Bluetooth HC-05 Question
Results 1 to 3 of 3
    May 2012
    Merseyside, UK
    Default Bluetooth HC-05 Question
    HI thank you for reading
    I have a project involving a HC05 / 06 Bluetooth module .... All is good but for one thing.
    I need the thing to drop connection when the host connection goes out of range
    Once paired it seems to stay paired, the only work around I can see is to cycle the power?
    But as the installation is remote not sure if feasible ?
    reason I need to drop connection is so different hosts can connect at different random times
    Ideas as always welcome
    Andy
    Sep 2009
    Default Re: Bluetooth HC-05 Question
    Look at command set:
    https://www.itead.cc/wiki/Serial_Por...Slave)_:_HC-05
    Be aware that there is several fw for HC-05. I have build programmer for them that worked on parallel port. So I could write FW that is best suited for me.
    You have several options, you can:
    1. disconnect using AT+DISC
    2. reset module AT+RESET
    3. remove all auth devices, AT+ RMAAD.
    I hope that this will help...
    if you use esp8266 IP device for serial comms, it will take up to 5 simultaneous connections.
  1. Bluetooth HC-05 Parity
    By brainless in forum Bluetooth
    Last Post: - 26th June 2018, 16:31
  2. Bluetooth headset for non bluetooth devices?
    By Normnet in forum Bluetooth
    Last Post: - 26th September 2015, 11:22
  3. Help with bluetooth...
    By mbox in forum Bluetooth
    Last Post: - 8th October 2009, 06:16
  4. Add RF to Bluetooth ???
    By Ron Marcus in forum Bluetooth
    Last Post: - 13th April 2007, 14:57
  5. Bluetooth
    By Beavis in forum General
    Last Post: - 16th January 2006, 10:19
