12F683 _CONFIG problem
Results 1 to 11 of 11
    Default Re: 12F683 _CONFIG problem
    I had to once, find the '683' INC or MAC file referred to by the assembler, look at the way the configs are expected in those files. I had to change my code to match the referenced/expected format/characters
    I've never seen it done like that before and I also use DT stuff and 16f83...
    Plus to the above, you still had one underscore instead of the correct two.
    I have used the following header for the 12F683 many times and never encountered any compiling problems. Try it.
    CMCON0 = 7 'comparators off
    ANSEL = 0 'all inputs digital, the adcin command automatically converts it to analog
    DEFINE OSCCON_1K 1 ' Set OSCCAL for 1K device to accurize osc
    OSCCON = %01110111 'Set osc to 8MHZ 12F683. Normally I leave this line out to default to 4MHZ
    @ DEVICE MCLR_ON, INTRC_OSC_NOCLKOUT, WDT_ON, BOD_OFF, PWRT_ON, PROTECT_ON
    START:
    I think you refer to an ancient version of PBP.
    Now we do not use this @ DEVICE MCLR_ON.....
    Current versions use this syntax:
    #config
     __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _BOD_OFF & _MCLRE_ON & _CP_OFF
    #endconfig
    Yes it is old. I think it's version 2.65 or something.
  1. 12F683 Light Dimmer Problem (SOLVED)
    By DavyJones in forum General
    Last Post: - 24th July 2020, 23:59
  2. PIC 12F683 and DS18B20 problem
    By slash819 in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 19:31
  3. 12F683 Logic Output Problem?
    By shockwave in forum mel PIC BASIC Pro
    Last Post: - 25th February 2012, 20:48
  4. _config set change for pic12f683
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 20th March 2010, 02:03
  5. 12F683 GPIO.3 problem
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 09:43
