Make PIC simulate binary up/down counter - how to calculate how fast can it count?
Results 1 to 7 of 7
    Jan 2007
    Default Make PIC simulate binary up/down counter - how to calculate how fast can it count?
    Hello All,
    I have a theoretical question about guesstimating how fast an input signal a PIC can track.
    I'd like to experiment with an 18pin PIC - such as the PIC6F627A
    I'd like to simulate a binary up/down counter
    But this counter will keep track of degrees - with a max value of 359
    Which means it needs to role over when > 359 and role over when < 0
    The input signal to track will be a standard A/B encoder signal requiring 2 input pins.
    The output will be PORTB's 8 pins, and one pin from PORTA to function as 9th bit.
    9 bits can hold our expected values.
    The PIC will be running with internal oscillator at 4mhz
    Is there a way I can guesstimate how fast an encoder pulse the PIC will be able to accurately track?
    Thanks in advance! :-]
    dw
    A description of the process follows:
    PORTA will have 2 input pins with alias names = Pin_A, Pin_B
    PORTA will have 1 output pin with alias name = bit9
    PORTB will have 8 output pins
    'Here we remain in a loop until Pin_A clock input goes high
    while pin_A = 0
    wend
    'We are now here because pin_A clock input went high starting a clock cycle
    if pin_B = 1 then counter = counter + 1
    if pin_B = 0 then counter = counter - 1
    if counter > 359 then counter = counter - 360
    if counter < 0 then counter = counter + 360
    if counter > 255 then HIGH bit9 else LOW bit9
    PORTB = counter && 255
    'We now wait for pin_A clock input to go LOW
    'In order to be ready for its next clock cycle
    while pin_A = 1
    wend
    'we are now here because pin_A has gone LOW and is now ready for its next cycle
    'Start over and get pin_A next clock cycle
    Default Re: Make PIC simulate binary up/down counter - how to calculate how fast can it count
    some thoughts, in my experience decoding quadrature signals that way usually miscounts when small back forward movements and or freq direction
    changes occur. plus you only get a quarter of the possible resolution , edge detection on both channels is a better method
    i might add your method will be intolerant to any noise [contact bounce] too
    you could try these ideas and maybe tweak a little more speed.
    PORTB = counter && 255 is not really correct , && is a logical AND you need a BITWISE AND
    PORTB = counter & 255
    or
    PORTB = counter.lowbyte
    or since its an 8bit chip
    PORTB = counter , would do but may get a warning about low byte value being used
    since the count can only inc/dec by 1 count you can simplify to this
    if counter.15 then counter = 359
    if counter > 359 then counter = 0
    bit9 can be simplified to this
    bit9=counter.8
    making
    bit9=counter.8
    Jan 2007
    Thank you Richard,
    Could you take a moment to describe what happens with edge detection on both channels?
    Sincere thanks!
    dw
    every edge [transition] is a decodable step for the encoder
    you catch each step with an edge triggered pin interrupt, you need a better chip , 16f1825 or something useful
    We had a similar discussion not that long ago, might be worth revisiting.
    It's important to remember that one usually want to do more than JUST keep track of an enocder and that has to be accounted for. Anyway, here's a link to that thread: http://www.picbasic.co.uk/forum/show...ght=quadrature
    Jan 2007
    Thank you Hendrik.
    That gave me a lot to think about.
    One of the examples in that thread has the pic checking for 4 possible conditions of two bits, and remembering the last condition of those two bits.
    With my experiments so far - I haven't found that to be necessary in order to maintain accuracy.
    I have a pic that simulates the output of an encoder, starting with pulse periods of 15ms.
    It produces 180 cycles in the CW direction - then pauses - and then produces 180 cycles in the CCW direction.
    After each CW/CCW process - it starts over - but with a little shorter pulse period.
    I then monitor my programs decoder output on an LCD display.
    If all goes well - it starts at 0 - goes to 180 counts and then returns to 0.
    I know when the processor is starting to loose track when the LCD displays bad numbers.
    So far I've been able to accurately track pulse periods down to 5milli-seconds.
    That may in fact be satisfactory for my usage - but I'm still playing with other options.
    Jan 2007
    Richard - thank you for pointing me to that PIC!!!
    I was going to ask about newer PICs with internal OSC running at higher speeds
    But I hadn't even imagined one running at 32Mhz
    Very sweet!!
    And thank you for the emphasizing catching each edge with an ONCHANGE interrupt.
    I'll be doing some further research on that - especially with a faster device!
    Sincere thanks :-]
  1. Replies: 7
    Last Post: - 19th December 2016, 18:19
  2. Use a PIC ADC like a fast interrupt comparator?
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 06:33
  3. Fast yet reliable PIC-PIC communication?
    Last Post: - 27th September 2009, 16:34
  4. How to calculate PIC sampling frequency
    By minmin in forum General
    Last Post: - 26th September 2006, 19:02
  5. Simulate a mouse with a PIC
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2006, 01:13
