Can we have multiple 1-wire devices on single pin?
Results 1 to 19 of 19
    Default Re: Can we have multiple 1-wire devices on single pin?
    I have an idea, fan tachometer output will be tied to VDD via 4.7k resistor, as DS18B20 should be. Fan outputs pulses not so fast, so what if I attach DS18B20 to same pin as fan tachometer output? and say, after falling edge of tachometer pulse, perform all DS18B20 stuff, while fan pulls pin high again?
    I believe it takes ~750 Ms. to complete 1 conversion. With that being said, How are you going to discern if the next pulse is the tach output or the DS output?
    EN82fn
    Yes, so I came to different solution. I also have PWM output pin, which goes into fan PWM in. So I'll hook DS18B20 to it - When I need to use thermometer, I will stop HPWM output on that pin, read the thermometer and then resume HPWM operation. I guess, fan will have enough inertia to have no significant impact on it's rpm.
    You do realize 750ms is three quarters of a second? Fan speed will be very wobbly.
    George
    Fan won't stop in absence of PWM signal. most fans, without PWM signal applied, will default to 30-50% RPM.
    Jun 2010
    Venezuela
    hello, you can read several ds18b20 sensors and execute the part of the control that you want to carry out, see the attached file the routine I use in a device for the control of air conditioning and lighting with serial communication.LEER_DS18B20.txt
    And a side question, can we use 1-wire protocol to communicate between 2 PICs?
  1. Random outcome on multiple devices
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2013, 22:36
  2. Multiple I2c Devices
    By alphaengr in forum mel PIC BASIC Pro
    Last Post: - 12th January 2012, 04:37
  3. Multiple serial devices to one pic
    By rshaver in forum mel PIC BASIC Pro
    Last Post: - 16th October 2011, 15:34
  4. Need Single wire serial LCD converter example
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2009, 02:30
  5. Multiple RETURNS within a single subroutine
    Last Post: - 21st June 2009, 16:43
