PBP3_PPS_NOTES.txt:
THIS FILE HAS BEEN UPDATED FOR PBP 3.1.1
Devices with full Peripheral Pin Select (PPS) may be manipulated with the
DEFINEs listed below. Default values shown may be subject to change due to
Microchip pre-defined values. If in doubt, use the DEFINES to override defaults.
Default output pins if no DEFINE is used:
Pins: 8 14/16 20 28/40/48 64
CCP1 RA2 RC5 RC5 RC2 RC2
CCP2 RA5 RC3 RC3 RC1 RC1
CCP3 RA2 RA2 RB5 RC3
CCP4 RC1 RA4 RB0 RG3
RX1 RA1 RC5 RB5 RC7 RC7
TX1 RA0 RC4 RB7 RC6 RC6
RX2 RC1 RC1 RB5* RG2
TX2 RC2 RC2 RB4* RG1
* RX2/TX2 defaults changed for some devices in PBP 3.1.1 to avoid ICSP lockout.
Note that on some devices, any pin that is assigned to a CCP channel
may not function as normal I/O. If a pin's CCP default inhibits a
desired function, you can cancel the default as described below.
HPWM
Use the following PBP DEFINE statements to specify the output pins for HPWM.
Check the Microchip datasheet (Peripheral Pin Select PPS) for the pins allowed
on each CCP channel. The PPS peripheral will automatically be configured
for the specified output pin upon execution of HPWM. When used on devices
without PPS, these defines will only control the Data Direction SFRs (TRIS).
These defines set PPS SFRs only once at program initialization. You may
change the PWM output pin at any point in your program code by modifying
the PPS SFRs. The HPWM command may be used without these DEFINEs if you
manually configure the PPS and TRIS SFRs.
As noted below, you may use DEFINE CCPx_REG 0 to inhibit PPS inititalization
and automatic TRIS settings for any channel. You should do this if you plan
to relocate pins with PPS settings at run-time to avoid erroneous TRIS settings.
DEFINE CCP1_REG PORTC 'Channel-1 port
DEFINE CCP1_BIT 2 'Channel-1 bit
DEFINE CCP2_REG PORTC 'Channel-2 port
DEFINE CCP2_BIT 1 'Channel-2 bit
DEFINE CCP3_REG PORTC 'Channel-3 port
DEFINE CCP3_BIT 3 'Channel-3 bit
DEFINE CCP4_REG PORTG 'Channel-4 port
DEFINE CCP4_BIT 3 'Channel-4 bit
DEFINE CCP5_REG PORTG 'Channel-5 port
DEFINE CCP5_BIT 4 'Channel-5 bit
DEFINE CCP6_REG PORTE 'Channel-6 port
DEFINE CCP6_BIT 6 'Channel-6 bit
DEFINE CCP7_REG PORTE 'Channel-7 port
DEFINE CCP7_BIT 7 'Channel-7 bit
DEFAULT CCP PINS SET FOR UNUSED HPWM CHANNELS! If CCP_REG DEFINEs are set
for unused channels, either explicitly or by default, the ports/pins specified
as CCP/PWM outputs may not function as normal I/O until the PPS SRFs are cleared
in your program code. To remove a default setting, define the CCPx_REG as 0,
for example:
DEFINE CCP2_REG 0 'Channel-2 UNUSED
DEFINE CCP2_BIT 0 'Channel-2 bit
DEFINE CCP3_REG 0 'Channel-3 UNUSED
DEFINE CCP3_BIT 0 'Channel-3 bit
DEFINE CCP4_REG 0 'Channel-4 UNUSED
DEFINE CCP4_BIT 0 'Channel-4 bit
HSEROUT/HSEROUT2
Use the following PBP DEFINE statements to specify the output pins for HSEROUT
and HSEROUT2. Check the Microchip datasheet (Peripheral Pin Select PPS) for the
pins allowed on each EUSART. The PPS peripheral will automatically be configured
for the specified RX/TX pins only once after reset or power up. This allows the
PPS SFRs to be changed at runtime to relocate the RX/TX pins as needed. These
defines will have no effect on devices without PPS.
DEFINE HSER_RXREG PORTC
DEFINE HSER_RXBIT 7
DEFINE HSER_TXREG PORTC
DEFINE HSER_TXBIT 6
DEFINE HSER2_RXREG PORTB
DEFINE HSER2_RXBIT 5
DEFINE HSER2_TXREG PORTB
DEFINE HSER2_TXBIT 4
