Rotary encoder with DT interrupts
Results 1 to 34 of 34
    Jun 2005
    West Australia
    Default Re: Rotary encoder with DT interrupts
    Hi Folks,
    I'm trying to get my head around what is happening with my attempt at using a Rotary Encoder... it is functional however something weird is happening periodically returning from the interrupt.
    My "I'm Alive" serial string is returned to and finds itself sprinkled among the debug terminal data. I'm sure it is staring at me but I can't see why. Any help appreciated.
    Bill
    PS
    @ richard
    I persisted for hours trying your method (with appropriate pin changes) and had no joy so went with the Old vs New method. It would only count in one direction with either CW or CCW.
    '*  Name    : RE test WJS.pbp        *
    '*  Author  : WJ Sherwood        *
    '*  Notice  : Copyright (c) 2021        *
    '*          : All Rights Reserved        *
    '*  Date    : 07/02/21        *
    '*  Device  : 16F1788        *
    '*  Version : 1    (PBP 3.0.10.4)        *
    '*  Notes   : Spurious "I'm Alive" serial traffic following RE action - what am I missing?          *
    '*          : REa portb.6, REb portb.5, REsw portb.4 all pulled up, active low.                     *
    '        CONFIGURE DEVICE
    #CONFIG ; 16F1788.
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON &  _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
            __config _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _LVP_OFF & _BORV_HI & _LPBOR_OFF
    ' -----[ Initialization ]------------------------------------------------------------------------------------------------
        TRISA = %00000000       ' Set I/O.
        TRISB = %01111111       ' Set I/O.
        TRISC = %00000000       ' Set I/O.
    define  OSC  4
            OSCCON = %01101010   ' 4Mhz (F1788).
    'define  OSC  32
    '        OSCCON = %11110000   ; 32 MHz,
        ANSELA = 0           ; all digital
        ANSELB = 0           ; all digital
    ' Define LCD connections
        DEFINE  LCD_DREG        PORTA	' LCD Data Port
        DEFINE  LCD_DBIT        0		' Starting Data Bit
        DEFINE  LCD_RSREG       PORTA	' Register Select Port
        DEFINE  LCD_RSBIT       4		' Register Select Bit
        DEFINE  LCD_EREG        PORTA	' Enable Port
        DEFINE  LCD_EBIT        7		' Enable Bit
        DEFINE  LCD_BITS		4		' Data Bus Size
        DEFINE  LCD_LINES		2		' Number of Lines on LCD
    '        PIN ASSIGNMENTS, SYSTEM CONSTANTS, TEMPORARY VARIABLES
    ' Rotary Encoder stuff
    Old_Bits    VAR BYTE bank0  ' Encoder port bits before change.
    New_Bits    VAR BYTE bank0  ' Encoder port bits after change.
    RotEnc1_val VAR word bank0  ' Connected to PORTB<5:6>.
    MaxLimit    var word bank0  ' Used for setting upper limit for encoder counts.
    RotEncDir   VAR BIT  bank0  ' Direction of rotation bit.
    ButtPush    var bit  bank0  ' Flag shows button was pushed, allows quick exit from Int handler.
        Include "MODEDEFS.BAS"      ' Include Shiftin/out modes.
        INCLUDE "DT_INTS-14.bas"    ' Needs to be assembled with MPASM **********
        INCLUDE "ReEnterPBP.bas"    ; Include if using PBP interrupts
        OPTION_REG.6 = 0        ' INTEDG set to interrupt on falling edge.
    '    OPTION_REG.6 = 1        ' INTEDG set to interrupt on rising edge.
    '   IOCBP = %01110000        ; REa portb.6, REb portb.5  pos edge trigger
       IOCBN = %01110000        ; REa portb.6, REb portb.5, REsw portb.4  neg edge trigger - falling edge only.
       IOCBF = 0                ; Reset the PortB flag.
       INTCON = %11001000       ; GIE, PEIE, IOCIE.
    '    RotEnc1_val = 0         '
        pause 500               ' Let everything settle...
    'latc.6 = 0                  ' Prevent garbled serial - newer PICs, true.
    latc.6 = 1                  ' Prevent garbled serial - newer PICs, inverted.
    serout2 PORTC.6,16468,[13,10,"I'm Alive",13,10,10]
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    IOC_INT,  _Rot_Encoder,   PBP,  yes  ; Newer PICs.
        INT_CREATE              ; Creates the interrupt processor .
    @    INT_ENABLE   IOC_INT   ; Newer PICs.
    Old_Bits = PORTB & (%01100000)  ; RE uses B.6,B.5 - REa and REb.
    'Old_Bits = PORTB & (%01110000)  ; RE uses B.6,B.5,B.4 - includes RE push button.
    goto main                       ' endless loop waiting for INT.
    '---[IOC - interrupt handler]---------------------------------------------------
    Rot_Encoder:
        if PortB.4 = 0 then             ' Check if Encoder pushbutton was pushed.
    serout2 PORTC.6,16468,[13,10,"ButtPush = 1, RE ",dec5 RotEnc1_val]
        ButtPush = 1                    ' Set the flag for a quick exit.
    goto DoneRotEnc                     ' Clean up and exit.
    ' Don't forget 4 counts per detent (Quadrature).
         New_Bits = PORTB & (%01110000)         ' Set port bits for Encoder's chosen A and B channels.
         IF (New_Bits & %01110000) = (Old_Bits & %01110000) then DoneRotEnc ' No change.
         RotEncDir = New_Bits.6 ^ Old_Bits.5    ' Bit XOR compare to get direction of rotation.
         if RotEncDir = 0 then                  ' CCW so decrement.
            if PORTB.6 and PORTB.5 = 1 then     ' Only when RE both pins high (convert quad counts to singles).
            RotEnc1_val = RotEnc1_val - 1       ' Decrement the count.
              if RotEnc1_val => 65530 then RotEnc1_val = 0  ' Limit the max.
              if RotEnc1_val <= 4 then RotEnc1_val = 0      ' Limit the min.
    serout2 PORTC.6,16468,[13,10,"RE_val ",dec5 RotEnc1_val]
         ELSE           ' RotEncDir = 1, CW so increment.
              RotEnc1_val = RotEnc1_val + 1     ' Increment the count.
              if RotEnc1_val >= MaxLimit then RotEnc1_val = MaxLimit ' Limit the count.
    DoneRotEnc:
         Old_Bits = New_Bits
        INTCON.0 = 0        ; Clean up and exit - clear IOCIF.
        IOCBF = 0           ; Reset the flag.
    @ INT_RETURN
    @ richard
    all you have to do is post the code for your attempt and i will have a look
    hints
    serout2 PORTC.6,16468,[13,10,"RE_val ",dec5 RotEnc1_val] once in an isr is bad twice is just asking for trouble , use flags
    using a pin change int for a switch is a giant over kill
    Jun 2005
    West Australia
    Hi Richard,
    Thanks for your help and guidance, as always.
    I took your hints and made appropriate adjustments (see below) but the rogue serial persists... With your preferred method I'd like to crack this existing problem before exploring your offer if that's okay.
    Stay safe,
    Bill
    '*  Notes   : Spurious "I'm Alive" serial traffic following RE action (still) and corrupt chars if  *
    '*          : Pause at line 75 (following MaxLimit = 60) removed - what am I missing?               *
    '        CONFIGURE DEVICE
    #CONFIG ; 16F1788.
    define  OSC  4
    'define  OSC  32
    RotEnc1_val VAR word bank0  ' Connected to PORTB<6:5>.
    REdec       var bit  bank0  ' Flag shows RE decrement, allows quick exit from Int handler.
    REinc       var bit  bank0  ' Flag shows RE increment, allows quick exit from Int handler.
      MaxLimit = 60           ' Menu value limit.
    '  pause 100               ' Let everything settle...
      while PortB.4 = 0:wend         ' Wait for release.
      pause 50                       ' Debounce delay.
      if REdec or REinc = 1 then
      REdec = 0:REinc = 0           ' Reset the flags.
    Rot_Encoder:
         New_Bits = PORTB & (%01100000)         ' Set port bits for Encoder's chosen A and B channels.
         IF (New_Bits & %01100000) = (Old_Bits & %01100000) then DoneRotEnc ' No change.
            REdec = 1                                       ' Flag the event.
            REinc = 1                           ' Flag the event.
    DoneRotEnc:
        Old_Bits = New_Bits
    @ INT_RETURN
    if you look at the expected b5,b6 pin values at each interrupt
    for neg edge trigger only
    ints occur on orange lines
    under ideal conditions you get for say cw rotation
    01,00,01,00,01............
    for ccw
    00,10,00,10,00............
    so for cw
    old = 01000000 new 00000000 or old = 00000000 new 01000000
    new.6 ^ old.5 =1 new.6 ^ old.5 = 0
    so for ccw
    old = 00100000 new 00000000 or old = 00000000 new 00100000
    new.6 ^ old.5 = 0 new.6 ^ old.5 = 1
    i don't see your logic decoding direction at all successfully
    Jun 2005
    West Australia
    Hi Richard,
    I don't see where you're going with your comments, maybe I'm just thick.
    In any case the Int Handler does recognize CW and CCW correctly with every turn and RE_val does increment or decrement accordingly by 1 count per detent as needed - the only issue is these unwanted regular serial disturbances following RE action, including the push button. Speed of rotation isn't a factor with their appearance.
    Something else is going on also - if I insert a Clear statement as below the RE_val resets to 0 - as if the PIC is reinitializing following the RE action hence the "I'm Alive" serial traffic. Without the Clear the count remains as it was prior to the serial disturbance.
    Is there a chance you could breadboard a 16F1788 and confirm my findings?
    Bill
    clear                        ' Clear all vars.
    SAMPLE of terminal
    RE_val 00001
    RE_val 00002
    RE_val 00003
    ButtPush = 1, RE 00003
    RE_val 00004
    RE_val 00005
    RE_val 00006
    RE_val 00005
    RE_val 00000
    RE_val 00000
    ButtPush = 1, RE 00000
    RE_val 00001
    RE_val 00002
    RE_val 00003
    RE_val 00004
    RE_val 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    RE_val 00009
    RE_val 00010
    RE_val 00011
    RE_val 00010
    RE_val 00009
    RE_val 00008
    RE_val 00007
    RE_val 00006
    RE_val 00005
    ButtPush = 1, RE 00005
    RE_val 00006
    RE_val 00007
    RE_val 00008
    I'm Alive
    RE_val 00001
    RE_val 00002
    RE_val 00003
    RE_val 00004
    Since the I'm alive output is outside of and before Main it looks to me as if the PIC is resetting and starting over. Try something like:
    serout2 PORTC.6, 16468, [BIN8 STATUS, "  -  ", BIN8 PCON, 10,13]
    What does it say when you power up and what does it say when you get that rouge output?
    i breadboarded a 1788 and using the code as posted in reply 8 with one slight change in that serout2 is set to T9600 it
    1. fails to count properly as predicted
    2. shows no signs of resets occurring
    interestingly using an encoder with no filtering it gives the appearance of functioning
    curious , not sure what to think .
    '****************************************************************************************************'*  Name    : RE test WJS.pbp        *
    '        CONFIGURE DEVICE
    #CONFIG  ; 16F1788
        TRISA = 000000       ' Set I/O.
        TRISB = 111111       ' Set I/O.
        TRISC = 000000       ' Set I/O.
    define  OSC  4
            OSCCON = 101010   ' 4Mhz (F1788).
    'define  OSC  32
    '        OSCCON = 110000   ; 32 MHz,
    '   IOCBP = 110000        ; REa portb.6, REb portb.5  pos edge trigger
       IOCBN = 110000        ; REa portb.6, REb portb.5, REsw portb.4  neg edge trigger - falling edge only.
       INTCON = 001000       ; GIE, PEIE, IOCIE.
    serout2 PORTC.6,84,[13,10,"I'm Alive",13,10,10]
    Old_Bits = PORTB & (100000)  ; RE uses B.6,B.5 - REa and REb.
      serout2 PORTC.6,84,[13,10,"ButtPush = 1, RE ",dec5 RotEnc1_val]
      serout2 PORTC.6,84,[13,10,"RE_val ",dec5 RotEnc1_val]
    Rot_Encoder:
         New_Bits = PORTB & (100000)         ' Set port bits for Encoder's chosen A and B channels.
         IF (New_Bits & 100000) = (Old_Bits & 100000) then DoneRotEnc ' No change.
    DoneRotEnc:
        Old_Bits = New_Bits
    @ INT_RETURN
  1. Rotary encoder subroutine
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 10th October 2018, 13:13
  2. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 22:23
  3. Instant Interrupts for rotary encoder
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 08:24
  4. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 21:05
