PPS understanding on 16F15313
Results 1 to 15 of 15
    Default Re: PPS understanding on 16F15313
    looking at PBP3_PPS_NOTES for ccp i see no mention of seting ccp inputs at all, its outputs
    reassigning ccpx inputs will be a manual effort
    the dt_ints-14 will not work in standard form , all the ccp ints are in pie/r 6
    i would just insert a new int to the file
      #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3                *
      #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4                *
      #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5                *
      #define CCP1_15313_INT     PIR6,CCP1IF, PIE6,CCP1IE    ;-- CCP1
    Feb 2008
    Michigan, USA
    Richard,
    Thanks, I'll work on it again tonight and update as I sort it out.
    btw, thanks for taking up the torch around here. It probably seems tiring helping all the time, but it is appreciated.
    bo
    Feb 2008
    Michigan, USA
    Other than adding the define, is there anything else that needs to be addressed in DT_INTs to make it work?
    other than
    asm
    INT_LIST macro
          INT_Handler  CCP1_15313_INT,   _myisr,    PBP,  yes
          INT_CREATE
    thats about all i recall . http://dt.picbasic.co.uk/ might have some detail i have missed
    Feb 2008
    Michigan, USA
    I have been to http://http://dt.picbasic.co.uk/ a number of times to refresh myself, but I admit, I haven't mined it thoroughly. I went back and found a couple of nuggets. One was in "DT's other code examples" that gave a better explanation of IOC interrupts, the other was by mpgmike named http://dt.picbasic.co.uk/INT16/Customisation.
    I had found his explanation on the forums of the PIC18's, but couldn't quite sort it for the lesser PIC's.
    bo
    i agree, its not very clear which "mods" apply to which dt-ints version
    a simple example adding 1 extra or modified dt-int to each version would be clearer
    adding a swag of int sources you will never use is an overkill for a pretty simple process
    you could use conditional asm constants to add a more generalised approach and standard notation
    like this
    ifdef PIR6
    #define CCP1_INT PIR6,CCP1IF, PIE6,CCP1IE ;-- CCP1
    #define CCP2_INT PIR6,CCP2IF, PIE6,CCP2IE ;-- CCP2
    but who can be bothered to see if every pic16 chip with a PIR6 has a ccp1 + 2 and conforms to these settings.
    and what about new chips
    its just not worth the effort these days
    Feb 2008
    Michigan, USA
    With your suggestions I was able to get it working. I will post the basics in case someone else needs to get through this. Having a better understanding of PPS will help a lot moving forward and allow me to take advantage of a lot of new features, some of which I didn't even know existed like an Angular Timer and a Math Accelerator with Proportional-Integral-Derivative (PID). Very interesting blocks to work with.
    bo
  1. PIC18F27J13 Peripheral Pin Select (PPS)
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 28th April 2015, 13:51
  2. DIV32 Understanding
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 19th January 2013, 21:44
  3. Help in Understanding the Math
    Last Post: - 24th March 2012, 16:49
  4. So many option but little understanding
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2010, 10:45
  5. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
