Determining variable length (number of digits) possible?
Results 1 to 15 of 15
    Default Determining variable length (number of digits) possible?
    Hello.
    I'm writing a custom parser for MAX7219 - it can display data and most of ASCII characters in any digit of connected 8 digit 7 segment led display.
    So say there is an input variable, XVR, which can hold any value from 1 to 9999.
    I have a loop, which will extract via DIG value of individual digits from this variable and send them to MAX7219
    The idea is to have loop repeat N times, where N is the total length of variable, and on each run, increase DIG value by 1, so next digit will be extracted, and in case of 2 digit variable, say from 11 to 99, it won't go thru whole display.
    On ZX Spectrum we had a LEN statement, but here we not.
    Any ideas?
    Bombay, India
    Default Re: Determining variable length (number of digits) possible?
    I will give a generic answer as my PICBasic skills are weak at the moment
    Assume your variable x contains 1000
    You can strip out digits like this from Right to left with position 0 at the right (least significant position) of the display
        position = 0
         if x > 9999 then x=9999                  ' restrict to maximum you can display
         while x != 0
             digit[position] = x Mod 10            ' keep the digit
             x = x div 10                                  ' integer divide by 10
             position = position+1                   ' next display position
         end while
    This will automatically stop if the value is 1..9 at 1 digit, or 11..99 at 2 digits and so on.
    Thanks, but will this give me variable length?
    I need to know number of digits in variable, to turn off unused digits on display (instead of showing zeroes there).
    Bombay, India
    What you're looking for is commonly known as leading zero blanking. You could continue with filling blanks to digits after the value is zero. That is how you will achieve it.
    OK
    IF XVR > 999 THEN
    [Work the first digit]
    ENDIF ;If not, no action taken
    IF XVR > 99 THEN
    [Work the 2nd digit]
    I'm doing a more featured custom decoder, which will display both letters and digits on max7219 7 segment display. It will also have custom decoder for digital values. The code is below:
    FOURD=12345 'test value
    dstart=2 'start segment
    DLEN=2 'decode length
    TEST: 'test digits
    FOR x=DLEN TO 1 STEP -1
    Z=FOURD DIG X+1	'EXTRACT VALUE
    GOSUB FOURDEC
    PAUSE 500
    NEXT
    GOTO TEST
    FOURDEC:	'DIGIT DECODER
    if Z=0 then Y=126
    if Z=1 then Y=48
    if z=2 then Y=109
    if z=3 then Y=121
    if z=4 then Y=51
    if z=5 then Y=91
    if z=6 then Y=95
    if z=7 then Y=112
    if z=8 then Y=127
    if z=9 then Y=115
    low load
    shiftout datapin,clockpin,1,[x+DSTART-1, y]	'DISPLAY THE LETTER
    high load
    This code works, but DLEN instead of cropping digits from the left, crops them from the right - say initial variable is "12345" and I want to display 2 digits from it, I'm getting "45" instead of "12", have no idea why. Same for start position - DSTART starts from rightmost position, instead of leftmost....
  1. Replies: 11
    Last Post: - 9th March 2020, 12:37
  2. Measuring a variable freq/length pulse and generating more pulses.
    Last Post: - 18th September 2014, 09:10
  3. Determining how much RAM is available?
    By Art in forum mel PIC BASIC Pro
    Last Post: - 20th February 2012, 16:04
  4. Determining LONG compiler
    Last Post: - 10th September 2011, 19:19
  5. HSERIN for variable length string
    Last Post: - 19th February 2010, 05:58
