18f2680 can config
Results 1 to 3 of 3
    Default 18f2680 can config
    Hi I could do with a bit of help on optimum PIC18F2680 CAN timing settings.
    It is correctly terminated with 120R resistors at both ends.
    I'm confused by quanta etc.
    The PIC data sheet is attached and I have tried the three lots of settings shown in the code tags below.
    I also tried various online calculators.
    What do you think the optimum register settings should be for the 32mhz PIC and 500kbps 3 Meter CAN bus? :unsure:
    'Test1 Doesn't Work at all
    'BRGCON1 = %01000001 'brp = 2(32 mhz), jump 2 TQ (SWJ)
    'BRGCON2 = %10011000 'freely programmable , sample once, 4TQ seg1, propagation time 1Tq
    'BRGCON3 = %00000011 '4TQ seg2
    'Test2 Works Better. (This is the one I am using at present but I still have some errors)
    BRGCON2 = %10101110 'freely programmable , sample once, 6TQ seg1, propagation time 7Tq
    BRGCON3 = %00000001 '2TQ seg2
    'Original Works + Errors
    'BRGCON1 = %00000001 'brp = 2(32 mhz), jump 1 TQ (SWJ)
    'BRGCON2 = %10001111 'freely programmable , sample once, 2TQ seg1, propagation time 8Tq
    'BRGCON3 = %00000100 '5TQ seg2
    Default Re: 18f2680 can config
    No one working with CAN?
    Too complicated!
  1. Config help
    By Sabahan in forum PBP3
    Last Post: - 4th September 2014, 00:33
  2. config
    By n0yox in forum PBP3
    Last Post: - 10th June 2014, 08:07
  3. PIC12F675 - config
    By Vezito in forum mel PIC BASIC Pro
    Last Post: - 8th June 2011, 20:29
  4. config help please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 23:49
  5. Need help with config
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 06:57
