PWM/HPWM Stepper Motor Controller
Results 1 to 34 of 34
    Jan 2008
    Pennsylvania
    Default Re: PWM/HPWM Stepper Motor Controller
    These type of controllers require a digital direction input, an digital enable input, and last but not least, a digital step input. The controller will advance the motor 1 step for every digital input pulse. Depending on the steps per rev. setting made thru the dip switches.
    Agreed..... I think I understood that what I am missing is if I am am going to send PWM/HPWM out on one of the pins (lets say as an example I set it up for 200 pules per revolution) is that 200 pulses per second or? How if I set it up for 200 pulses per revolution would you regulate the speed?
    David
    This is a simple way to generate step pulses
    Count = 1
    While count < 2000  ' Send 2000 pulses rotate motor 10 times
    Latx = 1 'Output 10us pulse to stepper drive
    pauseus 10
    Latx =0
    Count = Count +  1
    pause  10 ' use this delay to slow down or speed up the motor
     Wend
    Jan 2008
    Pennsylvania
    Thanks Mark_S that makes sense to me know
    David
    David, at 200 steps per revelolution the motor will run rough. Once you get it running change the dip switches on the driver to 1/8th step or 1600 pulses/rev. It will run much smoother.
    Mark
    Jan 2008
    Pennsylvania
    Mark thanks for the info. I'm new to working with stepper motors and their controllers. Seems a little easier to use a controller than to do all the programming to pulse all 4 inputs on the motor manually.
    It looks like the NEMA rating just has to do with the size of the front or something here is the NEMA 23 one I got. It looks like this is rated 2.8 amps so would you mind I should set my controller dip switches to reflect 2.8 amps right?
    David
    Quote Originally Posted by DavyJones View Post
    David
    It's depends on your power supply voltage and what you are driving with the motor. I would start at half of the rated current and see how it works. Yes the NEMA number is the mounting size. What are you driving with your motor?
    Jan 2008
    Pennsylvania
    Quote Originally Posted by mark_s View Post
    I'm going to be driving a drive pulley for a conveyer belt so things will be going slow don't need a lot of torque or speed.
    thanks I will start off at half power and 200 rev's see how things go
    David
  1. Motor Stepper Example
    Last Post: - 3rd January 2015, 18:58
  2. Need guidance with DC motor controller - PWM & H-Bridge
    By rfetech in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 04:33
  3. Another Stepper motor controller
    By aratti in forum Code Examples
    Last Post: - 19th December 2009, 10:52
  4. Stepper motor controller
    By aratti in forum Schematics
    Last Post: - 24th April 2009, 17:43
  5. Stepper Motor Program
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 27th November 2007, 03:56
