PWM/HPWM Stepper Motor Controller
Results 1 to 34 of 34
    Jan 2008
    Pennsylvania
    Default Re: PWM/HPWM Stepper Motor Controller
    David,
    At your desired conveyor belt speed, what approximate frequency are you generating? Is it 100Hz, 1000Hz, 5000Hz?
    For the CCP module you could use the HPWM command but if you want to implement acceleration then I would ditch HPWM and set the registers manually.
    Henrik, Thanks.... well that is going to be trial and error at this point. I actually am going to have to hook up my conveyer belt and use the pulse method I've been using so I can get an idea. i need to see the spray turned on and how fast I can make the part travel under the spray and get it coated good. It's not going to be traveling very fast I'm sure. When I manually spray my parts with my detail sprayer I'm not moving my hand very fast over the parts. At this point I really could not say at how many feet per minute or anything like that. My gearing ratio is going to affect that too. Right now I have about a 1:1 ratio on there. Now that I see what I am working on is do-able I've ordered my aluminum framing material so I can start to bring things together. The speed of the belt will be constant. Start - go a little distance, Stop
    What do you think about the 12F752 just to tinker around with the HPWM... I asked because I never worked with PWM before just wanted to make sure that pic will work. Reading the specs and looking at some sample code I think just to mess around that will work.
    David
    I see no reason for it not to work.
    But with an 8-pin device you're quickly running out of pins, step pulses out, solenoid drivers, perhaps a sensor of some sort to detect the items on the belt, a start/stop button, perhaps some means to output debug information or parts count to a LCD? It adds up...
    If you already have it go ahead and play, if you're ordering it and there's no real reason for an 8-pin device then perhaps something like the 16F1825? More pins, more FLASH, more RAM and an UART. It does also cost more but I reccon you're not building thousands of these so it doesn't matter much :-)
    Jan 2008
    Pennsylvania
    Henrik, agreed about the need for the extra pins. I will be switching to the 16F series for sure I've already thought of the extra pins I will need stop/start, Jog, , manual speed, lcd, direction, sensors, etc... I just quickly looked on microchip part picker and I am pretty sure I had the 12F but I didn't see any on their list that had HPWM in the 16F series that I had and I want to get started and have things worked out. Going to order some 16F's now which will take about a week to get here, I don't want to wait to see it work. I have a good bit of time to test things before I would actually put my conveyer to use I still need to work on the frame and belt mechanism itself. The framing material will be here in about a week I will keep this thread going as I progress through adding different functions to the PIC
    David
    Jan 2008
    Pennsylvania
    This is going to be a stupid question and one I could answer myself by just testing it but I will ask anyway. If the stepper is set to 1600 pulses per revolution and I send it 800 pulses I'm assuming it is going to go around half way and stop... see a stupid question the I guess figuring in the gear ratio you could get very small movement like in a 3D printer (I'm not doing a 3D printer but I thought it would be a good example.)
    David
    Yes, exactly so :-)
    That's sort of the idea behind the stepper motor - that you can relatively precisely control both the speed and the position without needing some sort of feedback device and "complicated" control algorithms. For that reason steppers have been and are being used in a LOT of mechatronic devices like printers, robots, machining equipment, optical stages, light effects, throttle valves in cars and many many other things.
    Jan 2008
    Pennsylvania
    Yes, exactly so :-)
    Henrik thank you I thought so. By the way if anyone is interested I got the power supply and dual dc/dc converter and they work beautifully. I have 24v for the stepper, 12v for the solenoids and 5v for my main board.
    Power Supply
    Tunable dc/dc converter
    Jan 2008
    Pennsylvania
    Argh... RTFDS! David haha the 12F683 that I have been testing with has PWM in it whats wrong with me. I do have some 16F pics coming to give me more input/output which I know I will need
  1. Motor Stepper Example
    Last Post: - 3rd January 2015, 18:58
  2. Need guidance with DC motor controller - PWM & H-Bridge
    By rfetech in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 04:33
  3. Another Stepper motor controller
    By aratti in forum Code Examples
    Last Post: - 19th December 2009, 10:52
  4. Stepper motor controller
    By aratti in forum Schematics
    Last Post: - 24th April 2009, 17:43
  5. Stepper Motor Program
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 27th November 2007, 03:56
