PPS understanding on 16F15313
Results 1 to 15 of 15
    Feb 2008
    Michigan, USA
    Default Re: PPS understanding on 16F15313
    With your suggestions I was able to get it working. I will post the basics in case someone else needs to get through this. Having a better understanding of PPS will help a lot moving forward and allow me to take advantage of a lot of new features, some of which I didn't even know existed like an Angular Timer and a Math Accelerator with Proportional-Integral-Derivative (PID). Very interesting blocks to work with.
    bo
    Feb 2008
    Michigan, USA
    Here's what I finally worked out:
    '*** DT_INTS_14.pbp changed and renamed DT_INTS_16F1xxx.pbp (AND put in the right folder!  ******************
    '*** bottom 2 lines apply to program below *******
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
      #define ALL_INT      	INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
      #define T1GATE_INT   	PIR1,TMR1GIF, PIE1,TMR1GIE  ;-- Timer1 Gate         *
      #define INT_INT      	PIR0,INTF,  PIE0,INTE       ;-- External INT
        #define IOCA0_INT   IOCAF,IOCAF0, PIE0,IOCIE   ; RA0 IOC+           (MR)
        #define IOCA1_INT   IOCAF,IOCAF1, PIE0,IOCIE   ; RA1 IOC+           (MR)
        #define IOCA2_INT   IOCAF,IOCAF2, PIE0,IOCIE   ; RA2 IOC+           (MR)
        #define IOCA3_INT   IOCAF,IOCAF3, PIE0,IOCIE   ; RA3 IOC+           (MR)
        #define IOCA4_INT   IOCAF,IOCAF4, PIE0,IOCIE   ; RA4 IOC+           (MR)
        #define IOCA5_INT   IOCAF,IOCAF5, PIE0,IOCIE   ; RA5 IOC+           (MR)
        #define IOCC0_INT   IOCCF,IOCCF0, PIE0,IOCIE   ; RC0 IOC+           (MR)
        #define IOCC1_INT   IOCCF,IOCCF1, PIE0,IOCIE   ; RC1 IOC+           (MR)
        #define IOCC2_INT   IOCCF,IOCCF2, PIE0,IOCIE   ; RC2 IOC+           (MR)
        #define IOCC3_INT   IOCCF,IOCCF3, PIE0,IOCIE   ; RC3 IOC+           (MR)
        #define IOCC4_INT   IOCCF,IOCCF4, PIE0,IOCIE   ; RC4 IOC+           (MR)
        #define IOCC5_INT   IOCCF,IOCCF5, PIE0,IOCIE   ; RC5 IOC+           (MR)
        #define CCP1_15313_INT PIR6,CCP1IF, PIE6, CCP1IE  ;                 (MR)
        #define CCP2_15313_INT PIR6,CCP2IF, PIE6, CCP2IE  ;                 (MR)
    '*  Name    : 16F15313 test-1.BAS
    '*  Author  :
    '*  Notice  : Copyright (c) 2020
    '*             : All Rights Reserved
    '*  Date    : 9/19/20
    '* CCP1 used for Capture,  16F15313 has two
    '*THIS REV:  WORKING
    '                                    16F15313
    '                        ---------------u-------------
    '                      -|vdd (+)                vss(-) |-
    '       VSS out    -|RA5                 RA0/pgd |-  Pulse in *
    '                      -|RA4                  RA1/pgc |-  Neut Out
    '                      -|A3/Vpp/MCLR         RA2/ |-
    include "DT_INTS-16F1xxx.pbp"    ; Base Interrupt System. Ver 1.22
    INCLUDE "ReEnterPBP.pbp"         ; Include for DT_INTS.  ver 3.4
    define OSC 8            ' tell the compiler that the OSC is 8MHz
    OSCEN = %01000000       ' HFINTOSC
    OSCFRQ = %00000011      ' 8MHz
    CCP1PPS = 0              ' assigns CCP1 Input to RA0;
    PulseIN      var PORTA.0  '
    LED1        var PORTA.1  '
    LED2         var PORTA.5  '
    PORTA   = %00001001      ' Outputs (except 0&3) = 0 on bootup
    TRISA = %00001001      ' Pins output(except 0&3)
    ANSELA  = %00000000      ' Set all digital
    ';----[High Priority Interrupts]----------------------------------------
    INT_LIST  macro    ; IntSource,   Label,   Type, ResetFlag?
            INT_Handler  CCP1_15313_INT,   _Capture,  PBP, yes ;
            INT_CREATE               ; Creates the High Priority interrupt processor
            INT_ENABLE  CCP1_15313_INT
    CCP1CON = %10000101    'capture mode, capture on rising edge
    GOTO Main
    '---[CCP1 - interrupt handler]------------------------------------------
    Capture:  ' Enter here with PulseIN (CCP1)
        if CCP1CON = %10000101 then    ' If rising edge capture, then
            toggle LED1
            goto Over_CCP   ' Done, exit
     if CCP1CON = %10000100 then   ' If falling edge capture, then
        toggle LED2
        CCP1CON = %10000101    ' switch back to rising edge
     Over_CCP
    @ INT_RETURN
    not sure your ioc solution will work
    the ioc interrupt flag pir0.4 is not being cleared . you only clear the ioc pin flag, its not enough.
    Feb 2008
    Michigan, USA
    The IOC may not work. I had those in DT_INTS when I was trying to use that instead of CCP. I will have to go back and address that.
    Feb 2008
    Michigan, USA
    For reference, I found a missed line when I copied this to here:
            toggle LED1
            CCP1CON = %10000100    ' switch to falling edge
        toggle LED2
     Over_CCP
    @ INT_RETURN
  1. PIC18F27J13 Peripheral Pin Select (PPS)
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 28th April 2015, 13:51
  2. DIV32 Understanding
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 19th January 2013, 21:44
  3. Help in Understanding the Math
    Last Post: - 24th March 2012, 16:49
  4. So many option but little understanding
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2010, 10:45
  5. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
