16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
Results 1 to 11 of 11
    Default Re: 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    try
    ' VARIANT 5 - WRITE 8 different bytes to memory
    EeWP = 0
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[1]
    EeAddress=EeAddress+1
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[2]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[3]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[4]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[5]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[6]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[7]
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[8]
    PAUSE 10
    EeWP = 1
    or just
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[1,2,3................] ;within block boundary
    SWITZERLAND (french speaking)
    Thanks Richard,
    I already corrected the address incrementing and also forgot to mention I already tried the ..[1,2,3,..] variant too.
    All without any success...
    See the results in two different memory locations (45 and 0)...
    >>> Variant 5
    >>> Variant 6
    '======= FUSES ====================================================================================
    ' PIC 16F690 Fuses (MPASM)
    ' Internal oscillator
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    @ ERRORLEVEL -306
    '======= REGISTERS =================================================================================
    ' Registers   76543210
    OPTION_REG = %10000000 ' Pull-Ups disabled
    OSCCON     = %01110000 ' Internal oscillator
    ANSEL      = %00000000 ' analog inputs Channels 0 to 7
    ANSELH     = %00000000 ' analog inputs Channels 8 to 11
    WPUA       = %00000000 ' weak pull-ups
    WPUB       = %00000000 ' weak pull-ups
    ADCON0     = %00000000 ' Select the VP6 channel as ADC input bits5:2 (xx1101xx)
    ADCON1     = %00000000 ' Set FRC
    VRCON      = %00000000 ' VP6 reference
    CM1CON0    = %00000000 ' Comparator1 Module
    CM2CON0    = %00000000 ' Comparator2 Module
    TRISA      = %00000000 ' Input/Output (0 to 5)
    PORTA      = %00000100 ' High/Low (0 to 5)
    TRISB      = %00000000 ' Input/Output (4 to 7)
    PORTB      = %00000000 ' High/Low (4 to 7)
    TRISC      = %00000000 ' Input/Output (0 to 7)
    PORTC      = %01000000 ' High/Low (0 to 7)
    '======= DEFINES ==================================================================================
    DEFINE OSC 8
    DEFINE NO_CLRWDT 1    ' Don't waste cycles clearing WDT
    '======= VARIABLES ================================================================================
    Ser_Out     VAR PORTA.2 ' Serial Out
    EeWP        VAR PORTC.3 ' memory Write Protect
    SCL         VAR PORTC.6 ' i2c Clock pin [6]
    SDA         VAR PORTC.7 ' i2c Data pin  [5]
    Cntr        VAR BYTE    ' just a counter
    Ser_Mode    VAR word    ' serial com baudrate
    Mem_Loc     var BYTE    ' holds the user's code memory place (000..255)
    Temp        VAR WORD    ' for WORD sized calculation
    EeVal       VAR BYTE(8) ' array that holds the numbers in the Eeprom
    EeCtrl      var BYTE    ' 4 control bits + 3 memory block selector bits
    EeAddress   var BYTE    ' 24LC16B address (0..255)
    EeBlock     var BYTE    ' holds memory block number (0..7)
    '======= INITIALIZE ===============================================================================
    Cntr      = 0
    Ser_Mode  = 84 ' 9600bps
    Mem_loc   = 0
    Temp      = 0
    EeCtrl    = 0
    EeAddress = 0
    EeBlock   = 0
    For Cntr = 0 to 7
        EeVal(Cntr) = Cntr ' initialize EeVal
    NEXT
    HIGH Ser_Out        ' avoid serial data garbage @ startup
    '======= TEST =====================================================================================
    Mem_loc = 45 ' put here an address between 0..255 to write the data to
    '======= PROGRAM ==================================================================================
    MAIN:
        ' Calculate control byte
        Temp     = Mem_loc * 8     ' 24LC16B's starting memory position
        EeBlock   = Temp /  256    ' 24LC16B's 0..7 memory block number
        EeAddress = Temp // 256    ' 24LC16B's 0..255 memory position
        ' Get the control byte according to block     [ 0..2047]  [0..255]
        IF Eeblock = 0 THEN EeCtrl = $A0 '                0..255     0..31
        IF Eeblock = 1 THEN EeCtrl = $A2 '              256..511    32..63
        IF Eeblock = 2 THEN EeCtrl = $A4 '              512..767    64..95
        IF Eeblock = 3 THEN EeCtrl = $A6 '             768..1023   96..127
        IF Eeblock = 4 THEN EeCtrl = $A8 '            1024..1279  128..159
        IF Eeblock = 5 THEN EeCtrl = $AA '            1280..1535  160..191
        IF Eeblock = 6 THEN EeCtrl = $AC '            1536..1791  192..223
        IF Eeblock = 7 THEN EeCtrl = $AE '            1792..2047  224..255
        ' Show the input I'm using for this test
        SEROUT2 Ser_Out, Ser_Mode,["Mem_Loc  : ",DEC Mem_Loc,10,"EeBlock  : ",_
            DEC3 EeBlock,10,"EeAddress: ",DEC3 EeAddress,10,"CTRL     : ",BIN EeCtrl,13,10]
    ' VARIANT 1 - WRITE 8 same bytes to memory = works
    'EeWP = 0
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[33]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    '' VARIANT 2 - WRITE 8 different bytes to memory = not working
    'EeWP = 0   ' Unprotect memory
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[Cntr]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    '' VARIANT 3 - WRITE 8 different bytes to memory = not working
    'EeWP = 0
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[EeVal(0),EeVal(1),EeVal(2),EeVal(3),_
    '    EeVal(4),EeVal(5),EeVal(6),EeVal(7)]
    'EeWP = 1
    '' VARIANT 4 - WRITE 8 different bytes to memory = not working
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[EeVal(Cntr)]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    '' VARIANT 5 - WRITE 8 different bytes to memory = not working
    'EeWP = 0
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[1]
    'EeAddress=EeAddress+1
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[2]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[3]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[4]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[5]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[6]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[7]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[8]
    'PAUSE 10
    'EeWP = 1
    ' VARIANT 6 - WRITE 8 different bytes to memory = not working
    EeWP = 0
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[1,2,3,4,5,6,7,8]
    EeWP = 1
        ' READ 8 bytes from memory
        For Cntr = 0 to 7
            i2cread SDA,SCL,EeCtrl,EeAddress,[EeVal(Cntr)]
        NEXT Cntr
        ' display what's in the memory chip
        SEROUT2 Ser_Out, Ser_Mode,[DEC3 EeVal(0)," ",DEC3 EeVal(1)," ",DEC3 EeVal(2)," ",_
            DEC3 EeVal(3)," ",DEC3 EeVal(4)," ",DEC3 EeVal(5)," ",DEC3 EeVal(6)," ",DEC3 EeVal(7),13,10,10]
        ' List all memory locations (0..255)
    '    Mem_Loc = Mem_Loc + 1
    '    IF Mem_Loc = 0 THEN END
    '    GOTO MAIN
    Roger
    keep is simple and clear/concise you need to supply 16 bit address $a0 + block <<1 + r/rw [0 for pbp] + eeaddress [0-255]
    EeWP = 0
    PAUSE 10
    EeCtrl=$a0 + 2 ;using block 1 ie 1<<1=2
    EeWP = 1
    Default 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    This is what I get with your suggestion:
        i2cwrite SDA,SCL,EeCtrl,0,[1,2,3,4,5,6,7,8]
    EeWP = 1
    Name:  2020-12-30 10_32_49-Window.png
    Something is also even more confusing to me. As you wrote, the address has to be WORD sized - this is also stated in the DS.
    In my code, I have it ("EeCtrl") as a BYTE. If I change it to a WORD, it doesn't make any difference.
    Your last suggestion with a WORD sized EeCtrl var gives this result:
    Name:  2020-12-30 10_42_42-Window.png
    Maybe I'm messing things up in the I2CWRITE command because I understand it this way and both vars (EeCtrl and EeAddress) are looking to be BYTE long:
    Name:  2020-12-30 10_52_01-Clipboard.png
    To be honnest, I don't get that thing with the WORD sized address...
    Roger
    the closest eprom i have is a xc24c16 which is pretty similar
    this works for me
        DEFINE OSC 8
     sda var portc.1
      sck var portc.2
              TMP VAR byte[3]
           osccon=$70    '8 mhz
             ansel=0       'dig i/o
             CMCON0=7        ' compare off
             trisa=%001110
             trisc=%111111
             serout2 porta.0,84, ["ready ",13,10]
         i2cwrite  sda,sck,$aa,$38,[1,30,52]
        i2cread sda,sck,$aa,$38,[str tmp \3 ]
         serout2 porta.0,84, ["d " , #tmp[0] ,"," , #tmp[1] ,"," , #tmp[2] ,",",13,10]
       pause 4000
    the closest eprom i have is a xc24c16...
    Thank you very much Richard.
    Unfortunately, even with your code example, it looks hopeless
    I should be able to grab another identical chip (or maybe a 24LC64...) by tomorrow or the day after.
    Roger
  1. 16F690 read/write
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 17th December 2016, 09:21
  2. Save some bytes in program memory
    By Ioannis in forum Code Examples
    Last Post: - 10th February 2012, 16:17
  3. How to Read / Write I2c 24LC16B EEprom
    By odie52 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2010, 03:00
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 11:46
