INA219 conversion time
Results 1 to 10 of 10
    Jun 2008
    Varese , Italy
    Default Re: INA219 conversion time
    thanks,
    let me try to explain....
    The correction is applied every 150 msec.
    let me say that at t=0 the correction is applied.
    At t+50 msec the power supply output is completely set.
    1> Should I wait 50 msec + 68 msec to get fitered data from INA219 ? ( without looking at the end of conversion bit ).
    2> what is the operation of the end of conversion bit ? Is it relevant to What start of conversion ? How is the "start of conversion" started ?
    3> what is the triggered mode ? I can not find any description on the ds.
    Thanks for helping.
    regards
    Ambro
    Does that mean you take a new "reading" every 150 ms ?
    in free run mode yes ,the "read" you get is the latest available
    in free run i don't see it has any useful function
    set the config to the triggered mode you desire
    data sheet
    BASIC ADC FUNCTIONS
    Writing any of the triggered convert modes into the
    Configuration Register (even if the desired mode is
    already programmed into the register) triggers a
    single-shot conversion. Table 7 lists the triggered
    convert mode settings
    Jun 2008
    Varese , Italy
    it is somewhat clear to me now . I will follow that inmplementation.
    > "set the config to the triggered mode you desire " : Yes, it is OK , but when does the trigger start pls ?
    Amb
    that is the trigger
    in continuous mode the end of conversion triggers the next conversion
    any other mode (single conversion) waits for user to retrigger it
    Jun 2008
    Varese , Italy
    so the trigger in triggered mode is the sending of the config register ?
    Amb
    Jun 2008
    Varese , Italy
    the procedure is to send the conf register and wait for the end of conversion bit and read the data : is this OK?
    Ambro
  1. INA219 interface help
    Last Post: - 19th June 2017, 14:23
  2. PIC 18F1330 - first time, hard time - blink that LED
    Last Post: - 1st March 2015, 22:33
  3. How best to time a pin state for extended periods of time
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 10th March 2011, 11:20
  4. DS1904 RTC - How to Convert Binary Time into Real Time/Date?
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2010, 10:45
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 15:04
