worry which bank you are in. The "MOVWF W_TEMP" always puts the byte in the correct location, no matter which bank is selected.
    Then, notice that the STATUS register is restored prior to restoring the W register. That way you always have the same bank selected that was used to save the W reg. to begin with.
    HTH,
    &nbsp;&nbsp;&nbsp;Darrel
    Apr 2005
    So even tho I may be in bank 2 the "MOVWF W_TEMP" command will save to W_Temp2 in this case automatically?
  1. Can't ID interrupt source with this IntHandler??
  2. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
