Heart rate sensor MAX30102
Results 1 to 40 of 85
    Oct 2010
    Default Re: Heart rate sensor MAX30102
    its alive i think
    Attachment 9142
    gives me a 63 rpm
    wow, ok little by little because i need to undestand what you have done.
    apart from that 63 bpm is quite ok and looks healthy.
    Low pass filter in excel
    makes peak detection look possible
    '****************************************************************'*  Name    : MAX30102  FOR PIC 18 DEMO                         *
    '*  Author  :  Richard                                          *
    '*  Notice  :                                                   *
    '*  Date    : 9/1/2022                                          *
    '*  Notes   : MAX30102                                          *
    '*          :18f26k22 @64Mhz                                    *
      #CONFIG   ;  The PBP configuration for the PIC18F26K22 is:
        CONFIG FOSC     = INTIO67
        CONFIG PLLCFG   = OFF	        ;Oscillator multiplied by 4
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    'define I2C_SLOW 1
    define  OSC 64
    OSCCON    = %01110000   ; 16Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    TRISC = %11011000
    ANSELC=0
    #DEFINE    DEBUGING 1
    #IFNDEF  DEBUGING
        DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0.08%
        SPBRGH = 1
    #ELSE
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        ANSELB=0
        LATB.7=1
    #ENDIF
    SDA     var portc.4  ' DATA PIN
    SCL     VAR portc.3  ' CLOCK PIN
    Timeout    cON 2000
    reg        var BYTE
    fifo       var byte[6]
    addr       var byte
    REVISION   var byte
    PARTID     var byte
    buffer     var byte[1152]
    ptr        var byte
    btr        var byte
    index      var word
    result     var word ext
    @result = _fifo
    ;-----------------------  REGISTER -------------------------
    REG_TEMP_INT         con $1F
    REG_TEMP_FRAC        con $20
    REG_TEMP_CONFIG      con $21
    REG_PART_REVISION    con $FE
    REG_MODE             con $09
    REG_SPO2_CONFIG      con $0A        ;SPO2_ADC_RGE[6:5]SPO2_SR[4:2]LED_PW[1:0]
    REG_LED1_PA          con $0C
    REG_LED2_PA          con $0D
    FIFO_WR_PTR          con $04        ;FIFO_WR_PTR[4:0]
    FIFO_RD_PTR          con $06
    FIFO_DATA            con $07
    FIFO_CONFIG          con $08        ;FIFO_A_FULL[3:0]   SMP_AVE[7:5]
    OVF_COUNTER          con $05
    STATUS1              con 0          ;A_FULL[7]
    INTERRUPT_EN         con 2
    #IFDEF  DEBUGING
        PAUSE 2000
        DEBUG 13,10,  "READY"
    #ENDIF
        ADDR = $ae     ; addr is  0x57 << 1
        reg = REG_PART_REVISION
        i2cread  SDA,scl,ADDR,reg,[REVISION,PARTID]
        reg = REG_MODE
        i2cwrite  SDA,scl,ADDR,reg,[3]
        reg = REG_SPO2_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[$20]
        reg = REG_LED2_PA
        i2cwrite  SDA,scl,ADDR,reg,[10]
        reg = REG_LED1_PA
        reg = FIFO_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[16]
        reg = INTERRUPT_EN
        i2cwrite  SDA,scl,ADDR,reg,[$E0]
    #IFNDEF  DEBUGING
        HSEROUT [$73,$03,$04,$11,$ff,$ff,"PART ID: 0X",hex PARTID,"/0X", hex REVISION,$00]
        Hserin  timeout,error,[wait(6)]
    #ELSE
        DEBUG 13,10,  "PART ID: 0X",hex PARTID,"/0X",hex REVISION
    #ENDIF
    start:
        reg= REG_TEMP_CONFIG
        i2cwrite  SDA,scl,ADDR,reg,[1]
        reg= REG_TEMP_INT
        i2cread  sda,scl,ADDR,reg,[fifo[0],fifo[1]]
    #IFNDEF  DEBUGING
        HSEROUT [$73,$05,$0A,$11,$07,$E0,"TEMP: ",DEC fifo[0],".",DEC2( fifo[1]<<6),$00]
    #ELSE
        DEBUG 13,10, "TEMP: ",DEC fifo[0],".",DEC2( fifo[1]<<6)
    #ENDIF
        GOSUB AQUIRE
        pause 5000
    goto start
    aquire:
        reg= FIFO_WR_PTR
        i2cwrite  SDA,scl,ADDR,reg,[0]
        reg= FIFO_RD_PTR
        reg = OVF_COUNTER
        i2cwrite sda,scl,ADDR,reg,[0]
     FOR index = 0 TO 1151 STEP 0
        btr = 0
        reg = STATUS1
        WHILE (btr&192) = 0
        PAUSE 10
        i2cread  sda,scl,ADDR,reg,[btr]
        DEBUG "Y" ,DEC btr
        WEND
        reg = FIFO_WR_PTR
        i2cread  SDA,scl,ADDR,reg,[Ptr]
        reg = FIFO_RD_PTR
        i2cread  SDA,scl,ADDR,reg,[btr]
        btr = (ptr - btr) &  31
        DEBUG "Z"  ,DEC btr
        WHILE btr
        reg = FIFO_DATA
        i2cread  sda,scl,ADDR,reg,[buffer[index + 2],buffer[index + 1],buffer[index + 0],buffer[index + 5],buffer[index + 4],buffer[index + 3]]
        index = index + 6
        btr = btr - 1
        WEND
     NEXT
         reg = OVF_COUNTER
        i2cread sda,scl,ADDR,reg,[reg ]
         DEBUG 13,10,"OF ",DEC reg
        for ptr = 0 to 2
        fifo[ptr] = buffer[index + ptr]
        next
        DEBUG 13,10;,  hex2 fifo[2] , hex2 fifo[1],  hex2 fifo[0]
        asm         ;ROTATE READING TO GET SUFFICIENT RESOLOUTION INTO UPPER WORD
        banksel _fifo
        bcf STATUS,C
        RRCF  _fifo + 2 ,f
        RRCF  _fifo + 1 ,f
        RRCF  _fifo    ,f
        bcf STATUS,C
        RRCF  _fifo + 2 ,f
        RRCF  _fifo + 1 ,f
        RRCF  _fifo    ,f
        banksel 0
        endasm
        DEBUG 9,HEX4 result
        index = index + 3
    '    DEBUG 13,10, hex2 buffer[index+2],hex2 buffer[index+1],hex2 buffer[index],9 ,HEX4 result
    '    DEBUG 9,  hex2 fifo[2] , hex2 fifo[1],  hex2 fifo[0]
        for ptr = 0 to 2
        next
        banksel _fifo
        bcf STATUS,C
        RRCF  _fifo +2 ,f
        RRCF  _fifo +1 ,f
        RRCF  _fifo    ,f
        bcf STATUS,C
        RRCF  _fifo +2 ,f
        RRCF  _fifo +1 ,f
        RRCF  _fifo    ,f
        banksel 0
        endasm
        DEBUG 9,HEX4 result
        index = index + 3
       NEXT
  1. New PIC failure rate
    By timmers in forum General
    Last Post: - 26th March 2009, 12:11
  2. Rf module baud rate
    By tazntex in forum Serial
    Last Post: - 5th August 2008, 18:47
  3. Replies: 6
    Last Post: - 18th January 2008, 08:17
  4. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 23:42
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:10
