Here is test code - it just counts 0 - 9 in clock type format wth colon between 2nd and 3rd digit.
eg 55:55 66:66 etc
I have ordered a display module from Ebay - so will see if current code works. Delivery probably a few weeks though.
'*  Name    : 0832test.bas                                      *
'*  Author  : aerostar                                          *
'*  Notice  : Copyright (c) 2021 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 04/01/2021                                        *
'Sure electronics module 0832 led matrix
'connect RD on module to +5v
'connect OSC on module to GND
            'displays XX:XX  COUNTING 0 TO 9
         DEFINE OSC 20
@ device PIC16F628A,HS_OSC,BOD_ON,MCLR_ON
TRISA = 0
TRISB = 0
               'change your ports to suit
CS var PORTB.7		'Connect this to CS1 (set dip switchs to 1 = on 2/3/4 = off)
WR var PORTA.4		'connect this to wr ACTUALLY CLOCK BUT HOLTEK CALL IT WR
DATALINE var PORTA.1	'connect this to DATA
ALOOP    VAR BYTE
COUNTER	var	byte
ADDRESS	var	byte
COMD	var	byte
ENDBIT	var	bit
CHARACTERS	var	byte [5]
SENDDOTS	var	byte
NUMBER VAR BYTE
' NUMBERS 0 TO 9  COLUMNS
data @0, %00000000,%01111100,%10001010,%10010010,%10100010,%01111100,%00000000,%00000000
data @8, %00000000,%00100010,%01000010,%11111110,%00000010,%00000010,%00000000,%00000000
DATA @16,%00000000,%01000010,%10000110,%10001010,%10010010,%01100010,%00000000,%00000000
DATA @24,%00000000,%10000100,%10000010,%10100010,%10110010,%11001100,%00000000,%00000000
DATA @32,%00000000,%00011000,%00101000,%01001000,%11111110,%00001000,%00000000,%00000000
DATA @40,%00000000,%11110100,%10100010,%10100010,%10100010,%10011100,%00000000,%00000000
DATA @48,%00000000,%01111100,%10010010,%10010010,%10010010,%01001100,%00000000,%00000000
DATA @56,%00000000,%10000110,%10001000,%10010000,%10100000,%11000000,%00000000,%00000000
DATA @64,%00000000,%01101100,%10010010,%10010010,%10010010,%01101100,%00000000,%00000000
DATA @72,%00000000,%01100100,%10010010,%10010010,%10010010,%01111100,%00000000,%00000000
CLEAR
 CMCON=7
PAUSE 500
'---------------- SENDS COMMANDS-------------------------------------
COMD = %00000100	'Comand mode
ADDRESS = %00000001	'osc on
GOSUB COMANDSEND
ADDRESS = %00000011	'led on
GOSUB comandsend
ADDRESS = %10101111	'pwm 16/16
GOSUB comandsend
ADDRESS = %00011000	'RC int clk sourse on
GOSUB comandsend
'---------- SENDS IMAGE DATA TO DISPLAY-----------------------------
COMD = %00000101	'Data Mode
NUMBER=0             'SET NUMBER TO 0
SHOWNUMBERS:
    ADDRESS = 0      'DIG 1 0, DIG2 16, DIG3 32, DIG4 48
    FOR ALOOP =0 TO 3     ' 4 DIGITS
    FOR COUNTER = 0 TO 7    ' NUMBER OF COLUMNS  PER DIGIT
    read (NUMBER*8)+COUNTER,SENDDOTS
    IF ALOOP=1 AND COUNTER = 7 THEN
    SENDDOTS=%00101000 'COLON IN COLUMN 7
 	GOSUB DATASEND
	ADDRESS = ADDRESS + 2     ' ADRESS INCREMENTS BY 2 EACH COLUMN
    NEXT COUNTER
    NEXT
    PAUSE   1000
    NUMBER=NUMBER+1
    IF NUMBER =10 THEN
    NUMBER=0
    GOTO SHOWNUMBERS
'----------------- sends infomation to display ----------------------
DATASEND:
	LOW CS
	SHIFTOUT DATALINE,wr,1,[COMD\3]		'send lower 3 bits of COMD byte
	SHIFTOUT DATALINE,wr,1,[ADDRESS\7]	'send lower 7 bits of adress byte
	SHIFTOUT DATALINE,wr,1,[SENDDOTS]		'send led data
	HIGH CS
COMANDSEND:
	LOW CS
	SHIFTOUT DATALINE,wr,1,[ADDRESS]	'send command byte
	SHIFTOUT DATALINE,wr,1,[ENDBIT\1]	'send 1 ENDBIT
	HIGH CS
