Another attempt for I2C eeprom, this time - 25C256.
Results 1 to 21 of 21
    Default Another attempt for I2C eeprom, this time - 25C256.
    Hello.
    I decided to give it another try, now with this module.
    https://www.elecrow.com/i2c-eeprom-m...256-p-736.html
    Pull up resistors installed, and following code configured.
    when properly working, it should produce chirp up, chirp down sound. But it does not
    of course, chirp up - write, works fine, because here it chirps directly, but in read routine
    I'm getting zeros.
    Only what I've found out, that if I set read address to 160 (A0) it returns 255, for any other address, it returns 0.
    So somehow, chip responds, right? but not completely.
    What I'm missing?
    x var byte
    y var byte
    z var byte
    sda var portb.1
    scl var portb.0
    ehmo:
    for X=0 to 12
    I2CWrite sda, scl, 160, x, [x]
    hpwm 1,127,1000+x*10
    pause 1
    next
    hpwm 1,0,1000 'mute
    for x=12 to 0 step -1
    i2cread sda, scl, 160,x,[y]
    hpwm 1,127,1000+Y*10
    pause 1
    next
    hpwm 1,0,1000
    goto ehmo
    Default Re: Another attempt for I2C eeprom, this time - 25C256.
    For read try 161 address
    No difference - already tried all combos like 159+160, 160+161 and so on....
    The 25C265 as mentioned in the title is a SPI EEPROM. That won't ever work with the I2C command.
    If, on the other hand, it's the 24C256 then the state of the A0-A2 pins will have an effect on the address. Anyway, looking at the 24C256 datasheet:
    In Byte Write mode the Master sends a START, followed
    by Slave address, two byte address and data to be written
    (Figure 6).
    And then your code:
    You're using the x-variable as the address (and data) but have it defined as a byte.
    With that said, I have not ever used I2C so I'm certainly no expert.
    Yes I made an error in tittle, chip is certainly 24C256.
    you need to do it properly
    OK
    C1, if you have the spare cash, I would recommend a cheap logic analyzer. Saelig sells one for (I think I paid) around $80 US. I haven't used mine in several years, as I now have a Pico Scope that does much more, and better. I am in the northeast US. If you're willing to cover shipping, you can have my old Saelig. It will help you to verify communication protocols and baud rates for situations like this. If interested, PM me & we can take it from there. You might be able to find one on eBay, Amazon, or Craigslist (or whatever local online sellers site you have) for next to nothing, and with cheaper or even no shipping.
    So what's wrong with 160? it is chip address, A0, and isn't that fixed?
    Regarding the logic analyzer. I have that saelae thing.
    I can't get it work as I understand it should work - run continuously, monitor bytes, like scope does. it only has "run", it runs, fills up buffer in couple of seconds and stops - that's all. For that purposes, I bought a scope with built-in logic analyzer, which can run infinitely - Hantek DSO2D10 - but was able it to work only very low speeds, for protocol decoding.
    it a constant , pbp constants are 16 bits , i2c address are 8 bit
    use your logic analyzer
    So what should I write instead of 160?
    I've searched this forum, and people do use plain numbers in I2C eeprom write/read?
    Address var byte
    Address = 160
    Yeah, you really should spend some time getting that logic analyzer working and understand what it does. It's NOT an oscilloscope and although newer versions of the software does allow it to continously stream and display that's not really its intended purpose.
    Anyway, here's what I'd try (and I'd have the logic analyzer hooked up)
    Chip_Address	VAR BYTE
    Mem_Address	VAR WORD
    sda		VAR portb.1
    scl		VAR portb.0
    Chip_Address = 160
    ' The chip address must be a BYTE, this is the 160 + whatever A0-A2 is set to.
    ' The memory address must be a WORD for the 24C256, this is the address of the byte to written (or read)
    ' The data to be written is, in this case, a BYTE but it does not have to be, you can write words or arrays - which are obviously just multiple bytes...
    FOR Mem_Address = 0 to 12
      '        I/O  I/O       BYTE        WORD             BYTE
      I2CWrite sda, scl, Chip_Address, Mem_Address, [Mem_Address.LOWBYTE]
    NEXT
    And I'd like to thank Richard for the primers on PBP I2C the last couple of days, much appreciated!
    WOW! Finally it works!
    x var word
    y var byte
    adr var byte
    sda var portc.0
    scl var portc.1
    lcdout $fe, $01, " "
    adr=160
    for X=0 to 5
    I2CWrite sda, scl, adr, x, [x.lowbyte]
    lcdout $fe, $14, dec x
    next
    lcdout $fe, $1, "Complete:"
    lcdout $fe, $c0, " "
    for x=0 to 5
    i2cread sda, scl, adr, x, [y]
    lcdout $fe, $14, dec y
    next
    stop
    That's very good, this means now I can do a lot of LCD things!
    Thanks everyone!
    by the way, I tried to write 160 directly, instead of adr - also works.
    Now I need bitwise hex editor - one that allows editing hex file by bits, not by bytes. Any ideas
    Not directly and the following isn't a hex editor but if it's intended purpose is to create "content" for LCDs then https://www.mikroe.com/glcd-font-creator might be what you're looking for.
    Here's another one https://www.buydisplay.com/lcd-font-maker and another https://kapusta.cc/2020/03/20/fontedit/
    I've not used any of them, I know Richard is using the one from MikroE.
    Yes I know all these
    The issue with Mikroe "creation" is it, as everything else done by them, is written with left feet- need admin priviledges to run it, and it outputs fonts rotated by 90 degrees
    But currently I don't need font editor or graphics editor, I already have all that done, just need some hex editor to put everything into single file and adjust bits as necessary.
    Oh and another issue, which deserves separate topic is how to emulate LCDOUT statement, because it can't send $FE to display
    Not exact match, but HxD hex editor does the job almost in the way I see it.
    make an icon and assign admin to it , not a problem. running in compatibility mode can help if it wont save stuff w10 is ok without it
    glcd mode is data by column, tft mode is data by row , there is no problem
    you need to massage the data a little for pbp but its no big deal
    I don't see any mode selector in GLCD font creator from their website.
    don't think you looked too hard
    Name:  Screenshot 2022-01-17 081202.jpg
    Thanks a lot !
    At my system, that menu bar was not visible at all
    and in file/edit menu, they have no such setting...
  1. i2c non-eeprom examples?
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2010, 18:07
  2. Using eeprom for the first time- Help please
    Last Post: - 12th October 2009, 03:16
  3. Help with i2C eeprom
    Last Post: - 17th March 2006, 00:33
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
  5. I2C EEPROM Programming
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2005, 15:03
