Which device and out of curiousity, what's up with the slightly odd baudrate?
Well nothing and intermittent isn't quite the same :-)
Are you SURE the serial data is actually getting to the correct pin on the PIC? Have you checked? Scope, logic analyzer?
Write up a simple program to make sure you have a working serial connection both ways, something like:EDIT: Sorry, didn't realise serial was over the BT...I guess data IS comming to the correct pin then.Code:Main: HSERIN 5000, timeout,[char] HSEROUT[char] Goto main Timeout: HSEROUT["Nope, not this time. Lets try again",13] Goto Main
