Ultrasonic sensor, serial communication.
Results 1 to 3 of 3
    Default Ultrasonic sensor, serial communication.
    Hi Folks,
    I need a little help with this task. I want to read data from Ultrasonic distance meter which put out every 100ms serial data.
    The protocol is here:
    The captured data looks like:
    My program trying to capture this data looks like:
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    ;MCU PIC 12F1840
    DEFINE OSC 4        ; Use internal clock 4MHz
    OSCCON  = %01101010 ; 4 MHz internal
    OSCTUNE	= %00000000	; Internal osc tunning
    TRISA = %100000     ; RA.5 input rest output
    ANSELA = %00000
    OPTION_REG.7=1      ; disable internal pull-ups
    APFCON = %10001100
    string var byte[16]
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    clear
    start:
    hSerin 100,start,[wait ($ff),str string\16]
    HSEROUT [hex string,13,10]
    goto start
    obviously it doesn't work because my poor programming skills.
    I searched the forum to find something to point me how to capture these data but no success.
    Can someone point me how to do that?
    Louis
    Default Re: Ultrasonic sensor, serial communication.
    Try something like:
    Distance VAR WORD
    Sum VAR BYTE
    Start:
      HSERIN 1000, NoData, [wait ($FF), Distance.BYTE1, Distance.BYTE0, SUM]
      ' Here you could evalute SUM to verify packet is correct but lets not do that now.
       HSEROUT["Distance: ", DEC Distance, "mm", 13]
    Goto Start
    NoData:
      HSEROUT["No data from sensor", 13]
      Goto Start
    Thanks Henrik,
    It works.
    How simple and elegant solution.
  1. Need help setting up my ultrasonic distance sensor
    Last Post: - 26th June 2010, 14:06
  2. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 09:01
  3. Water Level Detection using Ultrasonic Sensor
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 12th November 2007, 04:59
  4. sensor ultrasonic 8051&PIC
    By hd_uni_pro in forum Schematics
    Last Post: - 13th September 2006, 12:58
  5. ultrasonic sensor
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 9th May 2006, 20:26
