16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Byte...word ???
    Sorry to ask again Richard, but I really don't understand this "WORD" story. I'm french speaking so I may not fully understand your explanation
    In "i2cwrite sda,sck,$aa,$38,[1,30,52]", $AA (=EeCtrl) and $38 (=EeAddress) have BYTE sizes, no?
    Do you mean the I2C command will transform the two BYTE variables in one WORD sized one?
    Roger
    Default Re: 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    the control word to address an individual memory cell is 16 bits long for that eeprom
    made up as ->
    $a0 + block <<1 + r/rw [0 for pbp] + eeaddress [0-255]
    for example block=5,cell 0x38
    0xA0 + 5<<1 + 0 = 0xAA , high byte of word
    address=0x38 ,
    low byte of word
    this word is transmitted as two bytes, big end first ,
    other eeproms have other schemes where cell address is a word and the device control address byte is a constant
    based on address pins plus device code.
    address =0x538
    i2cwrite sda,sck,$a0,address,[1,30,52]
    no , the eeprom will interpret the two bytes as a 16 bit value
    Default Working fine after chip replacement
    Thanks a lot for your patience and clear explanation
    BTW, I changed my chip...and all is working fine now.
    I've put my last working test program in attachment.
    Roger
  1. 16F690 read/write
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 17th December 2016, 10:21
  2. Save some bytes in program memory
    By Ioannis in forum Code Examples
    Last Post: - 10th February 2012, 17:17
  3. How to Read / Write I2c 24LC16B EEprom
    By odie52 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2010, 04:00
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 12:46
