Dear all,
i need your help once again. I would like to replace the physical matrix 3x4keypad combination lock with a Digital touch screen display.
I have for couple of years a display from 4D systems, 32DT which is a nice touch display. So i though i could add the digital 3x4 matrix keypad and retrieve the information for every key, via serial port and using this information, i could manage to make a simple combination code.
Name:  4d combination lock.png
The following is the information recieved for every key pressed. There is also 07Hex in front of all those numbers.
As i read the datasheet of the Screen the actual value every number sent.....for example for the number 1 is 31hex.
num1    data  "0D0000313B" ; this is number 1
num2 	data  "0D00003238" ; this is number 2
num3    data  "0D00003339" ; this is number 3
num4    data  "0D0000343E" ; this is number 4
num5    data  "0D0000353F" ; this is number 5
num6    Data  "0D0000363C" ; this is number 6
num7    Data  "0D0000373D" ; this is number 7
num8    Data  "0D00003832" ; this is number 8
num9    data  "0D00003933" ; this is number 9
num10   data  "0D00002A20" ; this is number *
num11   data  "0D0000303A" ; this is number 0
num12   data  "0D00000802" ; this is number #
In the beggining i wanted to store those values everytime the key is pressed. My knowledge in programming is limitted so i though that if i want to use the digital 3x4 touch display i need to find an other way.
Please check the following program....it works for the first couple of 30 seconds. But then somthing goes wrong, maybe in the loops or in the gosub instructions, and program messed up and freeze.
Could anyone help me please?
'*  Notes   : This is a codelock based on the following components    *
'*          : PIC18F26K22 or PIC18F46K22 @ 64Mhz                      *
'*          : 4D Systems ULCD 32DT diablo                             *
@ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                  ; crossing page boundary - make sure bits are set              *
  #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
;    CONFIG FOSC     = RCIO6	    ; External RC oscillator
     CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
;*---------------------------------4x PLL ENABLE--------------------------------------*|
;*  4X PLL Enable        *|
;*    CONFIG PLLCFG  = OFF	        ;Oscillator used directly                         *|
    CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4                       *|
;  Primary clock enable bit
;    CONFIG PRICLKEN = OFF	        ;Primary clock can be disabled by software
    CONFIG PRICLKEN  = ON	        ;Primary clock enabled
;  Fail-Safe Clock Monitor Enable bit
    CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
;    CONFIG FCMEN    = ON	        ;Fail-Safe Clock Monitor enabled
;  Internal/External Oscillator Switchover bit
    CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
;    CONFIG IESO     = ON	        ;Oscillator Switchover mode enabled
    CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
    CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
    CONFIG  PWRTEN   = ON
    CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
    CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
    CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
    CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    CONFIG  DEBUG    = OFF          ; Disabled
define  OSC 64
        INCLUDE "modedefs.bas"
        INCLUDE"ALLDIGITAL.pbp"
OSCCON    = %01110000   ; 64Mhz
OSCTUNE.6 = 1           ; Enable 4x PLL
while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
TRISB = %00000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                    'in PORTC the RC3 attached is an LED.
'--------------------------- TRIS A B C ---------------------------------|
' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
'  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
'   0        0        0        0        0        0        0        0     |
' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
'   0        0        0        0        0        0        0        0     |
' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
'   1        0        0        0        0        0        0        0     |
'----------------------- At start all PORTS LOW -------------------------|
PORTA = 0            'make low all ports at A range                      |
PORTB = 0            'make low all ports at B range                      |
PORTC = 0            'make low all ports at C range                      |
PORTE = 0            'make low all ports at E range                      |
'-------------------------- COMPARATORS OFF -----------------------------|
CM1CON0.7 = 0 'Disable comparator1                                       |
CM2CON0.7 = 0 'Disable comparator2                                       |
'*----------------------- | EUART 1 Configuration  | --------------------------|
        DEFINE HSER_SPBRG 138 ' 115200 Baud @ 64MHz, -0.08%
        SPBRGH = 0
'*----------------------- | EUART 2 Configuration  | --------------------------|
        DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
        DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
        DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
        DEFINE HSER2_SPBRG 160 ' 38400 Baud @ 64MHz, -0.08%
        SPBRGH2 = 1
        BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
Timeout         CON 2000
DATAIN          var byte[5]
ResetLCD        var PORTC.2
RED             var PORTC.3
BLUE            var PORTC.4
i               var byte
' -----[ EEPROM Data ]-----------------------------------------------------
i just made a note of those numbers.
;num1    data  "0D0000313B" ; this is number 1
;num2 	data  "0D00003238" ; this is number 2
;num3    data  "0D00003339" ; this is number 3
;num4    data  "0D0000343E" ; this is number 4
;num5    data  "0D0000353F" ; this is number 5
;num6    Data  "0D0000363C" ; this is number 6
;num7    Data  "0D0000373D" ; this is number 7
;num8    Data  "0D00003832" ; this is number 8
;num9    data  "0D00003933" ; this is number 9
;num10   data  "0D00002A20" ; this is number *
;num11   data  "0D0000303A" ; this is number 0
;num12   data  "0D00000802" ; this is number #
;                           [LCD hold on reset]                                |
high resetlcd
low resetlcd
'                            [ pic power led ]                                 |
for i = 1 to 5
high RED : pause 50
low red : pause 50
next i
high red
Start:
HSERIN [WAIT($07), str datain\5]
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$31  and  datain[4] =$3B then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$32  and  datain[4] =$38 then
gosub flash2
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$33  and  datain[4] =$39 then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$34  and  datain[4] =$3E then
gosub flash4
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$35  and  datain[4] =$3F then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$36  and  datain[4] =$3C then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$37  and  datain[4] =$3D then
gosub flash7
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$38  and  datain[4] =$32 then
gosub flash8
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$39  and  datain[4] =$33 then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$2A  and  datain[4] =$20 then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$30  and  datain[4] =$3A then
gosub reset
if datain[0] = $0D and  datain[1] =$00 and  datain[2] =$00  and  datain[3] =$08  and  datain[4] =$02 then
gosub flash12
     goto start
flash:
hserout2 [str datain\5]
high blue
pause 50
low blue
flash2:
high blue
pause 50
low blue
high portb.0
gosub chkey
flash7:
high blue
pause 50
low blue
high portb.1
gosub chkey
flash8:
high blue
pause 50
low blue
high portb.2
gosub chkey
flash4:
high blue
pause 50
low blue
high portb.3
gosub chkey
flash12:
high blue
pause 50
low blue
high portb.4
gosub chkey
chkey:
if  portb.0 = 1 and portb.1 = 0 and portb.2 = 0 and portb.3 = 0 and portb.4 = 0 then start
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 0 and portb.3 = 0 and portb.4 = 0 then start
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 1 and portb.3 = 0 and portb.4 = 0 then start
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 1 and portb.3 = 1 and portb.4 = 0 then start
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 1 and portb.3 = 1 and portb.4 = 1 then pwok
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 0 and portb.3 = 0 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 0 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 0 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 0 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 1 and portb.3 = 0 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 1 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 1 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 0 and portb.2 = 1 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 0 and portb.3 = 0 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 0 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 0 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 0 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 1 and portb.3 = 0 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 1 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 1 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 0 and portb.1 = 1 and portb.2 = 1 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 0 and portb.2 = 0 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 0 and portb.2 = 0 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 1 and portb.1 = 0 and portb.2 = 0 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 0 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 0 and portb.3 = 1 and portb.4 = 0 then
gosub reset
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 0 and portb.3 = 1 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 1 and portb.2 = 1 and portb.3 = 0 and portb.4 = 1 then
gosub reset
if  portb.0 = 1 and portb.1 = 0 and portb.2 = 1 and portb.3 = 0 and portb.4 = 0 then
gosub reset
reset:
high blue
pause 50
low blue
low portb.0
low portb.1
low portb.2
low portb.3
low portb.4
pwok:
low portb.0
low portb.1
low portb.2
low portb.3
low portb.4
high portb.5
pause 2000
low portb.5
