16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
Results 1 to 11 of 11
    Default Re: 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    To be honnest, I don't get that thing with the WORD sized address...
    it's constructed as i stated and sent via i2cwrite as to single bytes ,big end first
    SWITZERLAND (french speaking)
    Default Byte...word ???
    Sorry to ask again Richard, but I really don't understand this "WORD" story. I'm french speaking so I may not fully understand your explanation
    In "i2cwrite sda,sck,$aa,$38,[1,30,52]", $AA (=EeCtrl) and $38 (=EeAddress) have BYTE sizes, no?
    Do you mean the I2C command will transform the two BYTE variables in one WORD sized one?
    Roger
    the control word to address an individual memory cell is 16 bits long for that eeprom
    made up as ->
    $a0 + block <<1 + r/rw [0 for pbp] + eeaddress [0-255]
    for example block=5,cell 0x38
    0xA0 + 5<<1 + 0 = 0xAA , high byte of word
    address=0x38 ,
    low byte of word
    this word is transmitted as two bytes, big end first ,
    other eeproms have other schemes where cell address is a word and the device control address byte is a constant
    based on address pins plus device code.
    address =0x538
    i2cwrite sda,sck,$a0,address,[1,30,52]
    no , the eeprom will interpret the two bytes as a 16 bit value
    Default Working fine after chip replacement
    Thanks a lot for your patience and clear explanation
    BTW, I changed my chip...and all is working fine now.
    I've put my last working test program in attachment.
    Roger
  1. 16F690 read/write
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 17th December 2016, 10:21
  2. Save some bytes in program memory
    By Ioannis in forum Code Examples
    Last Post: - 10th February 2012, 17:17
  3. How to Read / Write I2c 24LC16B EEprom
    By odie52 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2010, 04:00
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 12:46
