Rotary encoder with DT interrupts
Results 1 to 34 of 34
    Jun 2005
    West Australia
    Default Re: Rotary encoder with DT interrupts
    No, 5v all the way unless the app calls for 3v3 (typically when I use a Nokia GLCD). In any case the PIC should be able to handle 3v3 at low speeds, surely?
    The pcb has bunches of decoupling caps, selectable 10k pullups (as used on the RE) and .1 caps to ground also to minimize and bounce at the source.
    Reset is pulled high via a 10k series diode combination for the ICSP requirements.
    I make unused pins output so don't need to worry about pullups as you would with inputs (else floating nightmares). I guess your wpu's take care of your inputs.
    Worse case I'll develop with the F886 (yet to try the F1938, hopefully tomorrow - I think you have one or two of these IIRC).
    What's next wise one?
    Grasshopper
    no, 5v all the way unless the app calls for 3v3 (typically when I use a Nokia GLCD). In any case the PIC should be able to handle 3v3 at low speeds, surely?
    not sure , for the 16f1788 the microchip ipe with pk4 warns , 5.00 v recommended (not sure where the ldo comes into play)
    as i don't , i have never seen or heard of a pic having an adverse effect from an unused floating input. if your program is affected by an unused input then its incomplete.
    the only measurable effect is a slight increase in power consumption (you need a microamp meter to detect it). floating pin nightmares for pic chips are a myth based on other logic families with fixed i/p pin to o/p pin relationships where totem-pole outputs could be driven at prodigious rates unnecessarily to bad effect, pics are not like that.
    when breadboarding all unused pins set as i/p is a good thing, you won't damage anything with misplaced connections.
    I just use regular polling instead of interrupts when using a pb rotary, and only increment/decrement the "true status" upon TWO successive state changes in the SAME "direction". This eliminates debouncing and does not require interrupt use and it's infallible.
    Picster
  1. Rotary encoder subroutine
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 10th October 2018, 14:13
  2. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 23:23
  3. Instant Interrupts for rotary encoder
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 09:24
  4. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
