Yes there is file. You can edit it. There is example on forum cale LCD-AnyPIn, or something like that. But always have backup if you edit it.
You can find it in few places.
in PBP3 instalation folder there is few files .lib.
eg
pbppi14e.lib
Files correspond to PIC family.
For LCD look in that file for
everything between is LCD initialization.Code:btfsc LCDINITFLAG ; Has lcd been inititalized? goto lcdout1 ; Yes movlw 15100 >> 8 ; Wait at least 15ms movwf R0 + 1 movlw low 15100 call PAUSEUSL movlw 33h ; Init lcd movwf R3 ; Save char call lcdloop ; Send init movlw 4200 >> 8 ; Wait at least 4.1ms movwf R0 + 1 movlw low 4200 call PAUSEUSL call lcdloop ; Send init (33) again movlw 100 ; Wait at least 100us call PAUSEUS call lcdloop ; Send init (33) one more time if ((LCD_BITS) == 8) if ((LCD_LINES) == 1) movlw 30h ; 8-bit mode, 1 line, 5x7 font else movlw 38h ; 8-bit mode, 2+ lines, 5x7 font endif else movlw 22h ; Send init to 4-bit mode movwf R3 ; Save character call lcdloop ; Set interface to 4-bit mode if ((LCD_LINES) == 1) movlw 20h ; 4-bit mode, 1 line, 5x7 font else movlw 28h ; 4-bit mode, 2+ lines, 5x7 font endif endif call lcdoutcom ; Send function set movlw 0ch ; Display on, no cursor, no blink call lcdoutcom movlw 01h ; Display clear call lcdoutcom movlw 06h ; Lcd entry mode set, increment, no shift call lcdoutcom bsf LCDINITFLAG ; Set to initialized movf R3 + 1, W ; Get saved char back (again) goto lcdout1 lcdoutcom bsf LCDCDFLAG ; Set for command
In .lib files, there is bunch stuff that is optionally compiled. If you want to see just stuff that your code uses(there are again some optionally parts included) look for file .LST in your project folder.
And also search for same stuff as in lib. And you will se what PBP is doing in background.
