BME280 sensor.
Results 1 to 20 of 20
Thread: BME280 sensor.
    Default Re: BME280 sensor.
    Richard,
    Your change to the "cast routine" saved some 400bytes worth of code space and probably also executes faster. Thanks!
    Yeah, both of my sensors reports temperature which I believe to be 2-3°C above actual. I don't know if it's due to self heating of the sensor itself, the PCB assembly or something else but the fact that they run different code but both reports values very close to each other makes me fairly confident in the code.
    Just now when I started it up again, the humidity reading was way high, around 70%.
    A restart fixed it and it's now around 42% which is more inline with the other sensor. This seems to happen now and then and I'm not sure what's going on.
    Amazing piece of work by both of you! Thanks a lot for sharing!
    seems possible , the fact that the bmp ver is less "hot" tallies with its lower power use [hum sensor nearly doubles the consumption]
    my esp code uses forced mode letting it sleep between readings and fares no better anyway, so maybe it is what it is
    data sheet says writes to config reg 0xf5 may be ignored if device not in sleep mode, maybe por does not always achieve that.
    cannot say i have seen any issues with humidity readings from esp code.
    the pressure readings are consistent within 2hpa spread across the chips i have
    i find just reading the config reg 0xf5 can cause the device to stop responding completely some times
  1. MQ-7 Sensor
    By chipmaker in forum General
    Last Post: - 9th June 2017, 00:05
  2. Speed Sensor Anyone???
    By Ramius in forum General
    Last Post: - 18th May 2012, 04:37
  3. Pir Sensor
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 20th May 2009, 16:34
  4. Accelerometer Sensor
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 13:26
  5. Replies: 6
    Last Post: - 18th January 2008, 08:17
