HSEROUT of array of data with termination on a null
Results 1 to 19 of 19
    Aug 2011
    Default Re: HSEROUT of array of data with termination on a null
    ...trying to offload up to 256 MB of data from a flash chip to VB on laptop over 115.2k BAUD connection.
    At 115K it takes ~22ms to send 256 bytes assuming back to back transfers. At 9600 it's over 10x longer than that.
    You could use background serial transfers while you do something to read that flash chip, but you're going to have to know what you're doing to get all that working.
    you could...... forget hserout, then you can make your data buffer bigger, use longs if your pic can do it.... 18f's, then write data to ram or program mem location that can store more than 256 bytes, then access data knowing starting location and loop through data with TX routine number of chars to send. I have sent 10K bytes at a time serially at 115K over 8266esp
    I would dig up some code if interested in that technique.
  1. Null statement (NOP or CONTINUE)
    By RussMartin in forum General
    Last Post: - 4th February 2009, 21:28
  2. How to get ASCII data in array.
    By Ioannis in forum Serial
    Last Post: - 6th November 2008, 20:14
  3. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 1st September 2006, 23:07
  4. 8 data and parity using HSERIN, HSEROUT
    By Smity42 in forum Serial
    Last Post: - 3rd April 2006, 01:45
  5. Array data being corrupted
    By caverman in forum mel PIC BASIC Pro
    Last Post: - 17th March 2006, 04:22
