Erroneous mathematical processing?
Results 1 to 11 of 11
    Dec 2010
    Melbourne Australia
    Default Erroneous mathematical processing?
    I'm currently doing a project that involves 2 separate pic processors on 2 separate boards doing completely different things. One of the boards is more avionics based and one of its tasks is to process GPS data to establish a required heading and distance to a destination point. I'm using the Cordic tools posted here by Walter a few years ago to help with the trig processing.
    Also, I like the idea of transitioning from previous 28 pin PICs to the 18F26K83 due to numerous virtues it has; however one thing I discovered attempting to implement it for this particular application is that the 18F26K83 and the Cordic routines don't see eye-to-eye and produce erroneous results. Well, for some reason the results (particularly for atan2) always appear to exceed the maximum.
    If I change to an 18F26K22 with exactly the same code (except the osc settings which are different from the 28K83), the routines work perfectly. This is just straight math processing, no external inputs to factor for this debugging.
    Troy
    Default Re: Erroneous mathematical processing?
    if thats not just a comment then start here
    Dec 2010
    Melbourne Australia
    Richard,
    No, it was just a comment. The solution for me was to use a different 28 pin PIC which I had no problem with.
    Nevertheless, I think it's importand to put these issues on public record for anyone else who might experience similar issues. Saying that, I'm happy to post pertinent code and whatever else if anyone is interested in identifying the cause.
    Cheers,
    Troy
    Dec 2010
    Melbourne Australia
    Okay here is the code for the PIC18F26K22:
    include "trig18.inc"
    Define OSC 16 'Clock will be configured to 16MHz
    OSCCON.6 = 1    ' Set Internal Osc to 16Mhz
    OSCCON.5 = 1    ' Set Internal Osc to 16Mhz
    OSCCON.4 = 1    ' Set Internal Osc to 16Mhz
    OSCCON.1 = 0    ' Use Internal Osc through Primary Clock (not Directly) to Access PLL Block
    OSCCON.0 = 0    ' Use Internal Osc through Primary Clock (not Directly) to Access PLL Block
    OSCTUNE.6 = 0   '16MHz osc - PLL Disabled
    'Configure AN2 as Analog Inputs (PortA2)
    ANSELA = %00000000 'Everything Digital
    ANSELB = %00000000 'Everything Else Digital
    ANSELC = %00000000 'Everything Else Digital
    TRISB.7 = 0 'Outout
    Serial_out  var PORTB.7   'Serial out pin for debugging/developing comms
    n   var byte
        pause 2000
        serout2 Serial_out,84, ["Test 123",13,10]
        Pause 1000
        ang=3000
        serout2 Serial_out,84, ["Ang: ",dec ang,13,10]
        'sincos example:
        'input ang in degrees.dd example: ang = 3000 (= 30.00 degrees)
        'call sincos
        'result: x = 15004 , Y = 25981
        'so, 15004/30000 = sin(ang) = 0.5001 and 25981/30000 = cos(ang) = 0.8660
        call sincos
        serout2 Serial_out,84, ["Sin ang: ",dec x,13,10]
        serout2 Serial_out,84, ["Cos ang: ",dec y,13,10]
        serout2 Serial_out,84, [13,10]
        x = 12000
        y = 8000
        serout2 Serial_out,84, ["x input: ",sdec x,13,10]
        serout2 Serial_out,84, ["y input: ",sdec y,13,10]
        call atan2
        'result: x = 14422 = hypotenuse or distance to x,y, y = angle to x,y in degrees.dd = 5631 (=56.31 degrees), ang = 6133 = radians 0 to 65535
        serout2 Serial_out,84, ["hypotenuse: ",sdec x,13,10]
        serout2 Serial_out,84, ["Ang in degrees.dd: ",sdec y/100,".",dec2 y,13,10]
        serout2 Serial_out,84, ["Ang in Rad: ",dec ang,13,10]
        x = -12000
        y = 8000
        call atan2
        'result: x = 14422 = hypotenuse or distance to x,y, y = angle to x,y in degrees.dd = 3037 (=303.70 degrees), ang = 26634 = radians 0 to 65535
        x = -12000
        y = -8000
        call atan2
        'result: x = 14422 = hypotenuse or distance to x,y, y = angle to x,y in degrees.dd = 23632 (=236.32 degrees), ang = 38899 = radians 0 to 65535
        x = 12000
        y = -8000
        call atan2
        'result: x = 14422 = hypotenuse or distance to x,y, y = angle to x,y in degrees.dd = 12367 (=123.67 degrees), ang = 59405 = radians 0 to 65535
    Goto main
    Results of the 18F26K22 code running on a 18F26K22:
    Here is the (COPY & PASTED) code for the PIC18F26K83 - note the only difference is the osc setting method:
    'Configure OSC postscaler to provide 16mhz system clock
    OSCFRQ = %0101
    Define OSC 16
    TRISB.7 = 0 'Outout
    n   var byte
        pause 2000
        Pause 1000
        ang=3000
        'sincos example:
        'call sincos
        call sincos
        x = 12000
        y = 8000
        call atan2
        x = -12000
        y = 8000
        call atan2
        x = -12000
        y = -8000
        call atan2
        x = 12000
        y = -8000
        call atan2
    Goto main
    (Erroneous) Results of the 18F26K83 code running on a 18F26K83:
    I've also attached my slightly modifed Trig18.inc file - only modified to allow the use of longs for PIC18s. Same inc file is used for both examples.
    i don't have one of those chips or the ability to sim it either but for a start
    rather than trying to cram those extra vars into bank0 {unnecessarily} i would modify the include this way
    for "LONG" compilation. if you did push the important vars out of bank 0 then it wont fly anymore
    '/*******************************************************************************'                  TRIG.inc for PIC18  Long   Version
    '* FUNCTION NAME:    sincos
    '* ARGUMENTS:        ang (angle deg.dd format example: 35999 = 359.99 deg)
    '* RETURNS:          x = sin(ang) , y = cos(ang)
    '* DESCRIPTION:      The angle is given in degrees.dd (see above)
    '*                   The function simultaneously calculates the sine
    '*                   and cosine of the angle as fractions of 30,000 (where 30,000
    '*                   equates to 1 and -30,000 equates to -1) and returns them in
    '*                   x, and y as x=sin(ang), y = cos(ang).
    '* EXAMPLE:          ang = 3000 (30.00 degrees) x = 15004 , Y = 25981
    '*                   so, 15004/30000 = 0.5001 and 25981/30000 = 0.8660
    '* FUNCTION NAME:    atan2
    '* ARGUMENTS:        int x (x-coordinate)
    '*                   int y (y-coordinate)
    '* RETURNS:          atan2 of x,y:(angle to x,y) and the hypotenuse (distance) of x,y
    '* DESCRIPTION:      Given an ordered pair of coordinates, the function
    '*                   simultaneously calculates the atan2 (the direction of the
    '*                   position as y degrees, and ang radians) and the square root of
    '*                   the sum of the squares of the coordinates (the magnitude of
    '*                   the position vector) as x
    '* NOTES:            (1) The accuracy of the returned values increases as the
    '*                   sizes of x and y increase. Consider multiplying both by a
    '*                   scaling factor before calling the function.
    '*                   (2) The function will fail for x and y values that result in
    '*                   magnitues greater than 32,767 (the size of a signed int).
    '* EXAMPLE:          atan2
    '*                   x = 25980, y = 15000;
    '*                   results:
    '*                   ang = angle in radians 0 to 65535
    '*                   x = distance = 30000 (same units as x and y)
    '*                   y = 6000 (angle in degrees 60.00 degrees)
    ; --- CORDIC TRIG LIBRARY ---
    ;http://www.chiefdelphi.com/media/papers/2016
    ; FILE NAME:        trig.inc
    ; AUTHOR:           Patrick Fairbank
    ; Last Modified     Feb 15, 2012 - fixed bug in sincos which calculated wrong
    ;                   result for sin and cos in quadrants 2,3 and 4. Thanks Martin!
    ;                   FEB. 15, 2009 to make it PicBasic compatible and added degree conversion
    ;                   Modified by Walter Dunckel (Scale Robotics Inc.) with help from Darrel Taylor
    ;                   http://www.scalerobotics.com/79-cordic-for-picbasic.html
    ; DESCRIPTION:      This file contains functions implementing the COORDIC
    ;                   algorithm, or how to get a 16 bit sin, cos, tan2 and hypotenuse result
    ; USAGE:            Add this file to your PicBasic Pro project using INCLUDE "TRIG.inc"
    ;                   and add a line with main: directly below the include line
    ;                   Then fill x,y values for atan2, or fill ang value for sincos
    ;                   then either CALL sincos or CALL atan2
    ; LICENSE:          Users are free to use, modify, and distribute this code
    ;                   as they see fit.
    ;    sincos: input ang, output x = sin(ang) and y = cos(ang)
    ;     atan2: input x and y coordinates
    ;     Output the calculated angle and hypotenuse values
    ;     as output:    y = angle in degrees, ang = angle in radians, x = hypotenuse
    '   Example output using TRIG.inc using hserout
    '   HSEROUT ["Angle = ",dec a,", sin(ang) = ",sdec x,", cos(ang) = ",sdec y,13]
    'Angle = 0, sin(ang) = 5, cos(ang) = 30000
    'Angle = 10, sin(ang) = 5209, cos(ang) = 29544
    'Angle = 20, sin(ang) = 10266, cos(ang) = 28188
    'Angle = 30, sin(ang) = 15004, cos(ang) = 25981
    'Angle = 40, sin(ang) = 19287, cos(ang) = 22981
    'Angle = 50, sin(ang) = 22983, cos(ang) = 19285
    'Angle = 60, sin(ang) = 25983, cos(ang) = 14998
    'Angle = 70, sin(ang) = 28188, cos(ang) = 10264
    'Angle = 80, sin(ang) = 29544, cos(ang) = 5207
    'Angle = 90, sin(ang) = 30000, cos(ang) = 3
    'Angle = 100, sin(ang) = 29543, cos(ang) = -5223
    'Angle = 110, sin(ang) = 28189, cos(ang) = -10276
    'Angle = 120, sin(ang) = 25974, cos(ang) = -15010
    'Angle = 130, sin(ang) = 22973, cos(ang) = -19293
    'Angle = 140, sin(ang) = 19274, cos(ang) = -22992
    'Angle = 150, sin(ang) = 14991, cos(ang) = -25989
    'Angle = 160, sin(ang) = 10249, cos(ang) = -28190
    'Angle = 170, sin(ang) = 5192, cos(ang) = -29546
    'Angle = 180, sin(ang) = -9, cos(ang) = -29999
    'Angle = 190, sin(ang) = -5216, cos(ang) = -29544
    'Angle = 200, sin(ang) = -10271, cos(ang) = -28184
    'Angle = 210, sin(ang) = -15013, cos(ang) = -25977
    'Angle = 220, sin(ang) = -19296, cos(ang) = -22976
    'Angle = 230, sin(ang) = -22987, cos(ang) = -19275
    'Angle = 240, sin(ang) = -25986, cos(ang) = -14992
    'Angle = 250, sin(ang) = -28199, cos(ang) = -10258
    'Angle = 260, sin(ang) = -29549, cos(ang) = -5195
    'Angle = 270, sin(ang) = -30000, cos(ang) = 5
    'Angle = 280, sin(ang) = -29544, cos(ang) = 5213
    'Angle = 290, sin(ang) = -28188, cos(ang) = 10266
    'Angle = 300, sin(ang) = -25981, cos(ang) = 15004
    'Angle = 310, sin(ang) = -22981, cos(ang) = 19287
    'Angle = 320, sin(ang) = -19283, cos(ang) = 22985
    'Angle = 330, sin(ang) = -14998, cos(ang) = 25983
    'Angle = 340, sin(ang) = -10260, cos(ang) = 28190
    'Angle = 350, sin(ang) = -5207, cos(ang) = 29544
    i       var byte     BANK0
    j       Var byte     BANK0
    quad    var byte     BANK0
    x       var word     bank0
    y       var word     bank0
    ang     var word     bank0
    dy      var word     bank0
    dx      var word     bank0
    atans   var word[15] bank0
    atans(0) = 16384
    atans(1) = 9672
    atans(2) = 5110
    atans(3) = 2594
    atans(4) = 1302
    atans(5) = 652
    atans(6) = 326
    atans(7) = 163
    atans(8) = 81
    atans(9) = 41
    atans(10) = 20
    atans(11) = 10
    atans(12) = 5
    atans(13) = 3
    atans(14) = 1
    goto OverTrig
    atan2:
        asm
            call atan2_sqrt
        endasm
        'convert to degrees.dd    y is degrees
        If ang < 16384 then y = 16383 - ang
        if ang > 16383 then
            y = 65535 - ang
            y = y + 16383     'correct 90 degrees for radian
        'y = y * 256     'divides radians to get degrees within 57ppm
        'y = div32 466    'degrees.dd is y, radians is ang
         y = y ** 36002
    sincos:
        'use angle as deg.dd for example 35999 is 359.99 degrees
    '    ang_temp = ang ' Store ang.
        if ang < 9001 then ang = 9000 - ang         'change degrees to radians
        if ang > 9000 then ang = 45000 - ang        'change degrees to radians
        'ang = ang * 466
        'ang = div32 256
        ang = ang */ 466
        asm
            call sin_cos
        endasm
    '    if ang_temp > 9000 then y = ~y + 1 ' Perform 2's complement of y if ang > 90 for cos(ang).
    asm
    ; Calculates the sine and cosine of the given angle
    sin_cos:
      ; Initialize _x to 18218
      movlw 0x2a
      movwf _x
      movlw 0x47
      movwf _x+1
      ; Initialize _y to 0
      clrf _y
      clrf _y+1
      ; Initialize _quad to 0
      clrf _quad
      ; Check if the angle is greater than 16383 (90°)
    sc_check_greaterthan:
      btfss _ang+1, 7
      btfss _ang+1, 6
      bra sc_check_lessthan
      bra sc_adjust_quad2
      ; Check if the angle is less than -16384 (-90°)
    sc_check_lessthan:
      btfsc _ang+1, 7
      btfsc _ang+1, 6
      bra sc_setup_end
      ; If the angle is in quadrant 3, adjust it to quadrant 4
    sc_adjust_quad3:
      negf _ang
      bc sc_negate_quad3
      comf _ang+1
      bra sc_adjust_end
      ; If the low byte negation causes a carry, negate the upper byte
    sc_negate_quad3:
      negf _ang+1
      bra sc_adjust_end
      ; If the angle is in quadrant 2, adjust it to quadrant 1
    sc_adjust_quad2:
      comf _ang
      comf _ang+1
      ; Toggle the sign bit and set the '_quad' flag
    sc_adjust_end:
      btg _ang+1, 7
      setf _quad
      ; Multiply the angle by 2 to get better resolution
    sc_setup_end:
      bcf STATUS, 0
      rlcf _ang
      rlcf _ang+1
      ; Set up the main loop
    sc_loop_start:
      clrf _i
      lfsr FSR0, _atans
        ; The main loop label
    sc_loop:
        movff _x, _dy
        movff _x+1, _dy+1
        movff _i, _j
        movf _j
        bz sc_bs_x_done
          ; Loop to shift _dy right
    sc_bs_x_loop:
          bcf STATUS, 0
          rrcf _dy+1
          rrcf _dy
          btfsc _x+1, 7
          bsf _dy+1, 7
          decfsz _j
          bra sc_bs_x_loop
        ; Calculate what needs to be added to _x
    sc_bs_x_done:
        movff _y, _dx
        movff _y+1, _dx+1
        movff _i, _j
        movf _j
        bz sc_do_rotation
          ; Loop to shift _dx right
    sc_bs_y_loop:
          bcf STATUS, 0
          rrcf _dx+1
          rrcf _dx
          btfsc _y+1, 7
          bsf _dx+1, 7
          decfsz _j
          bra sc_bs_y_loop
        ; Perform adding operations on _x, _y and _ang
    sc_do_rotation:
        btfss _ang+1, 7
        bra sc_sub_angle
        ; If _ang is negative
        movf POSTINC0, W
        addwf _ang
        movf POSTINC0, W
        addwfc _ang+1
        movf _dx, W
        addwf _x
        movf _dx+1, W
        addwfc _x+1
        movf _dy, W
        subwf _y
        movf _dy+1, W
        subwfb _y+1
        bra sc_loop_bottom
        ; If _ang is positive
    sc_sub_angle:
        movf POSTINC0, W
        subwf _ang
        movf POSTINC0, W
        subwfb _ang+1
        movf _dx, W
        subwf _x
        movf _dx+1, W
        subwfb _x+1
        movf _dy, W
        addwf _y
        movf _dy+1, W
        addwfc _y+1
        ; Increment the counter and exit the loop if done
    sc_loop_bottom:
        incf _i
        movlw 0x0f
        cpfseq _i
        bra sc_loop
      ; Negate _x if it was initially in quadrant 2 or 3
    sc_finished:
      btfss _quad, 7
      bra sc_output
      negf _x
      bc sc_negate_x
      comf _x+1
      bra sc_output
    sc_negate_x:
      negf _x+1
      ; Output the calculated _x and _y values
    sc_output:
    ; Calculates the magnitude and direction of the given ordered pair
    atan2_sqrt:
      ; Initialize _ang to 0
      clrf _ang
      clrf _ang+1
      clrf _quad
      ; If the point is in quadrant 2 or 3, make _x positive and set flag
    as_check_negative:
      btfss _x+1, 7
      bra as_shift_x
      setf _quad
      negf _x
      bc as_negate_x
      comf _x+1
      bra as_shift_x
    as_negate_x:
      negf _x+1
      ; Divide the _x coordinate by 2 to prevent overflowing
    as_shift_x:
      bcf STATUS, 0
      rrcf _x+1
      rrcf _x
      ; Divide the _y coordinate by 2 to prevent overflowing
    as_shift_y:
      bcf STATUS, 0
      rrcf _y+1
      rrcf _y
      btfsc _y+1, 6
      bsf _y+1, 7
    as_loop_start:
      clrf _i
      lfsr FSR0, _atans
    as_loop:
        movff _x, _dy
        movff _x+1, _dy+1
        movff _i, _j
        movf _j
        bz as_bs_x_done
    as_bs_x_loop:
          bcf STATUS, 0
          rrcf _dy+1
          rrcf _dy
          btfsc _x+1, 7
          bsf _dy+1, 7
          decfsz _j
          bra as_bs_x_loop
    as_bs_x_done:
        movff _y, _dx
        movff _y+1, _dx+1
        movff _i, _j
        movf _j
        bz as_do_rotation
    as_bs_y_loop:
          bcf STATUS, 0
          rrcf _dx+1
          rrcf _dx
          btfsc _y+1, 7
          bsf _dx+1, 7
          decfsz _j
          bra as_bs_y_loop
        ; Perform adding operations on _x, _y and _ang, shifting the _atans right one
    as_do_rotation:
        movff POSTINC0, PRODL
        movff POSTINC0, PRODH
        bcf STATUS, 0
        rrcf PRODH
        rrcf PRODL
        btfsc  _y+1, 7
        bra as_sub_angle
        ; If _y is positive
        movf PRODL, W
        addwf _ang
        movf PRODH, W
        addwfc _ang+1
        movf _dx, W
        addwf _x
        movf _dx+1, W
        addwfc _x+1
        movf _dy, W
        subwf _y
        movf _dy+1, W
        subwfb _y+1
        bra as_loop_bottom
        ; If _y is negative
    as_sub_angle:
        movf PRODL, W
        subwf _ang
        movf PRODH, W
        subwfb _ang+1
        movf _dx, W
        subwf _x
        movf _dx+1, W
        subwfb _x+1
        movf _dy, W
        addwf _y
        movf _dy+1, W
        addwfc _y+1
    as_loop_bottom:
        incf _i
        movlw 0x0e
        cpfseq _i
        bra as_loop
      ; Multiply the _x value by 19898 and divide by 2^14 to scale it
    as_scale_x:
      movff _x, _dx
      movff _x+1, _dx+1
      movlw 0xba
      mulwf _dx
      movff PRODH, _x
      movlw 0x4d
      mulwf _dx+1
      movff PRODH, _dy
      movff PRODL, _x+1
      movlw 0xba
      mulwf _dx+1
      movf PRODL, W
      addwf _x, F
      movf PRODH, W
      addwfc _x+1, F
      clrf WREG
      addwfc _dy, F
      movlw 0x4d
      mulwf _dx
      movf PRODL, W
      addwf _x, F
      movf PRODH, W
      addwfc _x+1, F
      clrf WREG
      addwfc _dy, F
      movlw 0x06
      movwf _j
    as_scale_bs_loop:
        bcf STATUS, 0
        rrcf _dy
        rrcf _x+1
        rrcf _x
        decfsz _j
        bra as_scale_bs_loop
      ; Check if the quadrant was originally changed
    as_check_quad:
      btfss _quad, 7
      bra as_output
      btfss _ang+1,7
      bra as_adjust_quad1
      ; If the angle is in quadrant 4, adjust it to quadrant 3
    as_adjust_quad4:
      negf _ang
      bc as_negate_quad4
      comf _ang+1
      bra as_adjust_end
    as_negate_quad4:
      negf _ang+1
      bra as_adjust_end
      ; If the angle is in quadrant 1, adjust it to quadrant 2
    as_adjust_quad1:
      comf _ang
      comf _ang+1
    as_adjust_end:
      btg _ang+1, 7
    as_output:
    endasm
    OverTrig:  'jump over code
    Dec 2010
    Melbourne Australia
    Richard,
    Thanks for the tip. I've modified my trig file accordingly. Alas though, it didn't fix the issue with the ...K83 though.
    Troy
    maybe a config issue , there is not much i can see that would not work in the asm stuff unless the 8x8 mult works differently
    you could try this , clutching at straws
    the code just assumes bank0
    atan2_sqrt:
      banksel 0
      clrf _ang
      clrf _ang+1
    sin_cos:
     banksel 0
      movlw 0x2a
      movwf _x
      movlw 0x47
      movwf _x+1
    Aug 2011
    The K83 has its SFR registers located at the top of ram, and the common ones are in bank 63 ($3F00).
    The MOVFF instruction only uses 12-bits of addressing, so the highest address it can reach is $0FFF.
    To reach the upper registers past that you have to use the MOVFFL instruction instead. It's a 3-word instruction
    (vs 2 for MOVFF) that can reach the entire ram space. I mention that since that could require changing any
    jumps or gotos in the asm code as well.
    This would effect any code like the following:
    For the K83 (and K42) that would have to be:
        movffl POSTINC0, PRODL
        movffl POSTINC0, PRODH
    You also have to be using a version of MPASM that supports this instruction (MPASM v5.71 or later)
    Thanks tumbleweed
    Troy try this
    '                  TRIG.inc for ALL PIC18's  with  or without longs
    '* EXAMPLE:          atan2
    '*                   results:
    ;                   as they see fit.
    #IFDEF MOVFFL
    DEFINE MOXVE MOVFFL
    #ELSE
    DEFINE MOXVE MOVFF
    #ENDIF
    i       var byte     BANK0
    j       Var byte     BANK0
    quad    var byte     BANK0
    x       var word     bank0
    y       var word     bank0
    ang     var word     bank0
    dy      var word     bank0
    dx      var word     bank0
    atans(0) = 16384
    atans(1) = 9672
    atans(2) = 5110
    atans(3) = 2594
    atans(4) = 1302
    atans(5) = 652
    atans(6) = 326
    atans(7) = 163
    atans(8) = 81
    atans(9) = 41
    atans(10) = 20
    atans(11) = 10
    atans(12) = 5
    atans(13) = 3
    atans(14) = 1
    goto OverTrig
    atan2:
        asm
            call atan2_sqrt
        endasm
        if ang > 16383 then
            y = 65535 - ang
         y = y ** 36002
    sincos:
        'ang = ang * 466
        'ang = div32 256
        ang = ang */ 466
        asm
            call sin_cos
        endasm
    asm
    sin_cos:
      movlw 0x2a
      movwf _x
      movlw 0x47
      movwf _x+1
      clrf _y
      clrf _y+1
      clrf _quad
      btfss _ang+1, 7
      btfss _ang+1, 6
      bra sc_adjust_quad2
    sc_check_lessthan:
      btfsc _ang+1, 7
      btfsc _ang+1, 6
      bra sc_setup_end
    sc_adjust_quad3:
      negf _ang
      bc sc_negate_quad3
      comf _ang+1
      bra sc_adjust_end
    sc_negate_quad3:
      negf _ang+1
      bra sc_adjust_end
    sc_adjust_quad2:
      comf _ang
      comf _ang+1
    sc_adjust_end:
      btg _ang+1, 7
      setf _quad
    sc_setup_end:
      bcf STATUS, 0
      rlcf _ang
      rlcf _ang+1
    sc_loop_start:
      clrf _i
      lfsr FSR0, _atans
    sc_loop:
        movff _x, _dy
        movff _x+1, _dy+1
        movff _i, _j
        movf _j
        bz sc_bs_x_done
    sc_bs_x_loop:
          bcf STATUS, 0
          rrcf _dy+1
          rrcf _dy
          btfsc _x+1, 7
          bsf _dy+1, 7
          decfsz _j
          bra sc_bs_x_loop
    sc_bs_x_done:
        movff _y, _dx
        movff _y+1, _dx+1
        movff _i, _j
        movf _j
        bz sc_do_rotation
    sc_bs_y_loop:
          bcf STATUS, 0
          rrcf _dx+1
          rrcf _dx
          btfsc _y+1, 7
          bsf _dx+1, 7
          decfsz _j
          bra sc_bs_y_loop
    sc_do_rotation:
        btfss _ang+1, 7
        bra sc_sub_angle
        movf POSTINC0, W
        addwf _ang
        movf POSTINC0, W
        addwfc _ang+1
        movf _dx, W
        addwf _x
        movf _dx+1, W
        addwfc _x+1
        movf _dy, W
        subwf _y
        movf _dy+1, W
        subwfb _y+1
        bra sc_loop_bottom
    sc_sub_angle:
        movf POSTINC0, W
        subwf _ang
        movf POSTINC0, W
        subwfb _ang+1
        movf _dx, W
        subwf _x
        movf _dx+1, W
        subwfb _x+1
        movf _dy, W
        addwf _y
        movf _dy+1, W
        addwfc _y+1
    sc_loop_bottom:
        incf _i
        movlw 0x0f
        cpfseq _i
        bra sc_loop
    sc_finished:
      btfss _quad, 7
      bra sc_output
      negf _x
      bc sc_negate_x
      comf _x+1
      bra sc_output
    sc_negate_x:
      negf _x+1
    sc_output:
    atan2_sqrt:
      clrf _ang
      clrf _ang+1
      clrf _quad
    as_check_negative:
      btfss _x+1, 7
      bra as_shift_x
      setf _quad
      negf _x
      bc as_negate_x
      comf _x+1
      bra as_shift_x
    as_negate_x:
      negf _x+1
    as_shift_x:
      bcf STATUS, 0
      rrcf _x+1
      rrcf _x
    as_shift_y:
      bcf STATUS, 0
      rrcf _y+1
      rrcf _y
      btfsc _y+1, 6
      bsf _y+1, 7
    as_loop_start:
      clrf _i
      lfsr FSR0, _atans
    as_loop:
        movff _x, _dy
        movff _x+1, _dy+1
        movff _i, _j
        movf _j
        bz as_bs_x_done
    as_bs_x_loop:
          bcf STATUS, 0
          rrcf _dy+1
          rrcf _dy
          btfsc _x+1, 7
          bsf _dy+1, 7
          decfsz _j
          bra as_bs_x_loop
    as_bs_x_done:
        movff _y, _dx
        movff _y+1, _dx+1
        movff _i, _j
        movf _j
        bz as_do_rotation
    as_bs_y_loop:
          bcf STATUS, 0
          rrcf _dx+1
          rrcf _dx
          btfsc _y+1, 7
          bsf _dx+1, 7
          decfsz _j
          bra as_bs_y_loop
    as_do_rotation:
        MOXVE POSTINC0, PRODL
        MOXVE POSTINC0, PRODH
        bcf STATUS, 0
        rrcf PRODH
        rrcf PRODL
        btfsc  _y+1, 7
        bra as_sub_angle
        ; If _y is positive
        movf PRODL, W
        addwf _ang
        movf PRODH, W
        addwfc _ang+1
        movf _dx, W
        addwf _x
        movf _dx+1, W
        addwfc _x+1
        movf _dy, W
        subwf _y
        movf _dy+1, W
        subwfb _y+1
        bra as_loop_bottom
        ; If _y is negative
    as_sub_angle:
        movf PRODL, W
        subwf _ang
        movf PRODH, W
        subwfb _ang+1
        movf _dx, W
        subwf _x
        movf _dx+1, W
        subwfb _x+1
        movf _dy, W
        addwf _y
        movf _dy+1, W
        addwfc _y+1
    as_loop_bottom:
        incf _i
        movlw 0x0e
        cpfseq _i
        bra as_loop
    as_scale_x:
      movff _x, _dx
      movff _x+1, _dx+1
      movlw 0xba
      mulwf _dx
      MOXVE PRODH, _x
      movlw 0x4d
      mulwf _dx+1
      MOXVE PRODH, _dy
      MOXVE PRODL, _x+1
      movlw 0xba
      mulwf _dx+1
      movf PRODL, W
      addwf _x, F
      movf PRODH, W
      addwfc _x+1, F
      clrf WREG
      addwfc _dy, F
      movlw 0x4d
      mulwf _dx
      movf PRODL, W
      addwf _x, F
      movf PRODH, W
      addwfc _x+1, F
      clrf WREG
      addwfc _dy, F
      movlw 0x06
      movwf _j
    as_scale_bs_loop:
        bcf STATUS, 0
        rrcf _dy
        rrcf _x+1
        rrcf _x
        decfsz _j
    as_check_quad:
      btfss _quad, 7
      bra as_output
      btfss _ang+1,7
      bra as_adjust_quad1
    as_adjust_quad4:
      negf _ang
      bc as_negate_quad4
      comf _ang+1
      bra as_adjust_end
    as_negate_quad4:
      negf _ang+1
      bra as_adjust_end
    as_adjust_quad1:
      comf _ang
      comf _ang+1
    as_adjust_end:
      btg _ang+1, 7
    as_output:
    endasm
    Dec 2010
    Melbourne Australia
    Copy and pasted into a new inc file but still no luck. The hyp is different but still wrong.
    Dec 2010
    Melbourne Australia
    BTW: I tried compiling the same code but with the "Use Compiler Long Words" checkbox un-ticked this time in the Microcode Studios settings.
    Still erroneous results, but curiously different:
    Troy
  1. Replies: 4
    Last Post: - 19th October 2016, 12:02
  2. Mathematical calculation
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 27th October 2013, 00:07
  3. how to get the mathematical function sin
    By minssss in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 17:13
  4. Mathematical problem
    By iugmoh in forum General
    Last Post: - 25th January 2008, 18:24
  5. Mathematical Precedence
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 21:44
