i posted this some time ago and the topic seems to have disappeared , i can't remember who's post it was and the context
but the calcs work but for the ones that need 64bit vars
' DEVICE CONFIGURATION
    CONFIG  OSC = IRCIO
    CONFIG  FCMEN = OFF
    CONFIG  IESO = OFF
    CONFIG  PWRTEN = OFF
    CONFIG  BOREN = OFF
    CONFIG  BORV = 20
    CONFIG  WDTEN = OFF
    CONFIG  WDPS = 512
    CONFIG  WINEN = OFF
    CONFIG  PWMPIN = OFF
    CONFIG  LPOL = HIGH           ; PWM0, 2, 4 and 6 are active-high
    CONFIG  HPOL = HIGH           ; PWM1, 3, 5 and 7 are active-high
    CONFIG  T1OSCMX = ON          ; Low-power Timer1 operation when microcontroller is in Sleep mode
    CONFIG  MCLRE = OFF
    CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
    CONFIG  LVP = OFF             ; Low-voltage ICSP disabled
    CONFIG  DEBUG = OFF           ; Background debugger disabled; RB6 and RB7 configured as general purpose I/O pins
    CONFIG  CP0 = OFF             ; Block 0 (000200-000FFFh) not code-protected
    CONFIG  CP1 = OFF             ; Block 1 (001000-001FFF) not code-protected
    CONFIG  CP2 = OFF             ; Block 2 (002000-002FFFh) not code-protected
    CONFIG  CP3 = OFF             ; Block 3 (003000-003FFFh) not code-protected
    CONFIG  CPB = OFF             ; Boot Block (000000-0001FFh) not code-protected
    CONFIG  WRT0 = OFF            ; Block 0 (000200-000FFFh) not write-protected
    CONFIG  WRT1 = OFF            ; Block 1 (001000-001FFF) not write-protected
    CONFIG  WRT2 = OFF            ; Block 2 (002000-002FFFh) not write-protected
    CONFIG  WRT3 = OFF            ; Block 3 (003000-003FFFh) not write-protected
    CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
    CONFIG  WRTB = OFF            ; Boot Block (000000-0001FFh) not write-protected
    CONFIG  EBTR0 = OFF           ; Block 0 (000200-000FFFh) not protected from table reads executed in other blocks
    CONFIG  EBTR1 = OFF           ; Block 1 (001000-001FFF) not protected from table reads executed in other blocks
    CONFIG  EBTR2 = OFF           ; Block 2 (002000-002FFFh) not protected from table reads executed in other blocks
    CONFIG  EBTR3 = OFF           ; Block 3 (003000-003FFFh) not protected from table reads executed in other blocks
    CONFIG  EBTRB = OFF           ; Boot Block (000000-0001FFh) not protected from table reads executed in other blocks
' DEFINEs
    DEFINE    OSC    8                            ' Internal 8MHz
' Pin ALIASES
    LED1            VAR    PORTB.0                    ' Orange Lights
    GRNLED            VAR    PORTB.4                    '
    ClockPin        VAR    PORTA.6                    ' IIC BME280
    DataPin            VAR    PORTA.7                    ' IIC BME280
' CONSTANTS
    ' --- BME280 Registers---
    BMEADDR            CON    $EC                    ' Chip Address
    ID            CON    $D0                    ' Chip ID (0x60)
    ctrl_hum        CON    $F2                    ' Humidity Control Register
    stat            CON    $F3                    ' Status Register
    ctrl_meas        CON    $F4                    ' Temperature/Pressure Control Register
    config            CON    $F5                    ' Cofiguration
    cal_st_addr        CON    $88                    ' Calibration Start Address
' VARIABLES
    FLAG            VAR    BYTE
    IIC_RX            VAR    BYTE[8]                    ' IIC Received Data BME280
   i var byte
    T1            VAR    LONG
    T2            VAR    LONG
    T3            VAR    LONG
    adc_T            VAR    LONG
    var1            VAR    LONG
    var2            VAR    LONG
    T            VAR    LONG
    adc_Tr3            VAR    LONG
'    T1l1            VAR    LONG
'    T2r11            VAR    LONG
'    adc_Tr4            VAR    LONG
'    T1r12            VAR    LONG
'    T3r14            VAR    LONG
    t_fine            VAR    LONG
'    TT            VAR    LONG
' INITIALIZE REGISTERS
    OSCCON = %01110000                            ' Set internal osc to 8MHZ
    ANSEL0 = %00000000                            ' Set to Digital PortA
                                        ' -HW RS232 Setup-
TXSTA = $20   ' Enable transmit, BRGH = 0
SPBRG = 51    ' 9600 Baud @ 8MHz, 0.16%
SPBRGH = 0
BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
                                        ' -HW Timer Setup-
    TMR0H = 0                                ' HighByte of preload value
        TMR0L = 0                                ' LowByte of preload value (the order is important!)
        INTCON.2 = 0                                                ' Clear the flag bit
    T0CON = %10000111                            ' Setup and Enable TMR0 (8.388s)
    TRISA = %00000000                            ' Set ports as outputs (2-4 I/P)
    TRISB = %00000000
    TRISC = %00000000                            ' Set ports as outputs
CLEAR
' PROGRAM Start
    PORTA = 0                                ' Clear PORTA
    PORTB = 0
    PORTC = 0
    IIC_RX = 0
Init:
    GOSUB P500                                ' Let everything settle
    GOSUB VER_BME                                ' Is the BME280 Connected. Verify
MAIN:
    GOSUB GETTEMPBME                            ' Get the temperature reading from BME280
    GOSUB P1
    GOTO MAIN
                                        ' Go back to mainloop
GETTEMPBME:
    'I2CREAD DataPin, ClockPin, BMEADDR, stat ,[IIC_RX]            ' Check to see if busy Converting Measurements, or writing data
    'If IIC_RX[0] != 0 THEN                         ' If not, it should read as 0
    '    GOSUB P100
    '    GOSUB GETTEMPBME
    'ENDIF
'    DO
'        IF FLAG.0 = 1 THEN GOSUB P100                    ' If flag is set the BME280 was not ready (Try again)
'        TOGGLE LED1
'        I2CREAD DataPin, ClockPin, BMEADDR, stat ,[IIC_RX]        ' Check to see if busy Converting Measurements, or writing data
'        FLAG.0 = 1
'    LOOP WHILE IIC_RX[0] != 0                        '
'    FLAG.0 = 0                                ' Clear Flag
'    I2CREAD DataPin, ClockPin, BMEADDR, $F7 ,[STR IIC_RX\8]            ' Read Temp/Hum/Press registers
arraywrite  IIC_RX,[ $55 ,$2F ,$D0 ,$82 ,$D7 ,$90 ,$85 ,$A6 ]
    for i=0 to  6
    HSEROUT[hex2  IIC_RX[i],","]
next
    HSEROUT[hex2  IIC_RX[i],13,10]
'    GOSUB P1
    adc_T.Byte0 = IIC_RX[5]                            ' Store Raw Temerature data
    adc_T.Byte1 = IIC_RX[4]
    adc_T.Byte2 = IIC_RX[3]
'    GOSUB P1
    adc_T=adc_T >> 4
    var1 = ((((adc_T >> 3) - (T1 << 1))) * (T2)) >> 11
    var2 = (((((adc_T >> 4) - (T1)) *((adc_T >> 4) - (T1))) >>12) *(T3)) >>14
    t_fine = var1 + var2
    T = ((t_fine * 5) + 128)>>8
    HSEROUT["T " ,#T/100,".",#T//100,13,10]
VER_BME:
'    I2CREAD DataPin, ClockPin, BMEADDR, ID ,[IIC_RX]            ' Read the BME's ID
'    IF IIC_RX[0] != $60 THEN ERROR2                        ' Cannot Connect to the BME280
'                                        ' -Read Calibration Data for Temperature-
'    I2CREAD DataPin, ClockPin, BMEADDR, cal_st_addr ,[STR IIC_RX\6]        '
arraywrite  IIC_RX,[$6C ,$6E ,$77 ,$66 ,$32 ,$00]
for i=0 to  4
    HSEROUT[hex2  IIC_RX[i],","]                        ' Display -> 6C 6E 77 66 32 00 0D 0A
next
    T1.Byte0 = IIC_RX[0]                            ' Calibration data into Unsigned Word
       T1.Byte1 = IIC_RX[1]
    T2.Byte0 = IIC_RX[2]                            ' Calibration data into Signed Long
       T2.Byte1 = IIC_RX[3]
    T3.Byte0 = IIC_RX[4]                            ' Calibration data into Signed Long
       T3.Byte1 = IIC_RX[5]
                                        ' -Initialise the Sensor-
'    I2CWRITE DataPin, ClockPin, BMEADDR, config ,[%10101000]        ' Config Setting (1000ms Standby, IIR Filter @ 4)
'    I2CWRITE DataPin, ClockPin, BMEADDR, ctrl_hum ,[%00000010]        ' Humidity Setting (x2 Oversampling)
'    I2CWRITE DataPin, ClockPin, BMEADDR, ctrl_meas ,[%01001011]        ' Temp/Pres Settings (x2 Oversampling, Normal Mode)
'    GOSUB P250
ERROR1:
    DO
        TOGGLE LED1                            ' Flash the Orange LED every 1/2 second
        GOSUB P500
    LOOP
ERROR2:                                        ' BME280 Connection Error
    LED1 = 1
    GOSUB P250
    LED1 = 0
    GOSUB P250
    LED1 = 1
    GOSUB P250
    LED1 = 0
    GOSUB P1
    GOTO ERROR2
P100:
    PAUSE 100                                ' Just a pause..
P250:
    PAUSE 250                                ' Just a pause..
P500:
    PAUSE 500                                ' Just a pause..
P1:
    PAUSE 1000                                ' Just a pause..
