Rotary encoder with DT interrupts
Results 1 to 34 of 34
    Jun 2005
    West Australia
    Default Re: Rotary encoder with DT interrupts
    Hi Richard,
    I don't see where you're going with your comments, maybe I'm just thick.
    In any case the Int Handler does recognize CW and CCW correctly with every turn and RE_val does increment or decrement accordingly by 1 count per detent as needed - the only issue is these unwanted regular serial disturbances following RE action, including the push button. Speed of rotation isn't a factor with their appearance.
    Something else is going on also - if I insert a Clear statement as below the RE_val resets to 0 - as if the PIC is reinitializing following the RE action hence the "I'm Alive" serial traffic. Without the Clear the count remains as it was prior to the serial disturbance.
    Is there a chance you could breadboard a 16F1788 and confirm my findings?
    Bill
    '   IOCBP = %01110000        ; REa portb.6, REb portb.5  pos edge trigger
       IOCBN = %01110000        ; REa portb.6, REb portb.5, REsw portb.4  neg edge trigger - falling edge only.
       IOCBF = 0                ; Reset the PortB flag.
       INTCON = %11001000       ; GIE, PEIE, IOCIE.
    clear                        ' Clear all vars.
      MaxLimit = 60             ' Menu value limit.
    '  pause 100                 ' Let everything settle...
    serout2 PORTC.6,16468,[13,10,"I'm Alive",13,10,10]
    SAMPLE of terminal
    RE_val 00001
    RE_val 00002
    RE_val 00003
    ButtPush = 1, RE 00003
    RE_val 00004
    RE_val 00005
    RE_val 00006
    RE_val 00005
    RE_val 00000
    RE_val 00000
    ButtPush = 1, RE 00000
    RE_val 00001
    RE_val 00002
    RE_val 00003
    RE_val 00004
    RE_val 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    RE_val 00009
    RE_val 00010
    RE_val 00011
    RE_val 00010
    RE_val 00009
    RE_val 00008
    RE_val 00007
    RE_val 00006
    RE_val 00005
    ButtPush = 1, RE 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    I'm Alive
    RE_val 00001
    RE_val 00002
    RE_val 00003
    RE_val 00004
    Since the I'm alive output is outside of and before Main it looks to me as if the PIC is resetting and starting over. Try something like:
    serout2 PORTC.6, 16468, [BIN8 STATUS, "  -  ", BIN8 PCON, 10,13]
    What does it say when you power up and what does it say when you get that rouge output?
    i breadboarded a 1788 and using the code as posted in reply 8 with one slight change in that serout2 is set to T9600 it
    1. fails to count properly as predicted
    2. shows no signs of resets occurring
    interestingly using an encoder with no filtering it gives the appearance of functioning
    curious , not sure what to think .
    '****************************************************************************************************'*  Name    : RE test WJS.pbp        *
    '*  Author  : WJ Sherwood        *
    '*  Notice  : Copyright (c) 2021        *
    '*          : All Rights Reserved        *
    '*  Date    : 07/02/21        *
    '*  Device  : 16F1788        *
    '*  Version : 1    (PBP 3.0.10.4)        *
    '*  Notes   : Spurious "I'm Alive" serial traffic following RE action (still) and corrupt chars if  *
    '*          : Pause at line 75 (following MaxLimit = 60) removed - what am I missing?               *
    '*          : REa portb.6, REb portb.5, REsw portb.4 all pulled up, active low.                     *
    '        CONFIGURE DEVICE
    #CONFIG  ; 16F1788
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON &  _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
            __config _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _LVP_OFF & _BORV_HI & _LPBOR_OFF
    ' -----[ Initialization ]---------------------------------------------------------------------------------
        TRISA = 000000       ' Set I/O.
        TRISB = 111111       ' Set I/O.
        TRISC = 000000       ' Set I/O.
    define  OSC  4
            OSCCON = 101010   ' 4Mhz (F1788).
    'define  OSC  32
    '        OSCCON = 110000   ; 32 MHz,
        ANSELA = 0           ; all digital
        ANSELB = 0           ; all digital
    ' Define LCD connections
        DEFINE  LCD_DREG        PORTA  ' LCD Data Port
        DEFINE  LCD_DBIT        0           ' Starting Data Bit
        DEFINE  LCD_RSREG       PORTA  ' Register Select Port
        DEFINE  LCD_RSBIT       4           ' Register Select Bit
        DEFINE  LCD_EREG        PORTA  ' Enable Port
        DEFINE  LCD_EBIT        7           ' Enable Bit
        DEFINE  LCD_BITS            4           ' Data Bus Size
        DEFINE  LCD_LINES       2           ' Number of Lines on LCD
    '        PIN ASSIGNMENTS, SYSTEM CONSTANTS, TEMPORARY VARIABLES
    ' Rotary Encoder stuff
    Old_Bits    VAR BYTE bank0  ' Encoder port bits before change.
    New_Bits    VAR BYTE bank0  ' Encoder port bits after change.
    RotEnc1_val VAR word bank0  ' Connected to PORTB<6:5>.
    MaxLimit    var word bank0  ' Used for setting upper limit for encoder counts.
    RotEncDir   VAR BIT  bank0  ' Direction of rotation bit.
    ButtPush    var bit  bank0  ' Flag shows button was pushed, allows quick exit from Int handler.
    REdec       var bit  bank0  ' Flag shows RE decrement, allows quick exit from Int handler.
    REinc       var bit  bank0  ' Flag shows RE increment, allows quick exit from Int handler.
        Include "MODEDEFS.BAS"      ' Include Shiftin/out modes.
        INCLUDE "DT_INTS-14.bas"    ' Needs to be assembled with MPASM **********
        INCLUDE "ReEnterPBP.bas"    ; Include if using PBP interrupts
        OPTION_REG.6 = 0        ' INTEDG set to interrupt on falling edge.
    '    OPTION_REG.6 = 1        ' INTEDG set to interrupt on rising edge.
    '   IOCBP = 110000        ; REa portb.6, REb portb.5  pos edge trigger
       IOCBN = 110000        ; REa portb.6, REb portb.5, REsw portb.4  neg edge trigger - falling edge only.
       INTCON = 001000       ; GIE, PEIE, IOCIE.
    latc.6 = 1                  ' Prevent garbled serial - newer PICs, inverted.
    serout2 PORTC.6,84,[13,10,"I'm Alive",13,10,10]
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    IOC_INT,  _Rot_Encoder,   PBP,  yes  ; Newer PICs.
        INT_CREATE              ; Creates the interrupt processor .
    @    INT_ENABLE   IOC_INT   ; Newer PICs.
    Old_Bits = PORTB & (100000)  ; RE uses B.6,B.5 - REa and REb.
      if PortB.4 = 0 then            ' Check if Encoder pushbutton was pushed.
      while PortB.4 = 0:wend         ' Wait for release.
      pause 50                       ' Debounce delay.
      serout2 PORTC.6,84,[13,10,"ButtPush = 1, RE ",dec5 RotEnc1_val]
      if REdec or REinc = 1 then
      serout2 PORTC.6,84,[13,10,"RE_val ",dec5 RotEnc1_val]
      REdec = 0:REinc = 0           ' Reset the flags.
    goto main                       ' endless loop waiting for INT.
    '---[IOC - interrupt handler]---------------------------------------------------
    ' Don't forget 4 counts per detent (Quadrature).
    Rot_Encoder:
         New_Bits = PORTB & (100000)         ' Set port bits for Encoder's chosen A and B channels.
         IF (New_Bits & 100000) = (Old_Bits & 100000) then DoneRotEnc ' No change.
         RotEncDir = New_Bits.6 ^ Old_Bits.5    ' Bit XOR compare to get direction of rotation.
         if RotEncDir = 0 then                  ' CCW so decrement.
            if PORTB.6 and PORTB.5 = 1 then     ' Only when RE both pins high (convert quad counts to singles).
            RotEnc1_val = RotEnc1_val - 1       ' Decrement the count.
              if RotEnc1_val => 65530 then RotEnc1_val = 0  ' Limit the max.
              if RotEnc1_val <= 4 then RotEnc1_val = 0      ' Limit the min.
            REdec = 1                                       ' Flag the event.
         ELSE                                   ' RotEncDir = 1, CW so increment.
              RotEnc1_val = RotEnc1_val + 1     ' Increment the count.
              if RotEnc1_val >= MaxLimit then RotEnc1_val = MaxLimit ' Limit the count.
            REinc = 1                           ' Flag the event.
    DoneRotEnc:
        Old_Bits = New_Bits
        INTCON.0 = 0        ; Clean up and exit - clear IOCIF.
        IOCBF = 0           ; Reset the flag.
    @ INT_RETURN
    Jun 2005
    West Australia
    Hi Henrik,
    Thanks for joining, your input is welcome.
    Inserting your code shows (terminal output):
    00011001 - 01010100
    I'm Alive
    RE_val 00001
    RE_val 00002
    RE_val 00003
    RE_val 00004
    RE_val 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    RE_val 00007
    RE_val 00006
    RE_val 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    RE_val 00009
    00011001 - 01010100
    I'm Alive
    ... so no change from original states once the 'reset' occurs - if that is what it is (I'm still decyphering the data sheet).
    Any comments?
    Cheers,
    Bill
    mine has been running for 4 hours now , nill resets
    Try to disable the WDT and see if it resets.
    I was a little quick with that PCON thing, on startup set PCON = %00011111 then let the program run
    serout2 PORTC.6, 16468, ["Power-on:", BIN8 STATUS, "  -  ", BIN8 PCON, 10,13]
    PCON = %00011111
    serout2 PORTC.6, 16468, ["Priming PCON:", BIN8 STATUS, "  -  ", BIN8 PCON, 10,13]
  1. Rotary encoder subroutine
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 10th October 2018, 14:13
  2. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 23:23
  3. Instant Interrupts for rotary encoder
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 09:24
  4. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
