Challenge & Response
Results 1 to 9 of 9
    Default Challenge & Response
    Seasons Greetings to all.
    If you get bored with relatives and feasting today perhaps you might cast your eye over the below.
    I have an electronic gadget that has a challenge response going on.
    It sends me two bytes.
    I have to respond with two bytes somehow derived from the ones it sent me.
    I have a few examples below of correct challenges and responses.
    Any ideas on how it is working and generating the response?
    Challenge $E3 $C5
    Response $82 $CB
    Challenge $79 $71
    Response $04 $35
    Challenge $84 $15
    Response $ED $85
    Challenge $9B $B6
    Response $6F $C9
    Challenge $C7 $B0
    Response $1A $DD
    Challenge $AB $19
    Response $9A $69
    Many thanks and best wishes for the new year.
    Default Re: Challenge & Response
    I found a C++ solution to this calculation but I need to translate it into PbPro.
    The actual seed/key is 3 byte not two as I first thought.
    Happy to pay for some help to do this as I know nothing about C++ and don't have Visual Studio etc.
    Text file attached..
    OK
    It appears to be a random number generator based on the "Seed". At the top is a function for InitializeComponent(); which isn't anywhere in the body of code. I don't understand fully what it's supposed to do, but can give you some translation ideas. Let's break some of it down. All of the "Using"s listed at the top bring in macros and such from external files that are part of VS. Again, without actually looking each of them up, it's hard to tell what they contribute. The rest of the document is a Collection; more specifically it's called "namespace Calculation"; the rules which are probably spelled out in "System.Collections.Generic;".
    "int Func3(int paramInt1, int paramInt2, int paramInt3)" is a subroutine. In PBP we'd use "Func3:", but first we'd have to already declare:
    paramInt1 VAR SIGNED WORD
    paramInt2 VAR SIGNED WORD
    paramInt3 VAR SIGNED WORD
    Then prior to GOSUB Func3 we have to assign values to them:
    paramInt1 = 1234
    paramInt2 = -567
    paramInt3 = 890
    Next:
                int i = paramInt1 << 8 | paramInt2;
                int j;
                int k; int m; int n; int i1; switch (paramInt3)
                    case 65:
                    case 66:
    "switch (paramInt3)" would be the same as "SELECT CASE paramInt3:" Also, " int i = paramInt1 << 8 | paramInt2;" is the same as
    i.HIGHBYTE = paramInt1
    i.LOWBYTE = paramInt2
    At the bottom of the switch routine is "return Func2(i, j, k, m, n, i1);" In PBP we would have already placed the resultant values in each of these variables with
    case 111:
                        j = 16360;
                        k = 6010;
                        m = 0;
                        n = 1;
                        i1 = -2;
    "int getKey(int i)" manipulates the input ("i") with masks. I forget the hierarchy as to which gets precedence; ">>" or "&", and without parentheses, I would have to look it up to know for sure which operation is executed first.
    I know this isn't everything, but hopefully it will help you to work through much of it. Do what you can then report back where you're having challenges.
    Thanks for the response.
    I've have this so far, but it's not right yet.
    Gives same incorrect answer with different seeds.
    Any obvious gaffes?
    PIC18F2680
    'Long Variables for signed Key Calculation
    int VAR LONG
    key VAR LONG
    seed VAR LONG
    top_j VAR LONG
    top_k VAR LONG
    top_l  VAR LONG
    F3_i VAR LONG
    F3_j VAR LONG
    F3_k VAR LONG
    F3_m VAR LONG
    F3_n VAR LONG
    F3_i1 VAR LONG
    F2_i VAR LONG
    F2_j VAR LONG
    F2_k VAR LONG
    F2_m VAR LONG
    F2_n VAR LONG
    F2_i1 VAR LONG
    Start:
    Seed.Byte0 = $6B
    Seed.Byte1 = $E3
    Seed.byte2 = $C5
    'Answer should be $82 $CB $6B
    lcdout hex2 Seed.byte2," $",hex2 Seed.byte1," $",hex2 seed.byte0
    gosub CalcKey
    lcdout hex2 key.byte2," $",hex2 key.byte1," $",hex2 key.byte0
    'Try Again
    Seed.Byte0 = $6B
    Seed.Byte1 = $71
    Seed.byte2 = $79
    'Answer should be $04 $35 $6B
    gosub CalcKey
    Stop
    CalcKey:
    top_j = seed >> $10
    top_j = top_j & $ff
    top_k = seed >> 8
    top_k = top_k & $ff
    top_l = seed & $ff
    F3_i = top_j << 8
    F3_i = F3_i | top_k
    SELECT CASE top_l
                    case 1
                        F3_j = 20483;
                        F3_k = 37495;
                        F3_m = 19380;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 2
                        F3_j = 48737;
                        F3_k = 29064;
                        F3_m = 0;
                        F3_n = -2;
                        F3_i1 = 1;
                    case 3
                        F3_j = 38851;
                        F3_k = 17007;
                        F3_m = 57213;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 4
                        F3_j = 38191;
                        F3_k = 42963;
                        F3_m = 45416;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 5
                        F3_j = 31893;
                        F3_k = 60216;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -2;
                    case 6
                        F3_j = 26458;
                        F3_k = 15181;
                        F3_m = 11362;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 7
                        F3_j = 10773;
                        F3_k = 36766;
                        F3_m = 28592;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 8
                        F3_j = 13376;
                        F3_k = 4967;
                        F3_m = 62941;
                        F3_n = 2;
                        F3_i1 = -3;
                    case 9
                        F3_j = 2197;
                        F3_k = 24862;
                        F3_m = 65475;
                        F3_n = -2;
                        F3_i1 = 3;
                    case 10
                        F3_j = 31199;
                        F3_k = 59852;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 11
                        F3_j = 45383;
                        F3_k = 9690;
                        F3_m = 0;
                        F3_n = 3;
                        F3_i1 = -2;
                    case 12
                        F3_j = 34146;
                        F3_k = 59163;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 2;
                    case 13
                        F3_j = 62765;
                        F3_k = 33340;
                        F3_m = 5749;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 14
                        F3_j = 45458;
                        F3_k = 44092;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 3;
                    case 15
                        F3_j = 37357;
                        F3_k = 39321;
                        F3_m = 0;
                        F3_n = -2;
                        F3_i1 = 1;
                    case 16
                        F3_j = 8713;
                        F3_k = 454;
                        F3_m = 23575;
                        F3_n = 1;
                        F3_i1 = -2;
                    case 17
                        F3_j = 9988;
                        F3_k = 56677;
                        F3_m = 29637;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 18
                        F3_j = 57758;
                        F3_k = 34088;
                        F3_m = 11152;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 19
                        F3_j = 33800;
                        F3_k = 14769;
                        F3_m = 0;
                        F3_n = -2;
                        F3_i1 = 1;
                    case 20
                        F3_j = 4069;
                        F3_k = 4013;
                        F3_m = 24616;
                        F3_n = -1;
                        F3_i1 = 2;
                    case 21
                        F3_j = 17056;
                        F3_k = 12969;
                        F3_m = 11927;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 22
                        F3_j = 31370;
                        F3_k = 60592;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 3;
                    case 23
                        F3_j = 24184;
                        F3_k = 58486;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 3;
                    case 24
                        F3_j = 56838;
                        F3_k = 5012;
                        F3_m = 35563;
                        F3_n = 2;
                        F3_i1 = -3;
                    case 25
                        F3_j = 49473;
                        F3_k = 5452;
                        F3_m = 33161;
                        F3_n = 3;
                        F3_i1 = -2;
                    case 26
                        F3_j = 64459;
                        F3_k = 44104;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 27
                        F3_j = 6123;
                        F3_k = 30247;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 3;
                    case 28
                        F3_j = 62885;
                        F3_k = 57915;
                        F3_m = 28211;
                        F3_n = -2;
                        F3_i1 = 3;
                    case 29
                        F3_j = 56790;
                        F3_k = 34537;
                        F3_m = 0;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 30
                        F3_j = 34655;
                        F3_k = 4726;
                        F3_m = 0;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 31
                        F3_j = 45667;
                        F3_k = 2227;
                        F3_m = 0;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 32
                        F3_j = 64118;
                        F3_k = 22124;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 33
                        F3_j = 20483;
                        F3_k = 37495;
                        F3_m = 19380;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 34
                        F3_j = 18934;
                        F3_k = 33007;
                        F3_m = 45671;
                        F3_n = -1;
                        F3_i1 = 2;
                    case 35
                        F3_j = 53898;
                        F3_k = 43937;
                        F3_m = 8992;
                        F3_n = 3;
                        F3_i1 = -2;
                    case 36
                        F3_j = 26472;
                        F3_k = 30849;
                        F3_m = 15462;
                        F3_n = -2;
                        F3_i1 = 3;
                    case 37
                        F3_j = 18864;
                        F3_k = 16973;
                        F3_m = 0;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 38
                        F3_j = 10153;
                        F3_k = 24758;
                        F3_m = 0;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 39
                        F3_j = 28031;
                        F3_k = 31768;
                        F3_m = 65233;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 40
                        F3_j = 9577;
                        F3_k = 32816;
                        F3_m = 0;
                        F3_n = -3;
                        F3_i1 = 3;
                    case 41
                        F3_j = 33294;
                        F3_k = 41833;
                        F3_m = 63823;
                        F3_n = 2;
                        F3_i1 = -2;
                    case 42
                        F3_j = 46258;
                        F3_k = 33763;
                        F3_m = 47869;
                        F3_n = 2;
                        F3_i1 = -2;
                    case 43
                        F3_j = 303;
                        F3_k = 15452;
                        F3_m = 49261;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 44
                        F3_j = 14480;
                        F3_k = 52729;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -2;
                    case 45
                        F3_j = 26181;
                        F3_k = 30558;
                        F3_m = 11669;
                        F3_n = -1;
                        F3_i1 = 1;
                    case 46
                        F3_j = 57729;
                        F3_k = 31412;
                        F3_m = 0;
                        F3_n = 3;
                        F3_i1 = -3;
                    case 47
                        F3_j = 38273;
                        F3_k = 42785;
                        F3_m = 57170;
                        F3_n = 2;
                        F3_i1 = -3;
                    case 48
                        F3_j = 65304;
                        F3_k = 24702;
                        F3_m = 12077;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 49
                        F3_j = 25997;
                        F3_k = 16247;
                        F3_m = 11573;
                        F3_n = -2;
                        F3_i1 = 3;
                    case 50
                        F3_j = 47122;
                        F3_k = 17812;
                        F3_m = 0;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 51
                        F3_j = 62790;
                        F3_k = 184;
                        F3_m = 43056;
                        F3_n = -2;
                        F3_i1 = 1;
                    case 52
                        F3_j = 27811;
                        F3_k = 36172;
                        F3_m = 10312;
                        F3_n = -1;
                        F3_i1 = 2;
                    case 53
                        F3_j = 33495;
                        F3_k = 4706;
                        F3_m = 23772;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 54
                        F3_j = 11806;
                        F3_k = 6016;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 55
                        F3_j = 23022;
                        F3_k = 61027;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 56
                        F3_j = 14502;
                        F3_k = 52925;
                        F3_m = 45502;
                        F3_n = -3;
                        F3_i1 = 2;
                    case 57
                        F3_j = 19654;
                        F3_k = 47349;
                        F3_m = 29195;
                        F3_n = 3;
                        F3_i1 = -2;
                    case 58
                        F3_j = 4043;
                        F3_k = 49055;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -2;
                    case 59
                        F3_j = 238;
                        F3_k = 61025;
                        F3_m = 46052;
                        F3_n = -2;
                        F3_i1 = 3;
                    case 60
                        F3_j = 26525;
                        F3_k = 16314;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 61
                        F3_j = 27577;
                        F3_k = 18161;
                        F3_m = 3841;
                        F3_n = -3;
                        F3_i1 = 1;
                    case 62
                        F3_j = 11820;
                        F3_k = 48834;
                        F3_m = 24936;
                        F3_n = -3;
                        F3_i1 = 2;
                    case 63
                        F3_j = 926;
                        F3_k = 34536;
                        F3_m = 62639;
                        F3_n = -1;
                        F3_i1 = 1;
                    case 64
                        F3_j = 34242;
                        F3_k = 21476;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -3;
                    case 97
                        F3_j = 11937;
                        F3_k = 0;
                        F3_m = 54278;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 98
                        F3_j = 11129;
                        F3_k = 0;
                        F3_m = 41060;
                        F3_n = 1;
                        F3_i1 = -3;
                    case 99
                        F3_j = 16232;
                        F3_k = 0;
                        F3_m = 37025;
                        F3_n = 3;
                        F3_i1 = -2;
                    case 100
                        F3_j = 62287;
                        F3_k = 21359;
                        F3_m = 0;
                        F3_n = -1;
                        F3_i1 = 1;
                    case 101
                        F3_j = 19345;
                        F3_k = 63583;
                        F3_m = 20313;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 102
                        F3_j = 50636;
                        F3_k = 34432;
                        F3_m = 58878;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 103
                        F3_j = 8636;
                        F3_k = 42038;
                        F3_m = 0;
                        F3_n = 3;
                        F3_i1 = -1;
                    case 104
                        F3_j = 49296;
                        F3_k = 0;
                        F3_m = 23727;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 105
                        F3_j = 62603;
                        F3_k = 0;
                        F3_m = 7632;
                        F3_n = 2;
                        F3_i1 = -1;
                    case 106
                        F3_j = 54947;
                        F3_k = 13952;
                        F3_m = 0;
                        F3_n = -3;
                        F3_i1 = 2;
                    case 107
                        F3_j = 46336;
                        F3_k = 0;
                        F3_m = 32973;
                        F3_n = -1;
                        F3_i1 = 3;
                    case 108
                        F3_j = 31276;
                        F3_k = 0;
                        F3_m = 41988;
                        F3_n = -2;
                        F3_i1 = 2;
                    case 109
                        F3_j = 24959;
                        F3_k = 31354;
                        F3_m = 55064;
                        F3_n = 1;
                        F3_i1 = -1;
                    case 110
                        F3_j = 39963;
                        F3_k = 29660;
                        F3_m = 0;
                        F3_n = 2;
                        F3_i1 = -3;
                    case 111
                        F3_j = 16360;
                        F3_k = 6010;
                        F3_m = 0;
                        F3_n = 1;
                        F3_i1 = -2;
                    case 112
                        F3_j = 50050;
                        F3_k = 36355;
                        F3_m = 34628;
                        F3_n = 3;
                        F3_i1 = -3;
                    end select
    F2_i = F3_i + F3_j
    F2_i = F2_i & $FFFF
    IF (F3_n > 0) then
        F2_j = $FFFF & (F3_i << F3_n | F3_i >> 16 - F3_n)
        F2_j = $FFFF & (F3_i >> -F3_n | F3_i << 16 + F3_n)
    F2_k = F3_i + F3_k
    F2_k = F2_k & $FFFF
    IF (F3_i1 > 0) then
        F2_m = $FFFF & (F2_k << F3_i1 | F2_k >> 16 - F3_i1);
        F2_m = $FFFF & (F2_k >> -F3_i1 | F2_k << 16 + F3_i1);
    F2_n = F2_j * F2_m
    F2_i1 = F2_n + F3_m
    key = F2_i1 & $FFFF
    key = key << 8
    key = key + top_l
    not sure that pbp correctly left or right shifts negative numbers , see henriks treatise on the bme280 for correct method to deal with signed ints
    http://www.picbasic.co.uk/forum/showthread.php?t=24134
    ps , i did notice that some cases may lead to doing a left or right shift of a negative number of bits, eg [var << -3 ] i'm not sure how gcc would resolve that
  1. A new challenge (I'm in trouble again)
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 19th February 2012, 14:08
  2. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 07:54
  3. Replies: 20
    Last Post: - 13th May 2007, 05:10
  4. Problem with UART... here is a real challenge
    By matias in forum mel PIC BASIC Pro
    Last Post: - 5th May 2007, 08:30
  5. No Modem response
    By jimboho in forum mel PIC BASIC Pro
    Last Post: - 11th November 2004, 05:58
