HD44780 LCD cable length
Results 1 to 3 of 3
    Default HD44780 LCD cable length
    What is the practical length limit from a PIC to a LCD. If shielded cable were used would lengths of 15 to 20' be a problem. I have cables with individually shielded conductors plus an outer shield. Not sure if capacitance or R drop would be any issue. Anyone running a setup like this?
    Default Re: HD44780 LCD cable length
    If you do have problems then I would just use a serial BACKPACK and use RS232.
    EN82fn
    This has been covered a couple of times over the years, see (and read) here for starters:
    http://www.picbasic.co.uk/forum/showthread.php?t=15989
    I suppose it might depend on a lot of variables, like type of cable, output drive capability, HD44780 compatability (some are more picky than others) and so on so it's probably best to do some experients and find out.
  1. 18B20 and cable length
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 28th October 2015, 00:34
  2. LCD cable length?
    By Art in forum General
    Last Post: - 14th February 2012, 15:35
  3. Max cable length?
    By Fredrick in forum Serial
    Last Post: - 2nd July 2010, 20:37
  4. Maximun Cable Length for PIC to LCD
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 19:00
  5. Cable Length Between Micros
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 14:29
