Power Saving on 16f628
Results 1 to 5 of 5
    May 2012
    Merseyside, UK
    Default Power Saving on 16f628
    Hi All
    Thank you for putting up with me
    My recent Bluetooth project is sitting on a 12v Battery ... I am now looking to save some valuable Ah ...
    Suggestions as to how are welcome
    Changes in the __Config maybe ?
    Pulling unused inputs to Ov maybe?
    project is currently working fine 👍
    Just need to save battery where I can
    Andy
    Default Re: Power Saving on 16f628
    Just my 2 cents here. On most of my 16F819 projects idling current is about 5mA. When I add NAP 0, it drops to 1/2 mA. I put it at the top of the program where it's waiting for something such as a button press.
    wake on serial input example, you would need to add code to eliminate floating inputs and disable unused "modules" to get the
    absolute minimum power use.
    this wakes on any serial input and goes back to sleep if an "A" is not received
    ;16f628a #CONFIG
      __config   _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_ON & _BODEN_ON & _LVP_OFF & DATA_CP_OFF & _CP_OFF
    include "dt_ints-14.bas"
    DEFINE OSC 8
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 12  ' 9600 Baud @ 8MHz, 0.16%
    asm
    INT_LIST macro
           INT_HANDLER RX_INT  , _RX, asm,NO
          INT_CREATE
    wsave var byte $20 system
    wsave1 var byte $a0 system ; If device has RAM in bank1
    wsave2 var byte $120 system ; If device has RAM in bank2
    LED VAR PORTB.7
    TRISB=%01111111 'Make RB0 input
    BUFF var byte
    FLAG var byte
    CMCON=7
    FLAG=0
    LED=1
    PAUSE 500
    HSEROUT["READY",13,10]
    @ int_enable RX_INT
    LED=0
    @ SLEEP
    LED=1
      IF (FLAG) THEN
        GOSUB somewhere
    PAUSE 50
    Goto Main
    Somewhere:
       HSEROUT["I got an A", 13,10]
       FLAG=0
    RX:
    asm
        MOVLW "A"
        BANKSEL RCREG
        SUBWF  RCREG,W
        BTFSS  STATUS,Z
        GOTO EXT
        BANKSEL _FLAG
        BSF   _FLAG,0
    EXT
        BANKSEL 0
        INT_RETURN
    endasm
    May 2012
    Merseyside, UK
    Default Re: Power Saving on 16f628A
    ;16f628a #CONFIG
    All good help thank you will try ..... Just re:- Above.... I have done the same but turned BODEN_OFF
    All works ok ... And does give me a little saving
    BR
    Andy
    May 2012
    Merseyside, UK
    Thank You
    Andy
  1. PIC Power saving
    By comwarrior in forum Code Examples
    Last Post: - 18th December 2010, 02:08
  2. Power multiple electronics from 1 power source
    By koossa in forum Off Topic
    Last Post: - 2nd September 2010, 09:49
  3. ADC Max Impendance and Power saving
    By Michael Wakileh in forum Schematics
    Last Post: - 28th June 2009, 20:29
  4. Saving variable(s) contents before power is removed
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 18:26
  5. [16F871] Power on RA4 before power on vdd?
    By Buzzz in forum Schematics
    Last Post: - 5th September 2005, 17:48
