Weird problem with large(ish) array access
Results 1 to 11 of 11
    Default Weird problem with large(ish) array access
    Guys, I need some help here. This is probably one of the strangest bugs I've tried to figure out and I'm starting to believe it's actually not me (for once) doing something wrong.
    From a much larger piece of code I've reduced this as much as I possibly can, here it is in its current state:
    DEFINE OSC 48
    BTN1            VAR PortD.7
    BTN2            VAR PortH.3
    LD1             VAR LATD.4
    LD2             VAR LATE.4
    CRC             VAR WORD
    Number_Of_Bytes VAR BYTE
    Buffer          VAR BYTE[256]
    TRISD.4 = 0
    TRISE.4 = 0
    TRISD.7 = 1
    TRISH.3 = 1
    LD1 = 0
    LD2 = 0
    T0CON = %10000011       ' 1:16 prescaler TMR0 on
        IF INTCON.2 = 1 THEN        ' TMR0 interrupt flag?
            LD2 = ~LD2              ' Toggle LED so we know we're alive and kickin'
            INTCON.2 = 0
        If BTN1 = 0 THEN
            LD1 = 1
            GOSUB SendMsg_1
            LD1 = 0
            WHILE BTN1 = 0 : WEND
        IF BTN2 = 0 THEN
            LD1 = 1
            GOSUB SendMsg_2
            LD1 = 0
            WHILE BTN2 = 0 :WEND
    Goto Main
    SendMsg_1:
        Buffer[0] = $87
        Buffer[1]  = $02
        Buffer[2]  = $06
        Buffer[3]  = $00
        Buffer[4]  = $40
        Buffer[5] = $00
        Buffer[6]  = $00
        Buffer[7]  = $ea
        Buffer[8]  = $c4
        Buffer[9]  = $50
        Buffer[10] = $00
        Buffer[11] = $62
        Buffer[12] = $3b
        Buffer[13] = $30
        Buffer[14] = $00
        Buffer[15] = $b8
        Buffer[16] = $9d
        Buffer[17] = $80
        Buffer[18] = $01
        Buffer[19] = $6c
        Buffer[20]  = $00
        Buffer[21]  = $b8
        Buffer[22]  = $d5
        Buffer[23]  = $80
        Buffer[24]  = $01
        Buffer[25]  = $70
        Buffer[26]  = $00
        Buffer[27]  = $b8
        Buffer[28]  = $b7
        Buffer[29]  = $80
        Buffer[30]  = $01
        Buffer[31]  = $6a
        Buffer[32]  = $00
        Buffer[33]  = $b8
        Buffer[34]  = $57
        Buffer[35]  = $80
        Buffer[36]  = $01
        Buffer[37]  = $6c
        Buffer[38]  = $00
        Buffer[39]  = $b8
        Buffer[40]  = $c4
        Buffer[41]  = $80
        Buffer[42]  = $01
        Buffer[43]  = $7c
        Buffer[44]  = $00
        Buffer[45]  = $b8
        Buffer[46]  = $a7
        Buffer[47]  = $80
        Buffer[48]  = $01
        Buffer[49]  = $69
        Buffer[50]  = $00
        Buffer[51]  = $27
        Buffer[52]  = $0f
        Buffer[53]  = $80
        Buffer[54]  = $01
        Buffer[55]  = $8b
        Buffer[56]  = $00
        Buffer[57]  = $8b
        Buffer[58]  = $73
        Buffer[59]  = $80
        Buffer[60]  = $00
        Buffer[61]  = $0b
        Buffer[62]  = $00
        Buffer[63]  = $b8
        Buffer[64]  = $a3
        Buffer[65]  = $80
        Buffer[66]  = $01
        Buffer[67]  = $6c
        Buffer[68]  = $00
        Buffer[69]  = $b8
        Buffer[70]  = $88
        Buffer[71]  = $80
        Buffer[72]  = $01
        Buffer[73]  = $6c
        Buffer[74]  = $00
        Pause 5            ' If this PAUSE is removed the program crashes
        Buffer[75]  = $b8
        Buffer[76]  = $ce
        Buffer[77]  = $80
        Buffer[78]  = $01
        Buffer[79]  = $7c
        Buffer[80]  = $00
        Buffer[81]  = $b8
        Buffer[82]  = $aa
        Buffer[83]  = $80
        Buffer[84]  = $01
        Buffer[85]  = $6e
        Buffer[86]  = $00
        Buffer[87]  = $f6
        Buffer[88]  = $71
        Buffer[89]  = $80
        Buffer[90]  = $00
        Buffer[91]  = $0b
        Buffer[92]  = $00
        Buffer[93]  = $2c
        Buffer[94]  = $88
        Buffer[95]  = $80
        Buffer[96]  = $01
        Buffer[97]  = $93
        Buffer[98]  = $00
        Buffer[99]  = $14
        Buffer[100]  = $a5
        Buffer[101]  = $80
        Buffer[102]  = $01
        Buffer[103]  = $84
        Buffer[104]  = $00
        Buffer[105]  = $b8
        Buffer[106]  = $ae
        Buffer[107]  = $80
        Buffer[108]  = $01
        Buffer[109]  = $69
    SendMsg_2:
    @ NOP
    The target is the 18F87J50 and I'm using a PIC Clicker 2 from MikroE with their USB bootloader so the CONFIG is whatever their BL is using. No hardware other than what's on the PIC Clicker 2 itself is connected. The board is powered by the USB cable which is also used to download the code via their bootloader.
    At this point the code isn't really doing much at all. If one button is pressed does a NOP and returns, if the other button is pressed it loads an array with values and returns.
    Here's the thing: See that PAUSE 5 about 2/3 down thru the SendMsg_1 subroutine?
    If I remove that PAUSE 5 statement the program works fine until that SendMsg_1 routine is called at which point it just locks up. Do not ask me how I came to that conclusion, it's been MANY hours of head scratching and trial'n'error and I'm probably close to having worn out the FLASH on the poor 87J50.
    I do believe it's some sort of RAM allocation/acces issue because the very last thing I tried before posting here was to remove the declaration of the CRC variable (which isn't used) and then it all of sudden worked without the PAUSE statement in there. But if it IS some sort of RAM allocation/access issue what difference does the PAUSE do? And what exactly am I doint wrong? Even if I go back to my full program and it starts to work if I put that magic PAUSE 5 in there I really don't trust it - besides I really can't waste 5ms...
    Compiling with PBP 3.1.2.4, assembling with MPASM 5.84.
    Any insight here would be most appreciated, thanks!
    Default Re: Weird problem with large(ish) array access
    can't see any reason to it. the pause is not inserted where the banks rollover , its not on a code page boundary
    there is no difference in the lst that indicates a difference between loads.
    perhaps the flash did wear out or the bootloader wierds out somewhere
    i don't have one of those chips and my proteus has not got that model so i cant add much more than
    try loading the buffer this way ,for a different perspective
    [on a 18f26k22 but you can work it out]
      CONFIG  FOSC=INTIO67, PLLCFG=OFF, PRICLKEN=OFF, FCMEN=OFF, IESO=OFF
      CONFIG  PWRTEN=OFF, BOREN=SBORDIS, BORV=190, WDTEN=ON, WDTPS=32768
      CONFIG  CCP2MX=PORTC1, PBADEN=OFF, CCP3MX=PORTB5, HFOFST=ON, T3CMX=PORTC0
      CONFIG  P2BMX=PORTB5, MCLRE=EXTMCLR, STVREN=ON, LVP=OFF, XINST=OFF, DEBUG=OFF
      CONFIG  CP0=OFF, CP1=OFF, CP2=OFF, CP3=OFF, CPB=OFF, CPD=OFF, WRT0=OFF
      CONFIG  WRT1=OFF, WRT2=OFF, WRT3=OFF, WRTC=OFF, WRTB=OFF, WRTD=OFF, EBTR0=OFF
      CONFIG  EBTR1=OFF, EBTR2=OFF, EBTR3=OFF, EBTRB=OFF
    define  OSC 64
    OSCCON    = $70   ; 64Mhz
    OSCTUNE.6 = 1     ; Enable 4x PLL
    flashcount var word
    goto overasm
    Flash2Ram macro buffer, msg,size ; Fills the buffer from flash msg
       movlw   UPPER msg
       movwf   TBLPTRU
       movlw   HIGH msg
       movwf   TBLPTRH
       movlw   LOW msg
       movwf   TBLPTRL
       movlw   low buffer
       movwf   FSR2L
       movlw   High buffer
       movwf   FSR2H
       MOVE?CW  size ,_flashcount
       L?CALL  bfill
    bfill
       tblrd   *+
       movf   TABLAT,w
       movwf  POSTINC2
       CHK?RP _flashcount
       MOVF  _flashcount,w ;DECREMENT 16
       BTFSC STATUS,Z
       DECF  _flashcount +1, f
       DECF  _flashcount , f
       BNZ     bfill
       MOVF  _flashcount +1,w
       BNZ     bfill
       RST?RP
     overasm:
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    TRISB.7=0  ;DEBUG
    LATB.7=1   ;DEBUG
    ansela=0
    trisa=%11001111
    BTN1            VAR Porta.2
    BTN2            VAR Porta.3
    LD1             VAR LATa.4
    LD2             VAR LATa.5
    CRC             VAR WORD
    LD1 = 0
    LD2 = 0
    T0CON = %10000111       ' 1:16 prescaler TMR0 on
            INTCON.2 = 0
        If BTN1 = 0 THEN
            LD1 = 1
            GOSUB SendMsg_1
            LD1 = 0
        IF BTN2 = 0 THEN
            LD1 = 1
            GOSUB SendMsg_2
            LD1 = 0
    Goto Main
    SendMsg_1:
    @ Flash2Ram  _Buffer, _msg1,110
    '    Buffer[0] = $87
    '    Buffer[1]  = $02
    '    Buffer[2]  = $06
    '    Buffer[3]  = $00
    '    Buffer[4]  = $40
    '    Buffer[5] = $00
    '    Buffer[6]  = $00
    '    Buffer[7]  = $ea
    '    Buffer[8]  = $c4
    '    Buffer[9]  = $50
    '    Buffer[10] = $00
    '    Buffer[11] = $62
    '    Buffer[12] = $3b
    '    Buffer[13] = $30
    '    Buffer[14] = $00
    '    Buffer[15] = $b8
    '    Buffer[16] = $9d
    '    Buffer[17] = $80
    '    Buffer[18] = $01
    '    Buffer[19] = $6c
    '    Buffer[20]  = $00
    '    Buffer[21]  = $b8
    '    Buffer[22]  = $d5
    '    Buffer[23]  = $80
    '    Buffer[24]  = $01
    '    Buffer[25]  = $70
    '    Buffer[26]  = $00
    '    Buffer[27]  = $b8
    '    Buffer[28]  = $b7
    '    Buffer[29]  = $80
    '    Buffer[30]  = $01
    '    Buffer[31]  = $6a
    '    Buffer[32]  = $00
    '    Buffer[33]  = $b8
    '    Buffer[34]  = $57
    '    Buffer[35]  = $80
    '    Buffer[36]  = $01
    '    Buffer[37]  = $6c
    '    Buffer[38]  = $00
    '    Buffer[39]  = $b8
    '    Buffer[40]  = $c4
    '    Buffer[41]  = $80
    '    Buffer[42]  = $01
    '    Buffer[43]  = $7c
    '    Buffer[44]  = $00
    '    Buffer[45]  = $b8
    '    Buffer[46]  = $a7
    '    Buffer[47]  = $80
    '    Buffer[48]  = $01
    '    Buffer[49]  = $69
    '    Buffer[50]  = $00
    '    Buffer[51]  = $27
    '    Buffer[52]  = $0f
    '    Buffer[53]  = $80
    '    Buffer[54]  = $01
    '    Buffer[55]  = $8b
    '    Buffer[56]  = $00
    '    Buffer[57]  = $8b
    '    Buffer[58]  = $73
    '    Buffer[59]  = $80
    '    Buffer[60]  = $00
    '    Buffer[61]  = $0b
    '    Buffer[62]  = $00
    '    Buffer[63]  = $b8
    '    Buffer[64]  = $a3
    '    Buffer[65]  = $80
    '    Buffer[66]  = $01
    '    Buffer[67]  = $6c
    '    Buffer[68]  = $00
    '    Buffer[69]  = $b8
    '    Buffer[70]  = $88
    '    Buffer[71]  = $80
    '    Buffer[72]  = $01
    '    Buffer[73]  = $6c
    '    Buffer[74]  = $00
    '    Buffer[75]  = $b8
    '    Buffer[76]  = $ce
    '    Buffer[77]  = $80
    '    Buffer[78]  = $01
    '    Buffer[79]  = $7c
    '    Buffer[80]  = $00
    '    Buffer[81]  = $b8
    '    Buffer[82]  = $aa
    '    Buffer[83]  = $80
    '    Buffer[84]  = $01
    '    Buffer[85]  = $6e
    '    Buffer[86]  = $00
    '    Buffer[87]  = $f6
    '    Buffer[88]  = $71
    '    Buffer[89]  = $80
    '    Buffer[90]  = $00
    '    Buffer[91]  = $0b
    '    Buffer[92]  = $00
    '    Buffer[93]  = $2c
    '    Buffer[94]  = $88
    '    Buffer[95]  = $80
    '    Buffer[96]  = $01
    '    Buffer[97]  = $93
    '    Buffer[98]  = $00
    '    Buffer[99]  = $14
    '    Buffer[100]  = $a5
    '    Buffer[101]  = $80
    '    Buffer[102]  = $01
    '    Buffer[103]  = $84
    '    Buffer[104]  = $00
    '    Buffer[105]  = $b8
    '    Buffer[106]  = $ae
    '    Buffer[107]  = $80
    '    Buffer[108]  = $01
    '    Buffer[109]  = $69
        Number_Of_Bytes=0
        debug 13,10
        while    Number_Of_Bytes <109
            debug hex Buffer[Number_Of_Bytes]
            Number_Of_Bytes=Number_Of_Bytes+1
            if   Number_Of_Bytes//10 then
                debug ","
                debug 13,10
        wend
        debug hex Buffer[Number_Of_Bytes],13,10
    SendMsg_2:
    @ NOP
    msg1:
        DB 0X87,0X02,0X06,0X00,0X40,0X00,0X00,0Xea,0Xc4,0X50,0X00,0X62,0X3b,0X30,0X00,0Xb8
        DB 0X9d,0X80,0X01,0X6c,0X00,0Xb8,0Xd5,0X80,0X01,0X70,0X00,0Xb8,0Xb7,0X80,0X01,0X6a
        DB 0X00,0Xb8,0X57,0X80,0X01,0X6c,0X00,0Xb8,0Xc4,0X80,0X01,0X7c,0X00,0Xb8,0Xa7,0X80
        DB 0X01,0X69,0X00,0X27,0X0f,0X80,0X01,0X8b,0X00,0X8b,0X73,0X80,0X00,0X0b,0X00,0Xb8
        DB 0Xa3,0X80,0X01,0X6c,0X00,0Xb8,0X88,0X80,0X01,0X6c,0X00,0Xb8,0Xce,0X80,0X01,0X7c
        DB 0X00,0Xb8,0Xaa,0X80,0X01,0X6e,0X00,0Xf6,0X71,0X80,0X00,0X0b,0X00,0X2c,0X88,0X80
        DB 0X01,0X93,0X00,0X14,0Xa5,0X80,0X01,0X84,0X00,0Xb8,0Xae,0X80,0X01,0X69
    Thanks Richard!
    This one's got me stumped for sure. After posting yesterday I had to get on with what I was doing so I just left the PAUSE 5 in there and added the remaining pieces of code back in and it worked fine. Then, this morning, after seeing your post about that there "should not be" any difference I removed the PAUSE 5 and it still worked (!)
    Then, even more stumped, I went back to the code I posted yesterday and it's repeatable. Without the PAUSE 5 it hangs. If I then remove the declaration of the CRC variable it works again. With the CRC variable declared AND the PAUSE 5 it also works.
    This piece of code is just something that I need to send messages to the device I'm actually trying to write the code for. As it stands I've probably spent 3/4 of the time on the code for the "helper" device and 1/4 of the time on the ACTUAL device. The end device is also using the 87J50 so I can't help worrying that something bad might be happening.
    Over the years I've come to trust what the PBP compiler produces and I can not remember a single time that an issue has not been MY fault but, honestly, this thing I do not understand.
    Thank you for the ASM array loader routines, I will most certainly try those when I get this piece of code out the door. Doing it "my way" is uggly and using ARRAYWRITE doesn't really work for hundreds of bytes.
    are you using 3.1xx ?
    i looked at a 3.0xxxx lst file [Buffer start was 0x1f with crc in so 0x1f + 74d= (0x69) and not near the bank end]
    it might pay to see if adding the crc var pushed the array over a bank boundary or not near the "pause", the pause may get the banksel re-evaluated somehow to obscure the defect.
    if that's the case it will indeed be a nasty bug just waiting to pounce if not addressed
    Yes, PBP 3.1.2.4
    If I leave the CRC variable declared it puts it at 0x0026 and Buffer at 0x0029.
    _BTN1                             _PORTD??7
    _BTN2                             _PORTH??3
    _Buffer                           00000029
    _CRC                              00000026
    _DEVID1                           003FFFFE
    If I remove the CRC variable then Buffer starts at 0x0027 instead.
    With CRC variable declared (Buffer starting at 0x0029) it crashes but if I then comment out the lines that access Buffer[108] and Buffer[109] it does NOT crash.
    If I comment out the access to Buffer[107] or any other (not that I've tried them all but anyway) it still crashes.
    So I thought it "had to be" something with the RAM access but then I added that PAUSE 5 again, which magically makes everything work.
    CRC is still being put at 0x0026 and Buffer at 0x0029 so now I'm thinking it's NOT a RAM thing but a code memory thing....
    Adding the PAUSE 5 adds library code pushing "my" code down.
    I can put the Pause 5 anywhere within the SendMsg_1 subroutine as long as it is before the last two lines, accessing Buffer[108] and Buffer[109].
    Oh, it just hit me - I've been compiling with LONGs enabled.
    If I disable that it puts CRC at 0x001C and Buffer at 0x001F and it works without the Pause 5 in there which makes me think it's not a code thing but a RAM thing...
    Could it have anything to do with the bootloader?
    It seems custom to DEFINE RESET_ORG 1000h for USB HID bootloader but if I do that with the MikroE USB HID bootloader it seems to get stuck in bootload mode.
    I'm really lost here, don't understand and can't figure out WTF is happening.
    it would be provable , the board has access to a icsp with a modified cable you could overwrite the loader easily enough.
    you can download the loader from mikroe to replace it afterwards
    since you have repeatable example to offer charles it could not hurt to ask his advice.
    the 108 cell in buffer is pretty close to access bank sfr range , i wonder if there is a stray access ram bit being set in an instruction
    that could all sorts of bad stuff.
    have / can you re-verify code ?
    can you blank a code range and verify it is blank. [bootloaders are they worth the doubts?]
    another thought, on the non long version
    if you load up another 30 or so cells in buffer with 00 or ff do problems recur
    [surely its not just 01 or 0x69 that causes issue]
    The plot thickens...
    Long stort short, flashed the device with the PICKit3, could not reproduce the error. Reflashed the bootloader into it and now I can no longer reproduce the error at will - even my ACTUAL code now works without that magic PAUSE 5 in there.
    Before doing that I had reduced the test code to this:
            INTCON.2 = 0
        If BTN1 = 0 THEN
    '        Buffer[107] = $00       ' Testcase with LONGs
            Buffer[117] = $00       ' Testcase without LONGs
        IF BTN2 = 0 THEN
    '        Pause 5
    '        Buffer[108] = $00       ' Testcase with LONGs
            Buffer[118] = $00       ' Testcase without LONGs
    Goto Main
    As soon as the code for BTN2 was executed it crashed while the code for BTN1 worked fine. Enabling the PAUSE 5 made it work. And the value being written made no difference.
    As for the question if bootloaders are worth it I'd say maby. In this particular case I'm juggling two boards but I only have one PICKit so swapping between boards would be less than ideal. The USB bootloader is super fast but makes up for that by forcing you to manually reset the device and press connect in the PC application before the bootloader times out.
    Strange one this.
    how about contact bounce on button switches ?
    the only thing i can think of it to verify the flash as written by the bootloader is set the way it was intended to be.
    Can you test the program on different kind of PIC?
    Also, without bootloader, it works OK without the magic PAUSE 5 line?
    It does seem a RAM problem related to LONGs but Charles may help more.
  1. Array variable access time
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 25th April 2020, 08:48
  2. Replies: 9
    Last Post: - 14th September 2014, 20:38
  3. Weird Problem
    By isaac in forum General
    Last Post: - 22nd September 2008, 20:30
  4. Access array in PBP and .asm
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 6th September 2008, 01:35
  5. Large-ish PCB order...others wanted...
    By skimask in forum Off Topic
    Last Post: - 16th June 2006, 03:43
