Need help with 16F676 button press
Results 1 to 6 of 6
    Jan 2007
    Default Need help with 16F676 button press
    Hello all,
    I've been playing with a clock program.
    The program will display 24hour on line 1 of an 8x2 LCD
    And display 12 hour time on line 2
    This is working fine.
    I now want to add a button which will stall the increment of seconds.
    But for some reason the chip is not responding to the button press.
    Pin 13 RA0 is tied to ground via 10k resistor and pulled to 5+ by the button.
    But the chip is not detecting the button.
    There is an IF statement that looks for 5+ at PORTA.0 pin 13 which calls a subroutine
    I've verified this works by temporarily changing it to look for low state rather than high state.
    And I've verified with a DVM the pin change from 0 to 5+
    And I tempo
    What am I missing?
    ' 16F676 8x2 Clock Program
    ' Clock Displayed on Handtronix LCD
    ' Oscillator = Internal
    ' LCD 4-bit mode.
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    ' Defines necessary for PBP3's built-in LCD functions
    DEFINE LCD_DREG PORTC ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTC ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTA ' Set LCD Enable port
    DEFINE LCD_EBIT 5 ' Set LCD Enable bit - RA5 pin 2
    DEFINE LCD_BITS 4 ' Set LCD 4-bit mode
    DEFINE LCD_LINES 2 ' Set LCD lines
    DEFINE LCD_COMMANDUS 1500 ' Set command delay time in us
    DEFINE LCD_DATAUS 44 ' Set data delay time in us
    ANSEL = 0 ' Disable Analog
    TRISC = 0 ' PortC all output
    TRISA = %00000111 ' RA0,RA1,RA2 (pins 13,12,11) inputs for buttons
    ' RA3,RA4,RA5 (pins 4,3,2) output
    mhr var byte 'Military hour (24hr)
    lhr var byte 'Local hour (12hr)
    mn var byte 'minute
    sc var byte 'second
    mhr = 18
    lhr = 0
    mn = 16
    sc = 0
    clock_pulse var word
    clock_pulse = 1005
    Pause 1000 ' Wait for LCD to startup
    Lcdout $fe, 1 ' Clear LCD screen
    pause 10
    lcdout $fe, $0C ' Turn cursor off
    mainloop:
    lcdout $FE, $80 'Cursor at First Line
    lcdout " " 'clear line 1
    ' FIRST LINE OF CLOCK
    if mhr < 10 then lcdout "0" 'To insure hour is double-digit number
    lcdout dec mhr,":"
    if mn < 10 then lcdout "0"
    lcdout dec mn, ":"
    if sc < 10 then lcdout "0"
    lcdout dec sc
    pause clock_pulse
    'SECOND LINE OF CLOCK
    lcdout $FE, $C0 'Cursor at 2nd line
    Lcdout " " ' Clear 2nd line
    if mhr > 12 then
    lhr = mhr - 12
    elseif mhr = 0 then
    lhr = 12
    lhr = mhr
    if lhr < 10 then lcdout "0"
    lcdout dec lhr, ":"
    lcdout dec mn, " "
    if mhr < 13 then
    lcdout "AM"
    lcdout "PM"
    'LOOK FOR BUTTON PRESS TO STALL INCREMENT TIME
    if PORTA.0 = 1 Then second_pause 'Look for button press and stall clock
    'INCREMENT TIME
    sc = sc + 1
    if sc > 59 then
    sc = 0
    mn = mn + 1
    if mn > 59 then
    mn = 0
    mhr = mhr + 1
    if mhr > 23 then
    mhr = 0
    Goto mainloop ' Update Display
    second_pause:
    While PORTA.0 = 1
    wend
    Goto mainloop 'Update Display
    End ' END OF PROGRAM
    Jan 2007
    Default Re: Need help with 16F676 button press
    I found it!
    I changed
    to
    if PORTA.0 == 1 Then second_pause
    Its now working correctly
    I have a hard time believing that was the actual problem. In PBP (unlike, for example, C) = and == are the same thing. And you basically have the proof in your own code sine the WHILE loop works and you have only one = in that comparison.
    second_pause:
    While PORTA.0 = 1     ' <--- See, you don't need ==
    wend
    I would try changing it back and see if it really returns to a non working state.
    Jan 2007
    second_pause:
    wend
    Hi Hentik,
    I added the second = to the While loop when I updated the IF statement.
    I can definitely change the IF statement back to a single = and see if it goes back to not working - just for a validation test.
    Prior to making the change in the IF statement - I also removed the bias resistors and set PortA.0, 1, & 2 with internal pull-ups - and setup the buttons so that they pull to ground.
    I'll change the IF statement and let you know
    Jan 2007
    Well - you were right.
    I changed it back to a single = and it still works.
    So I can only guess.
    The only other change I made was to add the internal pull-ups and switch the buttons to press pins to ground.
    And I did that before changing the IF statement and it still didn't work until after I changed the IF statement.
    I added two more buttons - one to manually increment hour and one to manually increment minute.
    But in any case - its working - which is a good thing! :-]
    SWITZERLAND (french speaking)
    Hi dw_picbasic,
    I'm an electrician and when I need a lamp to light on, I turn on (a kind of "1" level) the button that will provide energy to the lamp.
    In electronic, it is different. As I learned over time, a good practice is to use "inverted-logic" for digital inputs.
    I see, you pull-down your input pin so you wait for a high level (or "1" or "active high") to trigger an event. I might suggest you to "invert" your way of thinking and trigger your event(s) when the button goes to a "low" level (or "0" or "active low").
    Waiting for a "low level" means that you need to keep the input always "high" like in this shema.
    Your PIC has alread built-in "weak pull-ups" (find this in your datasheet) like R1 so you don't need to add anything to your button. Use them in place of your external resistor(s)
    This way of doing has some advantages and one of them is a good protection against noise.
    Roger
  1. Replies: 5
    Last Post: - 26th February 2011, 06:51
  2. Button press or not
    Last Post: - 24th November 2010, 21:37
  3. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 23:36
  4. Sleep until button press?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 9th October 2007, 04:47
  5. Button press and press & hold how to ?
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 04:37
