Can we have multiple 1-wire devices on single pin?
Results 1 to 19 of 19
    Default Re: Can we have multiple 1-wire devices on single pin?
    You do realize 750ms is three quarters of a second? Fan speed will be very wobbly.
    George
    Fan won't stop in absence of PWM signal. most fans, without PWM signal applied, will default to 30-50% RPM.
    Jun 2010
    Venezuela
    hello, you can read several ds18b20 sensors and execute the part of the control that you want to carry out, see the attached file the routine I use in a device for the control of air conditioning and lighting with serial communication.LEER_DS18B20.txt
    And a side question, can we use 1-wire protocol to communicate between 2 PICs?
    The idea is to have the PIC as a master device and the PIC to request a communication.
    So, with the available commands, it is not possible to make a PIC react as a slave 1-wire device.
    You have to write your own code for that.
  1. Random outcome on multiple devices
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2013, 22:36
  2. Multiple I2c Devices
    By alphaengr in forum mel PIC BASIC Pro
    Last Post: - 12th January 2012, 04:37
  3. Multiple serial devices to one pic
    By rshaver in forum mel PIC BASIC Pro
    Last Post: - 16th October 2011, 15:34
  4. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 02:30
  5. Multiple RETURNS within a single subroutine
    Last Post: - 21st June 2009, 16:43
