max7219 and pic16f627
Results 1 to 10 of 10
    helenevans's Avatar
    helenevans Guest
    Question max7219 and pic16f627
    hello all,
    i'm working on a project which drives a row of number displays with the Maxim7219 which is in turn driven from a pic16f627. The pic16f627 gets it's instructions using 'serin' which is sent to it by an external computer. I'm using no decode so i can access the segments directly and a 4 mhz crystal.
    Thanks to alot of the previous posts, everything almost works perfectly, apart from a strange, recurrent problem. After about 3 minutes, the last digit in the row goes out of synch. Then, all the numbers go to full brightness. Then 4 out of five digits turn off completely. To get the set up running again, i have to shut off and on the power and then everything is ok again...for another three minutes. It seems to be a problem somewhere between the PIC and the Maxim, as this happens even if i stop using the serin from the computer.
    Any ideas?
    i have added 10k pull down resistors to clk, data,load.
    and I have posted the code below...
    Cheers,
    helen
    Device = 16F627
    XTAL = 4
    DIM IDnr as byte 'registers adress
    DIM value as byte 'registers data
    DIM digit as byte 'which digit
    DIM current as byte 'curent digit data
    SYMBOL datapin = PORTB.1 'orange
    SYMBOL clkpin = PORTB.2 'brown
    SYMBOL load1 = PORTB.3 'red
    DIM byt_01 as byte '1st header byte
    DIM byt_02 as byte '2nd header
    DIM byt_03 as byte 'read 1st byte
    DIM byt_04 as byte
    DIM byt_05 as byte
    DIM byt_06 as byte
    DIM byt_07 as byte
    '''''''''''''''''''''''''INIT MAXIM
    IDnr=12
    value=1
    GOSUB configure 'init shutdown
    IDnr=9
    value=0
    GOSUB configure 'init decode mode
    IDnr=11
    value=4
    GOSUB configure 'init scanlimit
    IDnr=10
    value=1
    GOSUB configure 'init intensity
    IDnr=15
    value=0
    GOSUB configure 'init testmode/normal operation
    delayms 1000
    SERIN PORTB.0, 16468, [byt_01]
    byt_01 = dec byt_01
    if byt_01=170 then 'this is the 1st header number
    SERIN PORTB.0, 16468, [byt_02]
    gosub check
    end if
    check:
    byt_02 = dec byt_02 'this is the second header number
    if byt_02 = 20 then
    SERIN PORTB.0, 16468, [byt_03] 'now get 5 bytes from pc
    SERIN PORTB.0, 16468, [byt_04]
    SERIN PORTB.0, 16468, [byt_05]
    SERIN PORTB.0, 16468, [byt_06]
    SERIN PORTB.0, 16468, [byt_07]
    end if
    for digit = 1 to 5
    current = LOOKUPl digit, [byt_03,byt_04,byt_05,byt_06,byt_07]
    SHIFTOUT datapin, clkpin, MSBFIRST, [digit] 'digit adress
    SHIFTOUT datapin, clkpin, MSBFIRST, [current] 'digit data
    PULSOUT load1, 3
    next
    ''''''''''''''''''''''''' CONFIGURE MAXIMS: add line for each LOAD/ROW
    configure:
    SHIFTOUT datapin, clkpin, MSBFIRST, [IDnr] 'adress
    SHIFTOUT datapin, clkpin, MSBFIRST, [value] 'data
    PULSOUT load1, 3
    '''''''''''''''''''''''''FIN
    Wink
    Hi, Helenevans
    And what about power dissipation in the 7219 ??? did you check the maximum current available for the digits ?
    No floating inputs ( Ck Enable or so ) ... for 7219 ???
    helenevans's Avatar
    helenevans Guest
    Red face
    hi Alain,
    thanks for your reply.
    After the Maxim we have a high current circuit to drive the digits.
    I just checked with an osciliscope to see what is happening when it has stopped working. The PIC is fine. The Maxims puts all the Segs to ground (therfore, off) and all the Digits are 5v (except, strangely Digit3)
    The other thing i noticed is that when the digits starts to misbehave, i can see a lot of noise (or pulsing) in the 5v that goes to both the Pic and the maxim. I have just put a diode in to protect the maxim's 5volt supply and for the moment this seems to have solved the problem. i will post again if this hasn't worked.
    best,
    helen
    Question
    and just an idea ...
    What if you make transmission a bit slowlier ??? ... (DEFINE SHIFT_PAUSEUS 100 i.e. )
    Default Always read the whole datasheet!!!
    <img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=439&stc=1>
    helenevans's Avatar
    helenevans Guest
    Cool max7219 and pic16f627
    thanks for all the responses.
    So the problem has come back again. One thing i've done is to re-initialise the maxims, every now and again, so at least they come back to life eventually. but it's far from an ideal solution.
    I have put a pause in as Acetronics suggests (although i need the speed) and they do keep going for much longer. but eventually they too, pack up (!)
    the speed, yes, maybe this is the issue. i guess most people don't want to change them so rapidly...
    Looking at the data sheet, I presume i need to consider the Pulse Width High (which is 50nS)? How can i calculate the right pauses and when to put them, to put the pic in synch with the maxims?
    Sorry, i'm sure this is all pretty basic stuff...
    any further thoughts, i'd be happy to hear them,
    best, Helen
    Talking
    Hello Helevans, You can send the scheme... that he wishes that makes the circuit.
    Greetings
    Quote Originally Posted by helenevans
    hello all,
    Any ideas?
    Cheers,
    helen
    Device = 16F627
    XTAL = 4
    DIM byt_04 as byte
    DIM byt_05 as byte
    DIM byt_06 as byte
    DIM byt_07 as byte
    IDnr=12
    value=1
    IDnr=9
    value=0
    IDnr=11
    value=4
    IDnr=10
    value=1
    IDnr=15
    value=0
    delayms 1000
    byt_01 = dec byt_01
    gosub check
    end if
    check:
    if byt_02 = 20 then
    end if
    for digit = 1 to 5
    PULSOUT load1, 3
    next
    configure:
    PULSOUT load1, 3
