IR temp sensor
Results 1 to 6 of 6
Thread: IR temp sensor
    Oct 2010
    Default Re: IR temp sensor
    Yeah, when you do x= y // 50 it will do a divide by 50 and then give you the remainder which can't be more than 49, right?
    If you first multiply the raw value by 2 it means you can then divide by 100 (instead of 50) and do modulo 100 (that's the // operator) to give you two digits after the decimal point. This won't increase the resolution, you'll still have 50 "steps" to the right of the decimal point but they will range from 0 to 98 instead of from 0 to 49.
    Thanks Henrik,
    i will try it out now.
    In the mean time i was playing with the ERPROM registers in order to assign the sign bit. I will leave that on a side and try your advice.
    Oct 2010
    Henrik,
    it worked!!!
    i did the following.
    remainder = (TEMPIR*2)//100
    It looks like it worked as expeced.
    Now i'm focusing to get the sign bit.
  1. Dodge temp sensor
    By Art in forum mel PIC BASIC Pro
    Last Post: - 19th August 2015, 16:18
  2. TMP05 Temp Sensor
    By RichG in forum mel PIC BASIC Pro
    Last Post: - 8th February 2009, 04:33
  3. Using WDT as a Temp Sensor?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 18:55
  4. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
  5. Temp sensor problem
    Last Post: - 14th June 2006, 15:49
