Advices required for Soap dispenser / sanitizer code
Results 1 to 8 of 8
    Default Re: Advices required for Soap dispenser / sanitizer code
    At work, we make a product that detects hand motion to light up a string of LED's. You can use a FET to drive the soap pump motor. We use the ADC in a 12F675 to detect fluctuations from a 5528 LDR. ADC has 47K pull down resistor, other side of LDR to B+.
    IF you use the comparator its as simple as this.it won't re-arm itself until hand is removed
    #config
       __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    #endconfig
    DEFINE OSCCAL_1K 1
    DEFINE OSC  4
    CMCON    = %00001110
    TRISIO   = %111011
    vrcon=$88    ;about vcc on 2
     ANSEL=1
    tmp var byte
    intcon=$40
    pir1=0
    PIE1=8
    asm
     SLEEP
     nop
    endasm
    if  CMCON.6 then
    gpio.2=1
    gpio.2=0
    Dec 2008
    Ploiesti, ROMANIA
    Thank you very much ! I think this is what I need ! I will tested and post the results. Regards !
  1. Thermistor based temperature reading short code required
    By asifiqbal in forum mel PIC BASIC Pro
    Last Post: - 12th November 2014, 09:18
  2. Cash dispenser
    By tigerflow in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2009, 11:40
  3. Help Required for Newbie
    By Moz in forum General
    Last Post: - 13th August 2004, 01:05
  4. Help Required
    By lester in forum Forum Requests
    Last Post: - 19th July 2003, 23:16
