16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    Hi there,
    I'm having trouble writing 8 bytes to a 24LC16B memory chip.
    In fact, I can write 8 consecutive bytes but it seems only the last byte I want to program is written to all 8 positions.
    Even after reading the DS many times knowing there is something particular when writing less than 16 bytes (...don't still understand everything for sure ), I can't see what am I missing.
    Name:  2020-12-29 21_37_13-Clipboard.png
    Any clue?
    '======= FUSES ====================================================================================
    ' PIC 16F690 Fuses (MPASM)
    ' Internal oscillator
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    @ ERRORLEVEL -306
    '======= REGISTERS =================================================================================
    ' Registers   76543210
    OPTION_REG = %10000000 ' Pull-Ups disabled
    OSCCON     = %01110000 ' Internal oscillator
    ANSEL      = %00000000 ' analog inputs Channels 0 to 7
    ANSELH     = %00000000 ' analog inputs Channels 8 to 11
    WPUA       = %00000000 ' weak pull-ups
    WPUB       = %00000000 ' weak pull-ups
    ADCON0     = %00000000 ' Select the VP6 channel as ADC input bits5:2 (xx1101xx)
    ADCON1     = %00000000 ' Set FRC
    VRCON      = %00000000 ' VP6 reference
    CM1CON0    = %00000000 ' Comparator1 Module
    CM2CON0    = %00000000 ' Comparator2 Module
    TRISA      = %00000000 ' Input/Output (0 to 5)
    PORTA      = %00000100 ' High/Low (0 to 5)
    TRISB      = %00000000 ' Input/Output (4 to 7)
    PORTB      = %00000000 ' High/Low (4 to 7)
    TRISC      = %00000000 ' Input/Output (0 to 7)
    PORTC      = %01000000 ' High/Low (0 to 7)
    '======= DEFINES ==================================================================================
    DEFINE OSC 8
    DEFINE NO_CLRWDT 1    ' Don't waste cycles clearing WDT
    '======= VARIABLES ================================================================================
    Ser_Out     VAR PORTA.2 ' Serial Out
    EeWP        VAR PORTC.3 ' memory Write Protect
    SCL         VAR PORTC.6 ' i2c Clock pin [6]
    SDA         VAR PORTC.7 ' i2c Data pin  [5]
    Cntr        VAR BYTE    ' just a counter
    Ser_Mode    VAR word    ' serial com baudrate
    Mem_Loc     var BYTE    ' holds the user's code memory place (000..255)
    Temp        VAR WORD    ' for WORD sized calculation
    EeVal       VAR BYTE(8) ' array that holds the numbers in the Eeprom
    EeCtrl      var BYTE    ' 4 control bits + 3 memory block selector bits
    EeAddress   var BYTE    ' 24LC16B address (0..255)
    EeBlock     var BYTE    ' holds memory block number (0..7)
    '======= INITIALIZE ===============================================================================
    Cntr      = 0
    Ser_Mode  = 84 ' 9600bps
    Mem_loc   = 0
    Temp      = 0
    EeCtrl    = 0
    EeAddress = 0
    EeBlock   = 0
    For Cntr = 0 to 7
        EeVal(Cntr) = Cntr ' initialize EeVal
    NEXT
    HIGH Ser_Out        ' avoid serial data garbage @ startup
    '======= TEST =====================================================================================
    Mem_loc = 45 ' put here an address between 0..255 to write the data to
    '======= PROGRAM ==================================================================================
    MAIN:
        ' Calculate control byte
        Temp     = Mem_loc * 8     ' 24LC16B's starting memory position
        EeBlock   = Temp /  256    ' 24LC16B's 0..7 memory block number
        EeAddress = Temp // 256    ' 24LC16B's 0..255 memory position
        ' Get the control byte according to block     [ 0..2047]  [0..255]
        IF Eeblock = 0 THEN EeCtrl = $A0 '                0..255     0..31
        IF Eeblock = 1 THEN EeCtrl = $A2 '              256..511    32..63
        IF Eeblock = 2 THEN EeCtrl = $A4 '              512..767    64..95
        IF Eeblock = 3 THEN EeCtrl = $A6 '             768..1023   96..127
        IF Eeblock = 4 THEN EeCtrl = $A8 '            1024..1279  128..159
        IF Eeblock = 5 THEN EeCtrl = $AA '            1280..1535  160..191
        IF Eeblock = 6 THEN EeCtrl = $AC '            1536..1791  192..223
        IF Eeblock = 7 THEN EeCtrl = $AE '            1792..2047  224..255
        ' Show the input I'm using for this test
        SEROUT2 Ser_Out, Ser_Mode,["Mem_Loc  : ",DEC Mem_Loc,10,"EeBlock  : ",_
            DEC3 EeBlock,10,"EeAddress: ",DEC3 EeAddress,10,"CTRL     : ",BIN EeCtrl,13,10]
    ' VARIANT 1 - WRITE 8 same bytes to memory = works but...
    EeWP = 0
    PAUSE 10
    For Cntr = 0 to 7
        i2cwrite SDA,SCL,EeCtrl,EeAddress,[33]
        PAUSE 10
    NEXT Cntr
    EeWP = 1
    '' VARIANT 2 - WRITE 8 different bytes to memory = not working
    'EeWP = 0   ' Unprotect memory
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[Cntr]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    '' VARIANT 3 - WRITE 8 different bytes to memory = not working
    'EeWP = 0
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[EeVal(0),EeVal(1),EeVal(2),EeVal(3),_
    '    EeVal(4),EeVal(5),EeVal(6),EeVal(7)]
    'EeWP = 1
    '' VARIANT 4 - WRITE 8 different bytes to memory = not working
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[EeVal(Cntr)]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    '' VARIANT 5 - WRITE 8 different bytes to memory = not working
    'EeWP = 0
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[1]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[2]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[3]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[4]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[5]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[6]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[7]
    'PAUSE 10
    'i2cwrite SDA,SCL,EeCtrl,EeAddress,[8]
    'PAUSE 10
    'EeWP = 1
        ' READ 8 bytes from memory
        For Cntr = 0 to 7
            i2cread SDA,SCL,EeCtrl,EeAddress,[EeVal(Cntr)]
        NEXT Cntr
        ' display what's in the memory chip
        SEROUT2 Ser_Out, Ser_Mode,[DEC3 EeVal(0)," ",DEC3 EeVal(1)," ",DEC3 EeVal(2)," ",_
            DEC3 EeVal(3)," ",DEC3 EeVal(4)," ",DEC3 EeVal(5)," ",DEC3 EeVal(6)," ",DEC3 EeVal(7),13,10,10]
    Roger
    Default Re: 16F690 and 24LC16B memory - can't WRITE 8 different bytes in a row
    try
    EeWP = 0
    PAUSE 10
    EeAddress=EeAddress+1
    PAUSE 10
    PAUSE 10
    PAUSE 10
    PAUSE 10
    PAUSE 10
    PAUSE 10
    PAUSE 10
    PAUSE 10
    EeWP = 1
    or just
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[1,2,3................] ;within block boundary
    Thanks Richard,
    I already corrected the address incrementing and also forgot to mention I already tried the ..[1,2,3,..] variant too.
    All without any success...
    See the results in two different memory locations (45 and 0)...
    >>> Variant 5
    >>> Variant 6
    @ ERRORLEVEL -306
    DEFINE OSC 8
    Cntr      = 0
    Mem_loc   = 0
    Temp      = 0
    EeCtrl    = 0
    EeAddress = 0
    EeBlock   = 0
    For Cntr = 0 to 7
    NEXT
    MAIN:
    'EeWP = 0
    'PAUSE 10
    'For Cntr = 0 to 7
    '    i2cwrite SDA,SCL,EeCtrl,EeAddress,[33]
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    'PAUSE 10
    'For Cntr = 0 to 7
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    'EeWP = 0
    'PAUSE 10
    'EeWP = 1
    'PAUSE 10
    'For Cntr = 0 to 7
    '    PAUSE 10
    'NEXT Cntr
    'EeWP = 1
    'EeWP = 0
    'PAUSE 10
    'EeAddress=EeAddress+1
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'PAUSE 10
    'EeWP = 1
    ' VARIANT 6 - WRITE 8 different bytes to memory = not working
    EeWP = 0
    PAUSE 10
    i2cwrite SDA,SCL,EeCtrl,EeAddress,[1,2,3,4,5,6,7,8]
    EeWP = 1
        For Cntr = 0 to 7
        NEXT Cntr
        ' List all memory locations (0..255)
    '    Mem_Loc = Mem_Loc + 1
    '    IF Mem_Loc = 0 THEN END
    '    GOTO MAIN
    Roger
    keep is simple and clear/concise you need to supply 16 bit address $a0 + block <<1 + r/rw [0 for pbp] + eeaddress [0-255]
    EeWP = 0
    PAUSE 10
    EeCtrl=$a0 + 2 ;using block 1 ie 1<<1=2
    EeWP = 1
    This is what I get with your suggestion:
        i2cwrite SDA,SCL,EeCtrl,0,[1,2,3,4,5,6,7,8]
    EeWP = 1
    Name:  2020-12-30 10_32_49-Window.png
    Something is also even more confusing to me. As you wrote, the address has to be WORD sized - this is also stated in the DS.
    In my code, I have it ("EeCtrl") as a BYTE. If I change it to a WORD, it doesn't make any difference.
    Your last suggestion with a WORD sized EeCtrl var gives this result:
    Name:  2020-12-30 10_42_42-Window.png
    Maybe I'm messing things up in the I2CWRITE command because I understand it this way and both vars (EeCtrl and EeAddress) are looking to be BYTE long:
    Name:  2020-12-30 10_52_01-Clipboard.png
    To be honnest, I don't get that thing with the WORD sized address...
    Roger
    the closest eprom i have is a xc24c16 which is pretty similar
    this works for me
        DEFINE OSC 8
     sda var portc.1
      sck var portc.2
              TMP VAR byte[3]
           osccon=$70    '8 mhz
             ansel=0       'dig i/o
             CMCON0=7        ' compare off
             trisa=%001110
             trisc=%111111
             serout2 porta.0,84, ["ready ",13,10]
         i2cwrite  sda,sck,$aa,$38,[1,30,52]
        i2cread sda,sck,$aa,$38,[str tmp \3 ]
         serout2 porta.0,84, ["d " , #tmp[0] ,"," , #tmp[1] ,"," , #tmp[2] ,",",13,10]
       pause 4000
    it's constructed as i stated and sent via i2cwrite as to single bytes ,big end first
    the closest eprom i have is a xc24c16...
    Thank you very much Richard.
    Unfortunately, even with your code example, it looks hopeless
    I should be able to grab another identical chip (or maybe a 24LC64...) by tomorrow or the day after.
    Roger
    Default Byte...word ???
    Sorry to ask again Richard, but I really don't understand this "WORD" story. I'm french speaking so I may not fully understand your explanation
    In "i2cwrite sda,sck,$aa,$38,[1,30,52]", $AA (=EeCtrl) and $38 (=EeAddress) have BYTE sizes, no?
    Do you mean the I2C command will transform the two BYTE variables in one WORD sized one?
    Roger
    the control word to address an individual memory cell is 16 bits long for that eeprom
    made up as ->
    for example block=5,cell 0x38
    0xA0 + 5<<1 + 0 = 0xAA , high byte of word
    address=0x38 ,
    low byte of word
    this word is transmitted as two bytes, big end first ,
    other eeproms have other schemes where cell address is a word and the device control address byte is a constant
    based on address pins plus device code.
    address =0x538
    i2cwrite sda,sck,$a0,address,[1,30,52]
    no , the eeprom will interpret the two bytes as a 16 bit value
    Default Working fine after chip replacement
    Thanks a lot for your patience and clear explanation
    BTW, I changed my chip...and all is working fine now.
    I've put my last working test program in attachment.
    Roger
  1. 16F690 read/write
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 17th December 2016, 10:21
  2. Save some bytes in program memory
    By Ioannis in forum Code Examples
    Last Post: - 10th February 2012, 17:17
  3. How to Read / Write I2c 24LC16B EEprom
    By odie52 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2010, 04:00
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 12:46
