Replacing array member on the fly (big LCD characters idea)
Results 1 to 38 of 38
    Default Re: Replacing array member on the fly (big LCD characters idea)
    But I have issue with statement for dividing bit variable into two. Say I have %10101010. How should I divide it into two variables, one which has 5 bits from left, and another having 3 bits from right?
    Something like this?
    byte_var    var byte
    a_left         var byte
    b_left         var byte
    byte_var=%10101010
    a_left=byte_var & %11111000
    b_left=byte_var & %00000111
    Yes, but I was thinking about either <<, >> or DIG() operators...
    then combine accordingly like that:
    a_left=(byte_var & %11111000)>>3
    to make it right justified if needed.
    Found interesting thing. On power up, custom character area in normal LCD are empty, but on WS0010 OLED displays, they are filled with random numbers on power up.
    On the custom character, unless explicitly stated, you should consider it full of rubbish.
    Yes, but on LCD it is usually empty. On OLED - it is filled with different garbage on each power up.
    Anyways, problem solved, also did some nice animation, will post code and video later.
  1. String of characters(array) to decimal value
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th June 2012, 14:30
  2. write big text to lcd
    By isaac in forum General
    Last Post: - 8th October 2008, 01:45
  3. Big big big memory or tiny SDs!
    By Ron Marcus in forum Off Topic
    Last Post: - 25th May 2007, 18:02
  4. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  5. Replacing an ARRAY with EEPROM write to save space?
    Last Post: - 12th March 2005, 18:31
