pulsin followed by serin2 problem
Results 1 to 8 of 8
    Dec 2003
    plano, texas usa
    Default reply
    INCLUDE "MODEDEFS.BAS"
    Define OSC 20 '20 meg clock`
    'define PULSIN_MAX 26000 ' MAX TIME TO READ PULSE 800US added
    ' Define LCD connections
    B2 var PORTB.2
    B1 VAR PORTB.1 ' FIRE LINE OR DECODED T"0"
    CNT VAR BYTE ' VARIBLE FOR COUNT OF PULSES
    PLENGTH1 VAR word ' VAR FOR FREQ MEASURE OF C2 first tone
    C2 var portc.2
    D4 var portd.4 'input pin
    plength2 var byte ' var for second freq
    ffid var word ' shot #
    cmnd var byte ' var for command number
    gosub radio_pwr_on
    main: input portb.0
    input portd.4
    gosub xmit_off
    gosub wait_for_t0
    wait_for_t0:
    if portb.0= 0 then wait_for_t0 ' loop until rssi goes high
    pulsin portd.4,1,PLENGTH1 ' MEASURE TIME C2 IS HIGH AND STORE
    IF PLENGTH1 > 255 AND PLENGTH1 < 270 THEN COUNTPULSes ' 42 usec error allowed
    gosub get_comnd
    ' made into sub routine get_cmnd
    'serin2 b2,16780,1000,wait_for_t0,[WAIT ("$$"),cmnd] ' get command wait $$ timeout 1 secs added
    'HSEROUT ["debug command = ",dec2 cmnd,13,10]
    GOTO wait_for_t0
    COUNTPULSES: COUNT portd.4,8,CNT ' COUNT PULSES FOR 10 MILISECS
    IF CNT > 6 and cnt < 9 THEN DETECT2
    'HSEROUT [" debug count = ",DEC3 cnt,13,10]
    GOTO wait_for_t0
    DETECT2:
    pulsin portd.4,1,PLENGTH2 ' MEASURE PERIOD HIGH
    IF PLENGTH2 > 115 AND PLENGTH2 < 130 THEN FIRE ' 20 usec error
    GOTO main
    FIRE: LOW B1
    HIGH B1
    PAUSE 10
    LOW B1
    ffid = ffid + 1
    if ffid =65535 then ffid = 0 ' reset ffid id exceeds word size
    HSEROUT ["fired ok ffid # =",dec5 ffid,13,10]
    HSEROUT ["debug fired plength 1 =",DEC3 plength1,13,10]
    HSEROUT ["debug fired plength 2 =",DEC3 plength2,13,10]
    HSEROUT ["debug fired count = ",DEC3 cnt,13,10]
    Radio_pwr_on: high portd.0
    pause 10
    low portd.0
    pause 500 ' wait for power to come up
    Radio_pwr_off: high portd.1
    pause 10
    low portd.1
    xmit_off : high portd.2
    pause 1
    xmit_on : low portd.2
    pause 50
    get_comnd: serin2 b2,16780,1000,wait_for_t0,[WAIT ("$$"),cmnd] ' get command wait $$ timeout 1 secs added
    command_decode: Select case cmnd
    case 1 ' command #1 T0 mode
    gosub xmit_on
    serout2 portc.2,84,["Buoy is in fire Mode",13,10]
    gosub xmit_off
    gosub wait_for_t0
    case 2
    gosub power_on_sbc ' command #2 turn on external power to device #1 SBC power on
    gosub xmit_on
    serout2 portc.2,84,["SBC power is on",13,10]
    gosub xmit_off
    case else
    End select
    power_on_sbc: high portb.5
    The problem is not with the serin2 command. It is the pulsin command with the addition of serin2 command. Everything was working until I added sub routine get_cmnd. The correct pulse stream is still coming in etc. It is not decoded properly at pulin command .Sorry for the mess of commented out code I have been trying everything I can think of.
    thanks
    Scott
    Dec 2003
    Wichita KS
    Hello Scott...
    Thats it...
    you are going SUBROUTINE and instead of branching to the END of the subroutine, you are branching OUT of it with a goto statement!!!
    THAT IS WRONG! (Cruising for a bruising.)...Maybe some others can verify ths for me and you.
    If I were you, I would *always* branch to the Return statement when you are into a Subroutine. Helps clear the stacks and all that good stuff. If I were to place my bet, it would be located here.
    Dwayne
    edit:
    Took another quick look at your code...(very quick)
    case else
    End select
    I am not sure about this.. Its been a while.. But usually you want your return AFTER the end select...
    Ability to Fly:
    Pilots that are Flying:
    It's amix of many things. One thing scratch my brain
        input PORTB.0
        input PORTD.4
        gosub xmit_off
        gosub wait_for_t0
    wait_for_t0:
    Take care of the Gosub / Return use. It's amazing how fast your program can behave weird when using few nested gosubs...
    the following snip is the source of your headache
    wait_for_t0:
        gosub get_comnd
        GOTO wait_for_t0
    get_comnd:
    easy to overflow the stack with this
    Lightbulb Gosub ...goto
    Hi, Steve
    have a look there : http://www.picbasic.co.uk/forum/showthread.php?t=1952
    I had a similar problem there, It seems that having GOTO',s outgoing and coming back to sub's did not work very well ...
    IF - Then, placed after the GOTO line ( in the sub ...) tests had always "yes" as a result ...
    This was added to a page boundary crossing ... ( worked on a 628, but no more on a 648 !!! )
    The solution for me was to place the program bits in good order ( all sub's at the end of the program and no "main" lines after ...
  1. Pulsin problem?
    By Skylar in forum mel PIC BASIC
    Last Post: - 27th May 2009, 15:40
  2. Serout2 and Serin2 problem
    By MrSafe in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 04:33
  3. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 13:52
  4. a problem RF Signal with PULSIN
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 16:42
  5. Serin2 problem on 16F876
    By jrt4fun in forum mel PIC BASIC Pro
    Last Post: - 29th May 2004, 17:24
