varable index buffer setup unsing a varable
Results 1 to 8 of 8
    Default Re: varable index buffer setup unsing a varable
    Allocation of memory is done at compile time - not during runtime. Hence the content of a variable can not dictate the size of an array since the content of a variable, by definition, can change during runtime while the size of the array is allocated at compile time.
    You really can't resize arrays at runtime like what you're suggesting/expecting.
    Can you elaborate on what problem is is you're trying to solve?
    Feb 2012
    PERTH AUSTRALIA
    hi hendric
    its an exiting program that uses named constants to set the buffer size , the same named constants are used in multi locations to set other variables and math
    problem is now need to set those named constants to be variables , which is ok for all , except setup the size of array bytes
    i dont want to change all the code just for this issue , but not sure how i can get arround it nicely
    cheers sheldon
  1. HSERIN string starting index ?
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 4th July 2016, 23:54
  2. strange word varable array results
    Last Post: - 26th October 2015, 01:01
  3. Index a bit through a portion of a port
    By ecoli-557 in forum mel PIC BASIC Pro
    Last Post: - 12th March 2012, 23:22
  4. How to index Port variable
    By jpadin1 in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 11:36
  5. Access pin using index
    Last Post: - 16th October 2008, 03:34
